Question about Frigidaire PLD4555RFC Dishwasher
Frigidaire dishwasher lo rinse light? - Frigidaire PLD4555RFC Dishwasher
4 Suggested Answers
  • 3 Answers
SOURCE: dishwasher, flashing lights, frigidaire
The steam has gotten into the keypad display and fried it. Call Fridgidaire and let them know you've seen numerous people on the internet with the same problem and that you need part# 154554401 It worked for me.
Posted on Apr 01, 2009
  • 39 Answers
SOURCE: My Frigidaire dishwasher leaks the rinse agent
it may leak because:
1. Seal is bad. (o-ring?)
2. a spring on mechanism may be loose, missing or broken.
3. the container that holds the fluid may be cracked.
find schematic and parts for you model number here:
appliancepartspros.com
Posted on Nov 02, 2009
  • 4 Answers
SOURCE: PLD4555RFC: Low Rinse Agent Light Will Not Go Out
I've disconnected the sensor in the dispenser for my new Frigidaire dishwasher. The setup is too unreliable in my opinion and is a potential source of headaches. I had the same problem. I studied the design and it's too easy for the floating magnet sensor in the rinse aid reservoir to stick thereby not actuating what is called a reed switch to toggle the control card LO ckt light. Mine has the electronic control front panel.
Posted on Aug 03, 2012
Frigidaire dishwasher model pldb998ac1
If you use salt, maybe that needs refilling. Can't think what else would be low
Nov 08, 2017 | Dishwashers
My Frigidaire dishwasher - most buttons don't work and clean and sanitized lights are flashing after cycle completes.
Hello Rich - From what you have described if only some cycles are working, then there seems to be a communication problem coming from the main control panel, I would suggest contacting a professional technician to diagnose the unit.
Sep 23, 2012 | Frigidaire Dishwashers
Light is on for heat dry but won't allow me to run a cyle or turn on
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
Apr 17, 2011 | Frigidaire Professional Series 24 in....
Brand new dishwasher does nothing but wash & rinse
Time for warranty replacement or repairs! Good luck!
May 14, 2010 | Frigidaire PLD4375RFC Dishwasher
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Nov 24, 2009 | Frigidaire Dishwashers
My Frigidaire dishwasher leaks the rinse agent into the tub. Therefore, the low rinse agent light is always on.
Nov 02, 2009 | Frigidaire Professional Series 24 in....
Dishwasher, flashing lights, frigidaire
Jan 20, 2009 | Frigidaire 24 in. PLD3465REC Stainless...
Dishwasher lock key
To prevent a child from accidently starting the dishwasher there is a child lockout feature. Press and hold the Rinse and Hold pad (certain models) or the No Heat dry pad (certain models) for # seconds to Lock or UnLock the controls
Jan 20, 2008 | Frigidaire 24 in. PLD2560LCC Energy...
Jan 07, 2008 | Frigidaire PLD4555RFC Dishwasher
Frigidaire PLD4555RFC Dishwasher Logo
37 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
