Question about Odif Usa 505 Spray & Fix Temporary Fabric Adhesive-11.7 Ounces
505 fabric adhesive hands - Odif Usa 505 Spray & Fix Temporary Fabric Adhesive-11.7 Ounces
  • 94 Answers
You can try Goo Gone (Home Depot, etc.) or nail polish remover.
Posted on Jul 14, 2014
How to remove fabric glue (505 Adhesive) from fabric
Petrol (with great care), Isopropyl Alcohol will work.
Jul 14, 2017 | Cars & Trucks
How to attach canvas top to tailgate
if there are no connectors made into either part, use velcro strips like some outdoor winter clothes have on them..use the nonstick (smooth) part on the metal gate and the rough side onthe fabric top..these are self sticking adhesive backed but they can be glued on both places also.. good luck// velcro strips can be glued on the metal with weatherstrip adhesive and the fabric side can actually be sewed in place if desired..once its done its done too...
Jan 22, 2013 | 1996 Geo Tracker 2 Door
The headliner has come down from the roof...how can i fix it???
you can purches some spray adhesive from your local auto parts store and spray the adhesive on the head linner
Dec 09, 2011 | 1989 Chrysler New Yorker
How do I fix the fabric on s type windshield post?
I had same problem and for an upmarket car it should not happen, but it does, I assume the fabric has come away from the plastic, if so, remove the trim, this is done by pulling the door rubber away from the trim , grasping the trim at the top and gently pulling towards the centre of the windscreen, once the top is free ,pull upwards and its free. The only option now is to remove the fabric completely ( trying to glue it back down will not work) search around fabric shops with the original fabric and purchase as close a match as you can. The next step can be tricky, but with patience a good job can be done. I used very thin double sided sticky tape and covered the trim completely, then with a lot of dexterity covered the trim with the new fabric, taking care to overlap the fabric onto the inside of the trim, this makes for a more secure fit. Hope this helps.
Jul 29, 2010 | 2001 Jaguar S-Type
How munch for a head line
Headliner you mean? Do it yourself. You can buy the thin foam underpad, & spray adhesive on it, then material chosen from a fabric shop. Scrape old stuff off good, spray adhesive on cardboard like headliner, apply foam, then spray foam good, and apply fabric, let it cure overnight, wrap material around to back side, and put back in place. Follow directions on adhesive, and make sure it's o.k. (compatible) on foam & material.
Aug 08, 2009 | 2003 Dodge Dakota Club Cab
Convertible rear window separated from fabric top
This problem is very common and is known as delamination.
Use Urethane adhesive to reglue the window.
This same adhesive is used to install windshields.
The hard part will be to hold the window in place till the Urethane cures.
Prepare for that in advance.
Karl at Topgunwon.com
Mar 20, 2009 | 1997 Toyota Celica
Embroidery machine patterns are not consistant
I'm just beginning to work with my machine, but I have had a similar issue. Some of the possible solutions that I have found include (note: I've tried #1, I will try 2 and 3 soon)...
1. use stabilizer fabric.
2. if you're using tear-away stabilizer, and it is tearing prematurely, try a cut-away stabilizer (or maybe iron-on stabilizer?).
3. if you're embroidering on fabric like fleece, try 'hoopless embroidery' This involves using adhesive stabilizer - put the stabilizer in the hoop with no fabric, (if you don't have adhesive stabilizer, use regular stabilizer and spray it with a craft adehesive) then lay your fabric over the hoop and press the fabric onto the adhesive.
good luck.
Dec 17, 2008 | Brother SE-270D Computerized Sewing...
Top thread bunches under the fabric
check that the stitch setting is correct for the type of stitch you require, also make sure the thread tension is tight enough, get a piece of rag and alter the tension till it goes right.
Check that the spool bobbin is feeding the thread correctly from underneath and that there is no trapped thread clogging the spool mechanism
kind regads
Dec 13, 2008 | Singer HD-110 Mechanical Sewing Machine
Odif Usa 505 Spray & Fix Temporary Fabric Adhesive-11.7 Ounces Logo
238 people viewed this question
Top Odif Usa Adhesives, Coatings & Sealants Experts
David Payne
David Payne
Richard Piatek
Richard Piatek
 perry tradesman    ...
perry tradesman ...
Level 1 Expert
Are you an Odif Usa Adhesive, Coating and Sealant Expert? Answer questions, earn points and help others
