Question about Mobile Systems Android Apps
Why wont myandroid wont let me put a ownerd name
Wrong Last Name placed
Just create a new user account. Then delete the one with the wrong name, when you do this it will ask you where you want the files from the old account, you just tell windows to put them in the new account, all set.
Jun 01, 2014 | Dell Computers & Internet
Can i use myandroid as the screen to my laptop that has broken screen
There are a few apps out there like AirDisplay that can be paired with software you put on your computer to do this. I am not aware of any that allows for direct connection by USB by seems plausible. Unfortunately you need to set up a couple things on your laptop first, and need to be connected to the same network. I would recommend either buying a very cheap lcd screen on craigslist (I bought a 17" flat panel for $25 once and it functioned nicely) as a temporary solution or perhaps borrow someones screen to get the software installed on your laptop and then use something like AirDisplay. Alternatively you could buy the screen off eBay, and install it yourself or have someone install it for you.
Sep 04, 2013 | Computers & Internet
My jeep will not start burn out a fuse put one in and steal will not start what can be wrong
name the fuse. or point a finger at it, there are many fuses.
we can not guess. this.
post a photo or name the fuse.
wont crank or wont start, all cars need to crank first.........
or in my case, push started, or all cars jumper cable started.
Aug 26, 2013 | 2004 Jeep Liberty
How to install toshiba tgo1 mobile in android 2.2
Ok its just been hacked recently so your phone is lucky !
Ok DOWNLOAD the ANDROID here
AND FOLLOW MY INSTRUCTIONS
For those who want to try himself.
1st. Download from Markinus posts his repository it's on the right side on the page http://gitorious.org/linux-on-wince-.../linux-on-tg01
2nd. Unzip it in a folder that you have created before. How to unzip it?
Go to Applications -> Accessories->Terminal
In Terminal tap: cd name of your new folder, ( example: cd myAndroid )
then you have myAndroid$
Now you tap : tar xvzf directory where you have download Markinus repository. (example: tar xvzf /home/downloads/linux-on-wince-htc-linux_on_wince-htc-linux-on-tg01.tar.gz.gz)
You will see how the file is unziped.
3rd. You will see in your folder that there is a new folder named (linux-on-wince-htc-linux_on_wince-htc-on-tg01 or something like that). If you see like a small lock in the front of this folder then do this. Create a new folder put the name you want. Then cut everything from the folder linux--on-wince-htc...........etc. and past it in your new folder.
(example what I did it was easy just in my folder myAndroid I create a folder kernel_1 and I paste everything inside.
4th Now wen we have not everything but may be a part of. Is time to download toolchan (compiler) and some libraries.
in your Terminal tap : apt-get install git-core gnupg flex bison gperf build-essential zip curl zlib1g-dev gcc-multilib g++-multilib libc6-dev-i386 lib32ncurses5-dev ia32-libs x11proto-core-dev libx11-dev lib32readline5-dev lib32z-dev.
thats for the libraries.
and this one for tollchains or cross tools or ... what you want call it.
http://www.codesourcery.com/sgpp/lit...tal/release858
download it and install it. in the same folder as repository (example myAndroid/cross_tools)
Thanks to Endrix with his tutorial help me a lot.
5th.Now enter in your kernel_1 folder or whatever you called it and tap: make ARCH=arm tsunagi_defconfig
6th When finish writing to configuration. tap: make ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabi-
enter
If you have done everything without errors then you will see how linux is building your kernel.
7th When finish building go to (exaple myAndroid/kernel_1/ARCH/arm/boot/ ) ther is your kernel Image and zImage you can use both if you want. :O)
Feb 17, 2011 | Toshiba TG01 - Pay Monthly Cell Phone
My ownerd manual will not download in this computer. How do I turn on the fine pix mode on the camera?
iam glad to be of help. The owners' manual can also be downloaded at the following internet address:
http://fujifilmusa.com/shared/bin/S1000fd_E.pdf
On page 79 of the manual the folllowing procedure for changing the finepix colour setting :
  • (STD) F-STANDARD: the contrast and color saturation are set to standard.use this mode for normal photography.
  • (C) F-CHROME: The contrast and color saturation are set to high.This mode is effective for taking more vivid shots of subjects such as flowers.
  • (B) F-B&W: This mode converts the colors in the photographed image to black and white
When setting the (C)F-CROME or (B) F-B&W the icon appears on the screen.
Hope this helps!
Oct 27, 2009 | Fuji FinePix S1000FD Digital Camera
PUT IN NEW CARTRIGES AND NOW MY HP WONT WORK
have you put the cartridge correctly sir/ ma'am? if yes try reinstalling the driver of your printer.
Feb 23, 2009 | HP DeskJet F380 All-In-One Printer
My psp video
search in google for (WinAVI MP4 Converter).
the out put file should be two file's.
the video name should be (M4V20001 and continue M4V20002, M4V20003, M4V20004).
if not you should name it.
the other file name should be (M4V20001.THM and continue M4V20002.THM, M4V20003.THM, M4V20004.THM)
the same here if not you should name it too.
and it will work :)
Regards.
Jul 15, 2008 | Sony PlayStation Portable (PSP) Console
Cordless phone modrl 25922
My phone is not ringing. How can I resolve this issue?
Dec 16, 2007 | Uniden Cordless Phone
Android Apps Logo
66 people viewed this question
Top Mobile Systems Apps Experts
Ian Prescott
Ian Prescott
Level 1 Expert
topcat7736
Level 1 Expert
Are you a Mobile Systems App Expert? Answer questions, earn points and help others
