Question about Air Tools & Compressors
Need assembly diagram for fenwai f 10 - Air Tools & Compressors
Searching for fenwai pressure control fw 10
If your compressor is a piston compressor, try cleaning the check valve which comes from the pressure switch to the tank (it has a little spring and a rubber/plastic valve inside)
Otherwise check to see if it is sucking air in properly, (whilst it is running, remove the air filter, and very quickly put your hand over the air intake to see if it is sucking whilst it is at 20 psi, if not, then it may be that the valves in the head maybe either broken or not seating properly
If it is not a piston compressor, then it maybe the MPV needing some attention
Hope that helps
Aug 22, 2012 | Air Tools & Compressors
Xerox 4150 workcenter says fuser module needs to warm up. This appears usually first thing in morning. I have to power off then on to stop this from showing on the screen. also, it wont print until after I...
1. Switch off the machine, then switch on the machine.
2. Enter dC330 code 10-100 to heat the fuser to 180 degrees. Enter codes 10-200 (centre
thermistor) and 10-210 (front thermistor) to verify the condition of the thermistors.
3. Enter code 10-300 to check power supply unit 2. If necessary, install a new power supply
unit 2, PL 1.10 Item 4.
4. Switch off the machine. Remove the fuser assembly. Check that the thermistors, PL 10.25
Item 9 are clean and in good contact with the fuser heat roller. Check the wiring to the
thermistors. Install new components as necessary, PL 10.25.
5. Check for continuity between the two pins on the fuser assembly connector, PL 10.25
Item 8.
NOTE: A cold fuser has a resistance of approximately 11.5 ohms (220V/240V) or 2 ohms
(110V).
6. Check that there is continuity through the fuser heater and across the over temperature
cut-out.
7. Check the wiring between the fuser connector, PL 4.15 Item 20 and CON3, CON8 and
CON9 on Power Supply Unit 2. If necessary, install a new fuser connector, PL 4.15 Item
20.
8. Check the wiring between CON4 on Power Supply Unit 2 and CN7 on the Main PWB.
9. Install new components as necessary:
• Fuser assembly, PL 10.25 Item 1.
• HVPS, PL 1.10 Item 2.
10. Perform the OF5 Main PWB Check RAP.
4250/4260 Checkout
NOTE: The main PWB has test points. The location of the test points is shown on the Main
PWB PJ location illustration.
Refer to Wiring Diagram 17, Wiring Diagram 18 and Wiring Diagram 21. Perform the following:
unit 2, PL 1.15 Item 4.
4. Switch off the machine. Remove the fuser assembly. Check that the thermistors, PL 10.28
thermistor assembly. Check the wiring to the NC thermistor, PL 10.28 Item 19. Install new
components as necessary, PL 10.28.
5. Check for continuity between the three pins on the fuser assembly connector, PL 10.28
Item 8.
(110V).
6. Check that there is continuity through the fuser heat lamps and across the over temperature
cut-out. Install new components as necessary, PL 10.28.
7. Check the wiring between the fuser connector, PL 4.15 Item 20 and CN5 on the Main
PWB. If necessary, install a new fuser connector, PL 4.15 Item 20.
8. Check the wiring between CON1 on Power Supply Unit 2 and CN7 on the Main PWB.
• Fuser assembly, PL 10.28 Item 1.
• Power supply unit 2, PL 1.15 Item 4.
May 10, 2012 | Xerox WorkCenter 4150 Black and White...
I have central pneumatic 21 gal. air compressor. The unloader valve is broke. The power switch is a fenwai model: fw-10. Where can I buy a new unloader valve?
If you should mean the switch that is pressure controlled that turn the compressor on and off- that is a fairly universal replacement piece, As is the power switch itself
If you needed that specific part, your best bet is Harbor Freight tools who owns the Central Pneumatic domain.
Feb 14, 2012 | Air Tools & Compressors
I need a wiring diagram for a 1998 Chevy Blazer fuel pump
The fuel pump assembly consists of fuel pump relay,fuel sensor,the fuel pump controlling fuse,its ECM B fuse. The fuel pump and oil pressure switch. ----------- For its wiring diagram, click the link below and refer the diagram:--- http://technoanswers.blogspot.com/2011/10/fuel-pump-wiring-diagram-for-1998-chevy.html ----------- This should help.Thanks.Helpmech.
