Question about Car Audio & Video
I have a 2000 mitsubishi 2.4 code 400 comes up how i fix this
My mitsubishi lancer cedia wagon wont let me rev above 2000 rpm and stalls afterwards it jerks down the road when driving iv cleaned the fuel filter what could the problem be
it is in limp mode because of a problem either in the engine or transmission
run the fault codes and fix the codes that come up
Jul 30, 2016 | Mitsubishi Cars & Trucks
I need to Get the authorization code for this software that my wife got for me in 2002? It's autocad LT 2002 serial #341-88732540. Key#HQZ3U6. Any help would be appreciated. I've tried registering it...
Autodesk AutoCad 2000 serial: 112-11111111
cdkey: 5X8NUG
Autodesk AutoCad 2000 Educational serial: 111-11111111
cdkey: GX8NUG
auth: FFD54A5A
Autodesk AutoCad 2002 Serial #: 400-12345678
cd-key : T4ED6P
Autodesk AutoCad Data Exchange 2000i 400-12345678
Autodesk AutoCAD Land Development Desktop Release 2i s/n: 400-12345678
cd-key: T4ED6P
Autodesk AutoCAD LT 2000 serial: 110-98539662
cdkey: 2ZC3DJ
Autodesk AutoCAD LT 2000i serial: 400-12345678
cd-key: T4ED6P
Autodesk AutoCAD LT 2002 s/n : 400-12345678
cd-key : T4ED6P
Autodesk AutoCAD Map 2000i serial: 400-12345678
cd-key: T4ED6P
Autodesk CAD Overlay 2000 s/n: 110-98539662
cd-key: 2ZC3DJ
AuthCode: 08BB785
Autodesk CAD Overlay 2000i serial: 400-12345678
cd-key: T4ED6P
Autodesk CAD Overlay 2002 serial # : 400-12345678
cd-key : T4ED6P
Autodesk Civil Design Release 2i serial: 400-12345678
cd-key: T4ED6P
Auth : no requiere
Autodesk Civil Design 3.0 serial # : 400-12345678
cd-key : T4ED6P
Autodesk Land Development Desktop Rel. 2 Serial #: 400-12345678
CD-KEY : T4ED6P
Auth : no requiere
Autodesk Land Desktop 3.0 serial # : 400-12345678
cd-key : T4ED6P
Autodesk LightScape name: EzD
company: PWA
s/n: 700-15158000
code: 6A147AF9
Jan 31, 2015 | Autodesk AutoCAD LT 2002...
Engine light code P0400
Code 400 is for a problem with the EGR valve gas flow or the flow sensor.
Jan 16, 2014 | 2000 Mitsubishi Montero Sport
What transmision does the Taurus have
that depend on a few things .like what do you have andF}}}400}1086932" CHECKED="" type="radio">A.T., (6-183, 3.0L), DOHC (VIN S), (AX4N), col shift
A.T., (6-183, 3.0L), DOHC (VIN S), (AX4N), floor shift
D}}}400}1086934" type="radio">A.T., (6-183, 3.0L), OHV (VIN U, 1 or 2), AX4N (code X), col shift
E}}}400}1086935" type="radio">A.T., (6-183, 3.0L), OHV (VIN U, 1 or 2), AX4N (code X), floor shift
C}}}400}1086936" type="radio">A.T., (6-183, 3.0L), OHV (VIN U, 1 or 2), AXODE/AX4S (code T or L), col shift
A}}}400}1086937" type="radio">A.T., (6-183, 3.0L), OHV (VIN U, 1 or 2), AXODE/AX4S (code T or L), floor shift
Jan 01, 2013 | 2000 Ford Taurus
2000 Mitsubishi Eclipse Problem TCL
2 concern for you when check engine light comes on your TCL (traction control) is disabled,so you get the light,and if TCL is disabled so is the ABS (anti lock brakes) you first step is get the Check engine light code,If it was just a TCL light on the ABS code will need to be gathered,You need a scan tool
Dec 08, 2012 | 2000 Mitsubishi Eclipse
Tv wont trun on
That's error code 23. The manual says that is loss of horizontal deflection. Maybe shorted-out Hor. Out. transistor, but it should be looked at by a shop if you're not a technician. probably at least $200, may be $400 for them to fix.
Apr 21, 2010 | Mitsubishi WS-65611 65" Rear Projection...
Mitsubishi WS-55859 power light comes on and then goes off.
I get an error code of 2- 2 x 10 etc Ten times I saw two blinks of the on light. I had a power relay replaced in the year one ,fixed it.then. what do I do now to fix it. What part would you replace thanks.
Dec 22, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi Mirage PO 400
Here are the possible causes for a PO440 code:
EGR valve source vacuum supply line is open or restricted
EGR exhaust tube is clogged or restricted
EGR valve assembly has failed
PCM has failed
Please let me know if this information is helpful. Positive feedback is appreciated. Thank You!
Mar 20, 2009 | 2000 Mitsubishi Mirage
Car Audio & Video Logo
41 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
