Question about Garden
How to install fuel lines,filter poulan pro 336
Rtten broken
  • 94 Answers
SOURCE: Can't find fuel filter on Poulan Pro weed eater.
Where is the fuel filter?
All gasoline engines have a fuel filter on the end of the fuel line in the fuel tank. Weed Eater recommends changing the fuel filter yearly. To remove the filter,
1. drain the fuel from the unit,
2. Pull the filter from the tank through the gas tank opening and remove it from the line,
3. Install the new filter on the fuel line and drop back in tank.
Posted on Jul 08, 2009
SOURCE: gas line with filter broke inside tank how to
get new line cut end at an angle , lube with oil and twist it in, snag the line and pull it out the filler hole and insert filter on the end, connect and enjoy.
Posted on Jun 01, 2010
rycgl
  • 1545 Answers
SOURCE: diagram fuel lines tank primer carbutor poulan pro
I have no diagram but here are the instructions on how it goes.
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
Posted on May 28, 2011
vincob
  • 718 Answers
SOURCE: Type of trimmer: Poulan Pro
Try cleaning your carb and even buying a rebuild kit. I do not think you have a blockage. Does it even try to start? Cleaning the carb will give you a chance to get rid of any debris or old gummed up fuel and oil that may be in there, give it a try. Good Luck...
Posted on Jun 04, 2011
  • 458 Answers
SOURCE: changed filter and fuel lines, poulan 31cc 250E. starts fine but dies when accelarated
My chainsaw was doing this.The carburetors on these small engines have a fuel inlet screen that clogs with tiny bits of debris.Remove the carb,and take the portion off that has the fuel line attached to it(if you're careful,you can reassemble it without needing a new gasket).The screen is about 5/16" in diameter.Spray some carb cleaner in there to clean the screen out.(this is mt best guess,because it sounds like a fuel starvation problem)
Posted on May 11, 2012
How do i replace fuel lines?
Where do the fuel and primer lines go in Craftsman or Poulan Chainsaw
Hope this helps. Also try to avoid using gasoline with ethanol. This causes the lines to deteriate.
Apr 30, 2016 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My poulan pro bvm210vs blower wouldnt start. Changed fuel lines, fuel filter, and cleaned carb. Now, fuel bulb will only prime when unit is on its side. It then will start, run10 seconds and die
Sounds like you made the Fuel line in the tank too short . OR the stone filter on the fuel line is not able to move about the Fuel tank to follow the fuel
May 06, 2015 | Poulan Garden
I have a Poulan 336 chainsaw and need a repair manual
The link below takes you to a video on YouTube from donnyboy73. He shows you how to tune a Poulan Carburetor. This may be your only problem.
It has mine running in tip top condition.
http://www.youtube.com/watch?v=3Lw0pJcEPYo
Hope this helps.
May 27, 2014 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Won't Start
The silver cylinder that fell out was the fuel filter. Fashion a thin coat hanger into a small hook and try to fish out the plstic tubing. This is your fuel line. If there is enough to get it just out of the tank, cut the broken end off and press back onto a new fuel filter. You should be able purchase one at hardware store such as Home Depot or Lowes. If the hose is broken too far down inside the tank, you will need to take it to a small engine repair shop. Hope this was helpful
May 12, 2014 | Poulan Pro 25CC 2Cycle Gas Blower
Poulan pro 16 inch chainsaw no fuel in primer
did you forget to install the filter on the hose?
Aug 19, 2012 | Poulan Garden
Replacing gas line
Your fuel lines are routed like the schematic below. I suggest you replace the filter, all hoses (2 different sizes), and the purge button (bleeder).
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
May 07, 2010 | Poulan ES350 16" Chain Saw
I need info on a Poulan Pro 445 fuel line routing
I'm so confused. This is reported as a Poulan and McCulloch pole saw, which one? Is it a pole saw? That is the only 445 Poulan I can find. It is reported as an electric but has a fuel routing problem.
If it is a Poulan Pro gas pole saw it is here: PP445 Gas Pole Pruner
The fuel system routing is terrible, but it is all there is.
Fuel Routing follows:
Tank to carburetor (hose in tank with filter on free end)
Carburetor to primer (primer draws fuel from the tank through the carb)
Primer to fuel tank (returns any excess fuel to tank when pushed) HTH
Lou
Oct 11, 2009 | McCulloch 10" Electric Pole / Chain Saw
Can't find fuel filter on Poulan Pro weed eater. Acts as if it's fuel starved
Jul 08, 2009 | Poulan Garden
I have a poulan 305 pro chain saw were do the 2 fuel lines go?
Find your model nuber here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The drawing containing your fuel system is as good as it gets. If you need more help contact PoulanPro.com. HTH
Lou
Jun 03, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
