Question about Pentair White/Gray Legend Platinum Automatic Pool Cleaner - Ll105pm
Water management system in pentair legend
There doesn't seem to be enough pressure to enervate the venturi
  • Pentair Master
  • 1,631 Answers
Check the finger screen in the wall adapter, which is located at the wall, that the hoses are connected to. Inside that is a screen, and it's probably plugged with debris.
Posted on Apr 05, 2015
  • 83 Answers
SOURCE: Pentair Legend fell on side before because the
Have you looked at the swivels in the hose? If they get stuck, it can cause the tipping over. Check the wear on the tires also.
Posted on Jul 01, 2009
  • 990 Answers
SOURCE: Legend pool cleaner wheels not moving
You might want to pull the drive wheels and see if their might be a small pebel stuck in the drive gears on the wheel.
Posted on Oct 04, 2009
  • 10 Answers
SOURCE: Cleaner lacks power won't climb sides
Hey Walt, Check the hose swivels. Alot of the time the hose swivels leak water which defreases the flow to the cleaner. Also, depening on the model Letro cleaner you have, it could be the gear teeth in the wheels. epoolshop.com
Posted on Nov 03, 2009
  • 990 Answers
SOURCE: My Pentair legend isn't picking up debris like it
You will need to take the unit apart and useing a wire clear the jets in the throught then flush with good pressure water. Check your filter to see if it is passing derbs. Also check your finger screen at the wall in the hose connection.
Posted on Jul 07, 2010
thepatioman
  • 52 Answers
SOURCE: Our Pentair Legend moves to a wall and stay there
Yes place the left jet (it rotataes) to the 11:00 position and the right jet to the 5:00 position and it will run correctly.
The Pool Tech
Posted on Jul 14, 2010
Pentair legend platinum sweep hose doesn't sweep
open up the screw on the bottom that will let water to the tail
Apr 28, 2012 | Pentair White/Gray Legend Platinum...
Jul 06, 2010 | Pentair White/Gray Legend Platinum...
My Pentair legend pool cleaner is not moving
On this automatic pool cleaner, this is usually an easy thing to fix. First, make sure that your filter bag is clean and free of obstructions. Next, take of your head float and shake it. If you can hear water inside, you will need to order a new head float and install it. They are usually inexpensive and easy to replace. Make sure the hose floats are evenly placed and make sure that the cleaner is not getting too much pressure from the return lines.
May 25, 2010 | Pentair White/Gray Legend Platinum...
Pentair legend 4 wheel cleaner - runs over its hose
check the white float on the cleaner. take it off and shake it, if it is full of water you will need to replace it. when they get water in them they make the cleaner heavy and it will tip of on its side.
Dec 20, 2009 | Pentair White/Gray Legend Platinum...
Nov 03, 2009 | Pentair White/Gray Legend Platinum...
My Pentair Legend Pool Cleaner is too slow
Here is a link to the factory website where they have technical support for this kind of problem.
Legend Pool Cleaner
Feb 23, 2009 | Pentair White/Gray Legend Platinum...
I have a Eurotech EDW154E dishwasher. I keep getting an error code 4. The previous owners said there is a way to reset the machine. Any ideas?
Eurotech Dishwashers are notorious for the E1 and E4 faults. The problem is with the solenoid they use for filling the dishwasher. The problem is something called the "Venturi Effect". The Venturi Effect is the reduction in fluid pressure that results when a fluid flows through a constricted section of pipe. The fluid velocity must increase through the constriction to satisfy the equation of continuity. while its pressure must decrease due to conservation of energy. The gain in kinetic energy is balanced by a drop in pressure or a pressure gradient force. I know, a lot of big words. To put it simply, the orifice within the solenoid is smaller than the inlets and outlets. Even more simply put: Not enough water is getting into the dishwasher. It appears that Eurotech isn't like a simple washing machine that senses fluid level and then shuts off the solenoid. It seems that it's on a simple timer. Turn on the solenoid for X time then turn it off. If not enough water, send fault code. It's a design flaw and I'm not certain there are many ways around it. Just make certain that you have a good water feed to the dishwasher (no kinks, valve on completley etc.). One thing you may try is reducing the feed pressure (i.e. slightly turn down the water valve supply to the dishwasher). Doing so may diminish the venturi effect by equalizing inlet pressure, hence allowing more water into the dishwasher. It's worth a try.
Dec 12, 2008 | EuroTech 24 in. EDW154E Built-in...
Pentair White/Gray Legend Platinum Automatic Pool Cleaner - Ll105pm Logo
91 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
