Question about Dishwashers
GE Potscrubber 650 does not drain and top rack not washed
I have 2 new issues that have happened back to back in the last few weeks. First the top rack was not being cleaned at all. Glasses and cups looked caked with residue from the soap or just the dirt. Now a new problem is more pronounced and that is the water in the tub is not draining. I checked my garbage disposer and it does not have any clog on it. I started a few rinse only cycles but the same 2 problems persist. Matter of fact the water level appears to be much higher than before.
  • bifidus Jun 25, 2009
    I took out the plastic food catcher at the base of the tub. It had a layer of food residue caked on the upper surface as it sits in the tub. You can't poke that stuff away. Only option is to remove the two nuts holding this basket down. Clean it out thorougly and place it back on. This fixed my problem! I was worried about the unit still connected to the power though while I was doing the unscrewing of the two nuts but thankfully nothing happened.
    Sergeant:
  • 212 Answers
Your not draining the washed dirty water out. its leaving crud on dishes. check drain pump and drain line for restrictions
Posted on Jun 22, 2009
How do you remove the sprayer arm from a GE potscrubber 600
Thought I had a problem with the spray arm or pump because water was not flowing enough to spray the upper rack. But it turned out it was a simple part missing: the "check valve" that is in the lower neck of the spray arm assembly. It's a $10 part. Part #WD1X5488 for GE Potscrubber 600.
May 20, 2013 | Dishwashers
Ge potscrubber 650 Dishwasher is humming when turned on and will fill but not wash and drain
This happens when the DW goes unused for a while. The motor is stuck. Open up the lower panels and move the Motor Fan by hand until it moves freely. This worked for me until a seal broke.
Freeing the motor may break the seal between the motor and pump assembly. I'm in the process of replacing that now.
Check for leaks by running the DW before putting the lower panels back on.
Aug 14, 2010 | Dishwashers
Amana ALW480DAW top load washer 9 yr old
You're not done yet. The washer pump probably is leaking. Lots of basements being pumped out in this area as a result of the snow.
Jan 16, 2018 | Amana ALW480DA Top Load Washer
Washing machine quits after filling
I believe you need a new belt. The weight of the water is to much for a loose belt that is connected to the agitator.
2. Make sure nothing is blocking the safety shut off located on the machine.
Jan 19, 2009 | Washing Machines
Ge WASE4220A0ww will not drain or spin
hI!!! You seem to have a bad transmission or a bad motor they are all expensive to repair..Good luck..
Jan 03, 2009 | GE Profile WPRE6100G Top Load Washer
Grinding/Rubbing noise?
the unit has a "food chopper" inside the pump sump. it is to chop up "food" items and not bones, seeds or other items. you can keep running the unit and see if after 2 or 3 loads the noise goes away. ie: the item get chopped up small enough to go out the drain.
if it doesnt go away, then you will need to get into the wash pump and see what is stuck in the sump.
its not hard to take apart and you will find whatever shouldnt be in there.
Dec 29, 2008 | Dishwashers
GE Washer
have they checked the door lid switch?..it could be intermittent also because if the switch is not close, it would not drain and spin anymore. try to bypass the switch temporarily by shorting it out then use it . becarefull because you can now open the door while it is spinning ad it is very dangerous.
Feb 17, 2008 | GE WPRB9110WH Top Load Washer
Dishwashers Logo
770 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
