Mitsubishi wd 62527
My Mitsubishi wd 62527 makes a grinding noise but picture is ok
    Master:
  • 688 Answers
Possibly the color wheel which is not available, you have to go with the optical engine which is part#: 938P015020
This would make repairs UNECONOMICAL
OR any one of 5 fans:
Chassis fan & Lamp fan: 299P288010 $20.00
http://www.shopjimmy.com/catalogsearch/result/?q=299P288010
PBS fan: 299P296010
Ballast fan: 299P287010 $25.00
http://www.shopjimmy.com/catalogsearch/result/?q=+299P287010
L/V fan: 299P295010 $27.00
http://www.shopjimmy.com/catalogsearch/result/?q=299P295010++
Posted on Jun 05, 2014
3 Suggested Answers
  • 115 Answers
SOURCE: Screen Removal - Mitsubishi WD-62527
SPEAKER GRILLE Removal
Pull the SPEAKER-GRILLE away from the cabinet to remove.
SCREEN-ASSY Removal
1) Remove 10 screws (a) from the upper cabinet rear cover (3 screws on each side and 4 screws across the
top).
2) Remove screws (b) along the bottom of the SCREEN-ASSY (8 screws on 52 inch models, and 12 screws
on 62 inch models),
3) Unplug the LL connector to the front CONTROL-PANEL.
4) Lift the SCREEN-ASSY up slightly and then pull away from the cabinet.
CABINET FRONT DISASSEMBLY
Posted on Sep 28, 2009
Slinteriors
  • 8617 Answers
SOURCE: mitsubishi wd 62527 has very dark picture changed
Clean the small front projection mirror. That mirror can get dust on it and will cause the projected image to appear dull and dim and cleaning that mirror will usually restore the brightness and crisp details in the image.
Posted on Oct 23, 2010
Mitsubishi wd 62527 makes a grinding noise but the picture is ok
possibly 1 of the fans has noisy bearings.
chassis & lamp fans pt# 299P288010 $19.95@ http://www.shopjimmy.com/catalogsearch/result/?q=299P288010
PBS Fan pt# 299P296010 $65.83 http://www.tvserviceparts.com/cgi-tvserviceparts/sb/productsearch.cgi?storeid=*20aab4584c1a864062e01c3c70e68e24afb3&search_field=299P296010&search_submit.x=29&search_submit.y=12
Ballast Fan pt# 299P287010 $27.95 http://www.tvserviceparts.com/cgi-tvserviceparts/sb/productsearch.cgi?storeid=*20aab4584c1a864062e01c3c70e68e24afb3&search_field=299P287010&search_submit.x=29&search_submit.y=5
L/V Fan pt# 299P295010 $55.13 http://www.tvserviceparts.com/cgi-tvserviceparts/sb/productsearch.cgi?search_field=%20299P295010
otherwise color wheel bearings going out and is not available, must get complete light engine
pt# for WD-62527 938P015020 $629.66
http://www.tvserviceparts.com/938P015020.html
Economically the fans are not too bad, but the light engine would not be cost effective.To determine which fan may be causing the noise, you just have to listen closely to tell which one. or replace all 5 fans for a total of $188.81. you might want to replace the unit with a New LED TV. Replace TV is my recommendation. This unit is too old & antiquated to put this kind of money into it!!
May 06, 2014 | Televison & Video
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Sounds like the fault with its back-light inverter board. Contact any service technician.
May 06, 2014 | Mitsubishi WD62527 62 in. LCD HDTV
Mitsubishi wd 62527
hello there it could be a loose connector that u may have disturbed or broken look again inside if it worked before with
sound the chances are its ok
Jan 21, 2018 | Televison & Video
Picture but no volume
I went to menu then press net command and press audio then enter. Then I press the arrow up on the adjust key and switch it from AVR to TV/Video.
Jan 06, 2010 | Mitsubishi WD-65731 65" HDTV
SCREEN-ASSY Removal
top).
on 62 inch models),
Aug 01, 2009 | Mitsubishi WD-65735 Television
Blue clouds in the screen of a Mitsubishi WD-62527
i have had similar problems before for me it was caused by a strong magnet on the floor below me. i suggest looking around for a strong magnet that could cause the problem
Jun 06, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Tv 62527 light goes off when after a few seconds when turned on
This is generally a Power Supply problem, usually the SMPS so it's replacement or repair.
Jul 15, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
