Question about Malibu ML200RT - Low Voltage Power Pack -200 Watt - With Timer - Plastic Ho
Malibu ml200rt internal wiring schematics
I have an ML200rt Malibu transformer and it fell from where was attachedc and the internal wires came out.
I opened the transformer and cannot tell where the black and white wires that feed the ac are connected internally.
Des anyone have a diagram of the intenal connections?
    President:
  • 1,723 Answers
If you have a meter you can test for 12 volts AC on the output of the transformer. They go to terminals
A & B
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jun 26, 2009
  • Malibu Master
  • 5,245 Answers
Open following link for Malibu troubleshoot resourceshttp://waterheatertimer.org/Malibu-power-pack-stopped-working.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on May 19, 2012
Intermatic ML200RT transformer Manual & Guide
All manuals are put together, along with troubleshooting, and installation tips on following link:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#manual
Gene
Water Heater Timers Save Money
May 25, 2014 | Intermatic Hardware & Accessories
Dusk to dawn sensor for 24 v light system
Malibu transformer is 12 volt AC
They make a photo eye for ML300-600-900 watt units, but not for 75-100 watt units
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#wire
Gene
Oct 04, 2013 | Malibu ML200RT - Low Voltage Power Pack...
Lighting transformer and wiring
Open following link for ML200 and other models of low-voltage transformer timers, for instructions, wiring, tips and troubleshoot:
Jun 22, 2012 | Malibu ML200RT - Low Voltage Power Pack...
Where do the wires go to a b c for a ml814drp phote eye
When wiring photo-eye to power pack, the wiring is changed from what shows in power pack manual:
Open following links for power pack resources:
http://waterheatertimer.org/pdf/Intermatic-malibu-photo-eye.pdf
Photo-eye manual shows correct wiring:
Photo-eye: Solid-black-wire to A, red-wire to C, middle-wire to B.
Lights: wires to lights are moved to terminals B and C
Jul 21, 2011 | Intermatic 200W Power Pack With 12v...
Shorting out
That is not really enough information: shorting out. If you disconnect all loads (wires) and it is "shorting out" then it is internal. If it shorts out only with wires attached then you have a short somewhere in that wiring
Jan 23, 2011 | Malibu ML200RT - Low Voltage Power Pack...
How do I connect the LV814PR Malibu remote photo control to the ML200RT Power Pack?
To connect the Malibu LV814PR photo control to the Malibu ML200RT:
On the bottom of the power pack you should have 3 terminals: A, B, and C. The trick to understanding how the photo control is connected to the power pack is to understand that the "C" terminal on the power pack is a "dummy" terminal. It is _not_ connected to the transformer in _any_way. It serves the same basic purpose as a wire nut, it's just a connection point.
To avoid confusion following these instructions, disconnect your existing wires from the lights to the power pack. (they should already be under terminals A and B.
To connect the photo control:
1...Connect the outside solid black wire from the photo control to the "A" terminal on the power pack.
2...Connect the center wire from the photo control to the "B" terminal on the power pack.
3...Connect the red striped wire on the photo control to the "C" terminal on the power pack.
4...Now reconnect the lights, except this time connect one wire from the lights to the "B" terminal (along with the center wire from the photo control) and the other wire from the lights to the "C" terminal (along with the red striped wire from the photo control).
Alternatively, one could not even use the "C" terminal and just connect those 2 wires with a wire nut. Kinda messy, hence, the reason for the "C" terminal.
If you want to have the lights on from dusk to dawn, remove both the red and black trippers and turn the manual switch to ON.
If you want the lights to come on at dusk and OFF at, say, Midnight, put the black tripper at Midnight.
Enjoy your lights.
May 20, 2010 | Malibu ML200RT - Low Voltage Power Pack...
Where you connect the electrical cord from a fount into the timer
The Malibu ML200RT is intended to operate _12_ volt AC (low voltage) lighting _only_.
Assuming your fountain pump is 120 volts, the needed set up would be to supply 120 volt circuit to an Intermatic T101 timer (or similar timer), then connect a GFCI receptacle to the load side of the timer. You could then plug your fountain pump into the now timer controlled GFCI receptacle.
You can use the same 120 volt circuit that supplies the ML200RT transformer.
Mar 27, 2010 | Malibu ML200RT - Low Voltage Power Pack...
Malibu ML200RT - Low Voltage Power Pack -200 Watt - With Timer - Plastic Ho Logo
1,535 people viewed this question
Top Malibu Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Rob Sinbad
Rob Sinbad
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
