Question about HP Officejet 5610 All-In-One InkJet Printer
Driver for HP OfficeJet Pro K550
Driver required
    Director Badge:
    Uploaded 100 video answers.
  • HP Master
  • 685 Answers
Here's how to find software.
Posted on May 08, 2014
  • 32 Answers
SOURCE: replacement of printhead
hi burhanzj-
just for future refs, here are a few links to hp's support site that might be helpful:
changing print heads -
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00491050&dlc=en&product=501369
cleaning print heads -
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00489797&dlc=en&product=501369
reviewing the configuration page -
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00601504&dlc=en&product=501369
Posted on Oct 08, 2008
SOURCE: HP Officejet Pro L7500 -
Had a similar problem " with my L7590 allin one unit, "scanner did not function" from the Solution center. If your unit is plugged into a surge protector, unplug the unit from the surge protector and plug directly into the wall power socket. It solved my problem. Can you believe this.The explanation is that the printer goes into sleep mode it reduces the amount of power needed for its uses and the internal surge protector of the unit notes this; however, when you "wake the printer up" the difference in power usage between the two levels may be considered by the surge protector as a power surge and limit or halt the increase, disabling certain functions. George
Posted on Apr 15, 2009
wings_it
  • 141 Answers
SOURCE: Hp officejet k550 wont print black ink
I guess you tried a new cartridge with the same problem.. so try to run the utility tools from the HP soft, you can download it here :
http://h10025.www1.hp.com/ewfrf/wc/product?product=501369&lc=en&cc=us&dlc=en&submit.y=7&submit.x=11&lang=en&cc=us
It has also a "Solve a problem" section who might help you.
Then if the problem remain check the contacts in the printer, sometimes ink goes in, dry and stop the contact. Clean it with a hear tip and water (disconnect power and allow to dry before testing)...
Good luck and don't forget to rate.
Cheers
Posted on Jan 23, 2010
  • 5187 Answers
SOURCE: no connection ref hp officejet pro 8500 a909a
How are you connecting to the printer (over the network or a direct USB connection)? If you are using a USB connection, try a new cable or plugging into a different USB port. If you use a USB hub, try a direct connection.
If you are using a network connection, check if your firewall is blocking the connection. Also check that the router (or switch) didn't dropped the network connection and didn't re-synch with the printer (or worse changed the IP address of the printer).
I hope this helps.
Posted on Apr 19, 2010
Testimonial: "superb"
  • 12 Answers
SOURCE: My HP Officejet pro K550
This is normal for this model of HP printer when the ink has 'expired'.
Normally it will print one line from the print head, then check to see if the ink is okay before pumping more ink into the printhead. If it has expired then it pauses in the middle of printing to give the user an opportunity to replace the ink cartridge with a new one, highlight which cartridge needs replacing by lighting and indicator over the 'bad' cartridge.
There are three solutions for this:
  1. Buy a new HP Ink cartridge;
    expensive and innefficient, but it will ensure the highest level of quality and continued warranty for your HP printer. And is the least likely to cause problems.
  2. Buy a third-party "refillable" ink cartridge, or MOD chip;
    Less expensive, but still wastes what remaining ink you have in that ink cartridge. Voids the warranty for your HP printer and can lead to a print head clog.
  3. Set your system clock and print like it's 1999;
    Silly printer driver reads the system time to determine if it has expired; will cause the printer log to be inaccurate, and cause problems with software updates, security certificates and other time-sensitive applications. May requirie shutting down both PC and printer simultaneously to be effective.
  4. Crack/Patch or replace the printer driver to remove expiry;
    3rd party replacement drivers are unable to match the resolution of HP's original drivers because they don't know HP's secret PCL codes. Cracking/Patching HP drivers may be illegal depending on where you live and what security clearance you have. It may also possibly sometimes break features like document control and printer logging.
  5. Buy another printer
    Expensive and wasteful.
I'd reccommend option 3 if not for the fact that there is no publically availble patch anywhere on the internet. However... you can make any choice you please.
Posted on Aug 08, 2010
My Office Jet Pro k550 won't pump ink from only one colour, the cyan. Will an HP cartridge help?
should, try cleaning the heads of the one that don't pump ink with achol and swab
Jan 26, 2013 | HP OfficeJet Pro k550 Printer
Hi, i have an HP Officejet pro k550 series printer and i dont know how to set the wireless setting, eg. IP configuration
If you printer has the optional Jetdirect print server istalled and you have a wireless router, then to configure this printer for your wireless network, please click on this link and follow my instructions.
http://www.fixya.com/support/r3559242-setting_up_hp_jetdirect_print_server_p
Jul 04, 2011 | HP OfficeJet Pro k550 Printer
I have a non HP cartridge in my K550 it will printe one copy and then ask for an authentic HP cartridge, I reset and will again get one copy and then the request for HP cartridge...How can I by-pass this...
Each printer require certain matched type of cartridge, if you use another type of cartridge it may broke the system or the printer itself. Instead of trying to skip this notification, I think it would be wiser if you change the cartridge with the original one. It may more expensive, but guaranteed compatible with the printer and the software.
If you resist use this non HP cartridge, try to re-install the driver with this cartridge attach in the printer.
Hope this help.
Feb 03, 2011 | HP Officejet Pro K550 InkJet Printer
Have had the HP k550 a while. all of a sudden,
Please go to device manager check the status of drivers please.
May be they need a reload.
Jul 27, 2010 | HP OfficeJet Pro k550 Printer
My HP Officejet pro k550 is sending a signal that the paper is out and it is full. Can you help me?
Try to disable bi-directional support
Go to printer properties->ports tab-->uncheck on bi-directional support
Click OK
Hope this helps.
Jun 29, 2009 | HP OfficeJet Pro k550 Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
16 people viewed this question
Seeker5211
Seeker5211