Oct 06, 2011 | 1998 Chevrolet Blazer
I need to find a picture which lable the bottles under the bonnet as one on them is on the min level and i dont no what it is?
Ford Focus engine diagram3242134_f260.jpg Ford Focus engine diagram - Ford Focus engine Zetec-E 1,8-2,0 l 16V Ford Focus engine diagram - Ford Focus engine Zetec-E 1,8-2,0 l 16V
1 - a tank of the hydraulic booster of a steering; 2 - a plug mouth oil-jellied; 3 - a tank of a working liquid of a braking system and clutch; 4 - the assembly block of safety locks and the relay; 5 - an air filter; 6 - a windshield washer reservoir; 7 - the accumulator battery; 8 - the identification tablet; 9 - a measuring instrument of level of oil; 10 - an expansion chamber of system of cooling.
Ford Focus engine diagram3242159_f260.jpg Ford Focus engine diagram - turbo-diesel of 1,8 l Endura-DI Ford Focus engine diagram - turbo-diesel of 1,8 l Endura-DI
Mar 28, 2011 | 2004 Ford Focus
Front right hub and sensor assembly or a diagram
Removal Steps
1. Torsion bar
2. Wheel speed sensor
(if equipped with ABS)
3. Back plate
4. Lower ball joint
5. Upper ball joint
6. Knuckle assembly
7. Oil seal
8. Thrust washer
9. Needle bearing
10. Knuckle
Installation Steps
10. Knuckle
9. Needle bearing
8. Thrust washer
7. Oil seal
6. Knuckle assembly
5. Upper ball joint
4. Lower ball joint
3. Back plate
1. Torsion bar
Mar 01, 2011 | 1999 Isuzu Trooper
Heater keeps shutting off what could it be cant find manual to help
Use this manual to assist you in troubleshooting. http://www.bealsmotor.com/Desa%20Hot%20Surface%20Manual.pdf
The manual will help you isolate the problem.
Things than can cause your symptoms:
1. Pump pressure incorrect
2. Dirty air intake, air output
and/or lint filter
3. Dirty fuel filter
4. Obstruction in nozzle
5. Photocell assembly not properly
installed (not seeing the flame)
6. Dirty photocell lens
7. Bad electrical connection between
photocell and ignition
control assembly
8. Defective photocell
9. Defective ignition control
assembly
10.Line voltage is below 108V or
above 132v
REMEDY corrosponds with 1 - 10 above
1. Fill tank with kerosene
2. See Pump Pressure Adjustment,
page 10
3. See Fuel Filter, page 11
4. See Nozzle Assembly, page 12
5. Drain and flush fuel tank with
clean kerosene. See Storing,
Transporting or Shipping,
page 7
6. Check electrical connections.
See Wiring Diagrams, page 16
7. Replace ignitor, see page 11
8. Replace ignition control
assembly
9. Check for proper line voltage
1. See Pump Pressure Adjustment,
page 10
2. See Air Output, Air Intake and
Lint Filters, page 10
5. Make sure photocell boot is
properly seated in bracket
6. Clean photocell lens
7. Check electrical connections.
8. Replace photocell
9. Replace ignition control
assembly
10.Check for proper line voltage.
Disconnect power equipment
that may be used on same
line
Thanks for choosing FixYa,
Kelly
Jan 09, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
Need diagram of how the LH inside door panel is removed 1996 S-10
Consult a chiltons or haynes repair manual. May review the layout assembly under applicable year model from lmctruck.com
Jan 15, 2010 | 2002 Chevrolet S-10
I need a free diagram for 93 chevy blaizer frint
please contact me at chevy4x4k1500@aol.com and I will print and fax you a copy just give me the last 8 of the VIN and a fax # or call jason @ GENERAL TRUCK SALES at 800-382-7717.
Jul 30, 2009 | 1993 Chevrolet S-10 Blazer
Air Tools & Compressors Logo
57 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
