Question about Amcor Heating & Cooling
Use of amcor 9000 air conditioner
Can I use this machine in a small room (10' x 12.5') without using the exhaust hose ?
  • brianclarkso Jun 22, 2009
    Many thanks for such a quick response. It was impressive and answers my problem admirably,
  • 520 Answers
No because you would be putting the heat right back in just as fast as you take it out.
Posted on Jun 22, 2009
My home base portable air condition blow cold air for short period I have put the temperature 16° if it blow cold air small then it will cut off and blow warm air and the room temperature is always at 30°...
http://www.royalsovereign.com/customer-support/faqs-frequently-asked-questions/portable-air-conditioner-faq.html
Why does my portable air conditioner cool for a short period of time and then turn off?
Have you extended the exhaust hose with another? The unit can ONLY be used with the included exhaust hose (dryer type exhaust hoses will cause the unit to over heat).
How close is the unit to the wall? If the unit is only inches away from the wall and you are running the exhaust hose out a window, more than likely their exhaust hose bend is at 90 degrees which restricts air flow. In order for the unit to run more efficiently and not overheat, it should be at least 1-1/2 feet away from the wall and the exhaust hose should not exceed more then a 45 degree angle.
Are you exhausting the unit out a hole in the wall? If so, are you using a flap vent on the exterior of your home/office? The flap may be too rigid and not open continuously. The compressor is not strong enough to push the air through and therefore will only run for a short period of time before overheating and shutting off. You should take the flap off the vent and replace it with a piece of screening.
Are you venting it into a ceiling or basement? Does the ceiling or basement have ample ventilation? If the ceiling or basement does not have a way of pushing the heat from the exhaust to the outside, the unit will work for a short period of time and then eventually overheat and shut off. Portable Air Conditioner FAQ Portable Air Conditioner Frequently Asked...
Apr 24, 2018 | Heating & Cooling
What causes the exhaust hose to get hot on a windchaser portable AC
make sure its not obstructed, then wrap it up with a towel or other insulative material. it heats up because the heat exhausts through that hose out the window.
Jun 28, 2014 | Windchaser PAC9 Air Conditioner
What does E20 mean
The E20 error code indicates a problem with water drainage. Inspect the drainage hose for kinks that could impede the drainage flow. This frequently occurs when the machine is pushed up against the wall without allowing room for the hoses. If there are no kinks, the hose is probably clogged. Carefully detach the hose from the machine, and use a garden hose to force water through it. If the water doesn't pass through, use a plumber's snake to clear the clog. If there is no clog, inspect the drain pump for clogs. Unplug the machine, and open the small rectangular door towards the bottom of the front of the machine. Drain the pump through the emptying hose into a container until the water flow stops, and rotate the pump impeller to clear any foreign objects. Close the pump and restart the cycle. If the problem persists, contact a service center.
May 18, 2012 | Zanussi ZWF1430W Front Load Washer
My laundry room has tons and tons of lint in it. The dryer is emitting so much lint into the air. I clean out the trap in the front of the machine but there has got to be something I am missing.
The hose is probably off of the dryer in the back....the lint should be exhausting outside and not into the room...they will always throw lint even with the lint filter in the dryer...
look for where the exhaust hose is unhooked at...
heatman101
Jul 27, 2010 | Dryers
Air intake via hose & window or intake from room only?
Hello artrey3 The answer is yes, BUT the unit will be exausting room/basement air outside ruining any efficency the unit is rated for.Also you will need makeup/fresh air in the basement. The unit exausting air can put the basement in a vacuum/negitive pressure pulling in air from the chimney!
Jul 09, 2010 | Amana Heating & Cooling
When I turn on ac, temp in room comes down, temp on machine reads 95F could problem be exhaust hose has some tears?
The temp sensor is located on the upper rear just behind the air filter. Slide the filter out and give it a cleaning. Look for a small wire visible. Inspect the temp sensor; it gets dusty.
If the hose was leaking you would feel the heat in the room.
Jul 09, 2010 | Danby DPAC120068 Air Conditioner
AC was cooling fine. Now, won't cool room even though cool air comes out. Exhaust hose is extremely hot.
Check filter, if you have a 5000BTU unit (small) and it is extremely hot, then it wont work great for a big room. BTU is the rate of what the AC will put out. 5000 BTU is good for a small single room. 10,000 will cool a bigger room and 18,000 btu is meant to cool a home.
Jul 07, 2010 | Whirlpool ACP102PS Portable Air...
Dryer exhaust not blowing out of vent tubing
open it up follow the vent,it is either blocked or came off.
Dec 08, 2008 | Splendide 2100 Vented Washer-Dryer
Hot Air
I am assuming it's turned on, and plugged into electricity, but at that point I have no idea what you are doing to try to cool the air, as in, what settings do you have it on?
Does the front indicator panel, led lights, have any signals indicated?
Are you exhausting air out of the room, and using both exhausts?
Are the exhaust lines straight? Pointed upward or downward? Sideways kinked?
Are there Hard S's in the exhaust lines that would cause backup of air flow?
Has a family of small penguins (very small) moved into the exhaust hoses, thereby blocking flow?
What is the actual temperature before use, and during use after a given amount of time and at what is the outside ambient temperature?
Did You lay it down or sideways before turning it on, or has it always been in the upright position?
Is the filter clean?
Have you cleared out the drainage hoses? They may be backed up.
Are your vents open?
Air in, air out.
try leveling or having the exhaust hoses point down and not up to exhaust.
Aug 01, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Blows room temperature air
Hello
Welcome to fixya.
I'm Huuum and happy to assist you
The air conditioning
unit works, but does
not cool the room
• window open
• there are heat sources in the room (burner,
lamp, etc)
• the exhaust hose is detached
• air filters clogged
• Inadequate size of the room (too large)
• close the window
• eliminate the heat source
• connect the exhaust hose
• clean or replace the filters
If all this dose not remedy the problem then you need to see service!
Please remember to leave a rating before you go!
Thank you
Jul 13, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Heating & Cooling Logo
174 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
