Question about Garden
Desired oil pressure on john Deere z820a - Garden
jimmy nutron
  • 132 Answers
SOURCE: I have a 1968?? 2020 john deere. The hydraulic
make shure none of your hydrolic cylenders are extended and fill it up till you can stick you finger in there and it barley touches if you do this when cylenders are extended you will over fill it.
Posted on Jun 04, 2009
  • 302 Answers
SOURCE: change oil in riding lawn mower
look at the side of the engine down low. There should be a pipe plug screwed in that has a square head. Put a drain pan under the area and remove this plug and the oil will drain out. It's best if the engine is warm. You should get 1 1/2 quarts of oil out of it. Let it drain for about 5 minutes and then re-install the pipe plug. Add 1 1/2 quarts of 30W oil and then cut the grass !
Posted on Aug 27, 2009
Testimonial: "Thanks. It worked!"
jdlipscomb41
  • 157 Answers
SOURCE: my father in law has a 1980 410d john deere
did they rebuild the hydralic pump and if so they need to do it again and check the valves in it
Posted on Sep 18, 2009
  • 8404 Answers
SOURCE: John Deere 4410 three point hitch will not raise.
Im sorry, I thought you said you changed the oil. My thought was that perhaps the hitch might have bled down during the oil change. That happens occasionally with the tractor I service at work.
I hope you find your trouble. If you could let me know the answer, id appreciate that.
a
Posted on Sep 25, 2009
rwvanlue
  • 486 Answers
SOURCE: John Deere Gx75, kawasaki 9hp motor- oil in carb!
A very common problem with the GX series with Kawasaki engines. The carburetor 'inlet needle' sticks open and fills the crankcase with fuel. When checking the oil, it can be difficult to see the gasoline and the level appears to be OK. Remove the dipstick and smell the oil, you may detect a gasoline smell. Also, drain the oil, and you may find much more fluid than you expect.
The solution on newer mowers was to install an 'in-line' shut-off valve to keep the fuel from syphoning into the carburetor. The inlet needle and seat in the carburetor is NOT replaceable, so a new carburetor is the ultimate solution, but VERY expensive. Installing and using an in-line shut-off valve is more affordable.
Also, this situation is common when machine is transported on a trailer, as the bouncing causes the needle/seat to leak. When transporting, always turn off the fuel supply to the carburetor.
Posted on Nov 08, 2009
Need to locate the oil pressure sending unit on my 300D john Deere backhoe
Looking at engine on oil filter side, the sender is on the left side of oil filter and to the right of dipstick in between both
Dec 15, 2017 | John Deere Garden
Def pressure extremely low on a 848L john Deere Skidder
check for problem pressure relief valve or valves passing oil back to reservoir
Jun 02, 2016 | John Deere Garden
Where do i locate oil pressure sender on a john deere 445
Not sure but if you follow the sure from the oil gauge it should lead to it also match the color coding..good luck..
Feb 28, 2015 | John Deere Garden
What type of transmission does a John Deere Z820A use
look on the ******. the all have a Brand and Model # on them
Aug 04, 2012 | John Deere Garden
I have a John Deere Z820A 25 Horse Kawasaki. After about 45 minutes it acts like it is running out of gas. It will start again with the choke out, but won't run for long. I have replaced fuel...
I am an ex-z820a owner because these machines are terrible. Deere issued a PIP for these motors and maybe yours has not beed done yet. The best thing to do is get with a dealer see if the PIP has been completed then sell as fast as you can. I traded my z820a on a z920a and couldnt be happier.
Jul 26, 2011 | John Deere Garden
We fixed an engine of john deere 3020 diesel model 1966. All things it's ok. We took a watch which pressure the oil engine instead of the short lamp. When the engine is working and is cold, the pressure is...
I have been working on the my John Deere 3020 and can not get it to start. I had the starter rebuilt and have gone through everything I can think of! Any help would be great
Feb 18, 2011 | John Deere 3020 Gas & Diesel Tractor...
Need to locate the oil pressure sending unit on a John Deere 1010 Gasoline tractor
looking at engine on oil filter side--the sender is on the left side of oil filter and to the right of dipstick in between both
Mar 03, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
