Question about Pride Sundancer 3 Wheel Electric Scooter
How to remove back seat on a 2004 cadillac cts
What kind of tool do i need to remove the front seat in a 2004 cadillac cts
enter this in your web browser
"how to cadillac remove seat"
Oct 07, 2014 | 2004 Cadillac CTS
How to 2007 cts seat removal
the rear seat lifts up in the front if you pull up quickly on each side the snaps will let go. the front seat has 4 bolts in it.
Jun 21, 2014 | 2004 Cadillac CTS
Removing an alternator from 2004 cadillac cts
buy a service manual , dont break the heater bypass valve either
Mar 30, 2013 | 2004 Cadillac CTS
How to remove front seat back 2010 cts
Remove the front and rear trim covers over the four bolts that hold the seat to the floor, then go under the seat and disconnect all the wiring being careful not to break any of the connector locking tables.
Jul 12, 2012 | 2010 Cadillac CTS
Driver seat removal
Yes. There should be 4 bolts and up to 3 wire connectors.
Jun 02, 2012 | 2003 Cadillac CTS
Fix heated driver seat on 04 cts
The #1 cause of the heated seat not working is that the heating grid is defective from all the 1000's of times it is flexed when you sit in it. To replace the grid requires the seat be taken apart and the seat cover removed, this takes skilled hands and some special tools to get done right, it is a job best left to an auto trim shop that does upholstery work
Feb 10, 2012 | 2004 Cadillac CTS
My cadillac cts 2004 airbag service warning light is on,can anyone tell me how to reset it. I would appreciate if anyone helps me.
You will need a professional grade scan tool to reset the light.You will need to repair the cause of the light , the failure that set the code.
Feb 12, 2011 | 2004 Cadillac CTS
What size fuze for the radio in 2005 cadillac cts
The driver's side rear fuse block is located under the rear seat on the driver's side of the vehicle. The rear seat cushion must be removed to access the rear fuse block. See "Removing the Rear Seat Cushion" listed previously.
To access the fuse block, push in the two tabs located at each end of the fuse block cover. Then lift the cover off...
From owners manual.
Feb 05, 2011 | 2004 Cadillac CTS
Describe how to remove rear seat in a 2006 cadillac cts
You Must PUSH DOWN and IN (TOWARDS REAR) At the area that the Back of your Knee's are when Sitting in the seat do this on BOTH Sides of the seat, the Back Part of seat has 2 TORKS BOLTS at the Bottom of the seat
Dec 26, 2009 | 2006 Cadillac CTS
Need to know where my fuel pump relay is located under my hood and what it looks exactly like so i know im pulling out the right relay in my 2004 cadillac cts
it is located under the rear seat on the right hand side... on both ends of the fuse block are the fuel relays
robert
Please take a moment to rate this solution
Feb 22, 2009 | 2004 Cadillac CTS
Pride Sundancer 3 Wheel Electric Scooter Logo
23 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
