Question about Cannon Kitchen Ranges
Whole unit keep tripping when electric is switched on
    Problem Solver:
  • 5 Answers
Water ingress to regulator needs to be replaced
Posted on Mar 04, 2015
My Bonaire evap cooler keeps tripping the fuse when I turn it on
there is an electrical short in the unit that is causing the fuse / breaker to trip
could be insulation, moisture in a junction connection or failing motor
Call in an accredited electrician to find / fix the fault
Mar 12, 2016 | Dryers
Why when plugged in to my electrical sockets it keeps tripping out my electrics.
Either Faulty , or the unit power is to much for the electic cable / system. Always when power trips out , it's to do with the unit you have plugged in, (ie ) If it's a 3 kilowatt fire, this will trip unit as unit very sensitive
Mar 07, 2015 | Heating & Cooling
Goodman gms90703bxa tripping overheat limiters, keeps flashing 6 times, open roolout
When unit come on you need to watch the flames that shooting in all should blue. If there is any red flame kick out that would trip the flame role out switch. If the is the case you need a need heat exchanger.
Feb 09, 2015 | Goodman GMS90703BXA Heater
My kettle keeps blowing the circuit
If the fuse in the mains plug or MCB at the consumer unit / fuse box keeps tripping then there probably is a fault in the kettle element or switch. If the RCD is tripping (the safety device with the test button on it) then there is an electrical leak either due to a crack in the element or water has got into the wiring, switch or power cord of the kettle.
Allow the kettle to dry out in a warm place for a day. Also check it at another power outlet to eliminate any problem with the outlet you are using.
May 28, 2011 | Dualit 72300 Stainless Steel Cordless...
Have a mira sports shower. when i turn on at isolated switch light comes on but when i turn on shower light goes out. no sound of water coming to unit or electrical sound in unit.
Have you checked if when turning on the shower water the electrical trip switch turns off at the fuse board. If the shower does keep tripping the RCD then the shower is the problem.
Apr 01, 2011 | Home
I have just had a saniflo installed. When I put the power on it knocks the trip switch on the box straight off.
That means that somehow water got inside the pressure chamber which is where all the electrical components are, if it senses water it will trip the GFI and the unit will shut off completely. You may have to replace the whole pressure chamber since water may have corroded the electrical components.
Mar 02, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
Keeps tripping my electrical circuit. have the G1100 model. Any ideas? checked for leaks, socket works fine.
The unit is shorted out internally.... the element either has too much build up on it or it has warped and is touching the sides grounding it out...
I think that element may be replaceable... or you will need to replace the whole unit...
heatman101
Jan 31, 2011 | Emerson InSinkErator W-152 Hot Water...
Carver 5500 turbo fanmaster keeps blowning the
its sounds like you have a sort some where, if you have a compressor , or the heater element could be bad? slide heater out to see if there is a burnt wire
Apr 11, 2010 | Heating & Cooling
Our miele condenser dryer with the miele washing machine will often trip the whole house's electricity. Sometimes it will trip on the house circuit board. while other times it trips the external trip...
have the neutral power connection on that circuit and back to the main house panel and then have the neutral connection checked at the power companies side also, it sounds like you have a high resistance neutral connection somewhere in the circuit and its looking for another return path due to the high resistance on the line to another feed circuit line to make connection
Dec 07, 2009 | Miele Novotronic T220 Electric Dryer
Blown accessory fuse? jenn air cooktop jed8430adb
the unit doesnt have any internal fuses. you have a house fuse blown or circuit breaker that tripped. the fan switch can be found online or from your local parts house and make sure you get the clips to hold it to the mounting tabs.
next time you get ready to work on it, just make sure and turn off the power first as you will touch the metal terminals to the frame again.
Dec 27, 2008 | Jenn-Air JED8430 Electric Cooktop
Kitchen Ranges Logo
59 people viewed this question
Top Cannon Kitchen Ranges Experts
Paul Carew
reyaazm
Level 1 Expert
Tom Chichester
Are you a Cannon Kitchen Range Expert? Answer questions, earn points and help others
