How many 3 figure combinations are there for the numbers 1, 2, 3
Numbers can be used more than once or not at all in each combination
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Computers & ... Master
  • 102,366 Answers
Twenty-seven (27).
Posted on Jun 05, 2014
2 Suggested Answers
  • 7993 Answers
SOURCE: Does anybody know how many different combinations there are for the numbers 1, 2, 3, 4, 5 and 6?
No, we don't, unless you tell us more. How many digits are you selecting at a time? Even though you say combinations, I am not sure if you mean arrangements, permutations, or combinations.
Posted on Oct 18, 2013
How to change the 3 digit code of my samsonite ?
Luggage manufacturer Samsonite offers a variety of business, personal, travel products and accessories. Many Samsonite pieces such as attaches and other bags include a three-digit, built-in combination lock. When purchased, the locks are set on a factory default combination that you can change as often as you wish.
STEP 1
Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage.
STEP 2
Locate the reset button, usually placed to the side of the combination dials.
STEP 3
Press the reset button and hold it while rotating the number dials to the desired combination. Set this to a sequence easy for you to remember but hard for others to figure out.
STEP 4
Release the reset button after you set the numbers to the new combination.
STEP 5
Test the combination by turning the dials to the new code to open the lock. If the combination does not open the lock, repeat Steps 1 through 4 and test the lock again. If you still can't open the lock, contact Samsonite Customer Service at 800-765-2247.
Aug 28, 2016 | Luggage & Travel
I need all possible 5 digit combinations using only numbers 1,2,3,4,7 nobly using each number once in every combinations
There is only one combination using all five digits, namely 1, 2, 3, 4, 7 in some order.
If the order matters then there are 120 different permutations. I won't list them all here, but they start with 1, 2, 3, 4, 7 and go through 7, 4, 3, 2, 1.
Aug 21, 2014 | Computers & Internet
1 to 12 numbers picking 4 numbers only once in each set of four how many combinations are they
Combinations 12C4=495 if the position of a number is not considered.
It means {1,2,3,4}, {2,1,3,4}, {3,1,2,4}, etc. are the same combination
Permutation. 12P4=11880 if order is important.
Jun 01, 2014 | Computers & Internet
I have 11 numbers. I want to use those 11 numbers to create 7 number combinations.
Does every number have to be taken only once?
If order is important you have 11P7=1663200 permutations (different from combinations)
If order is not important for example 1,2,3,4,5,6,7---- 2,1,3,4,5,6,7----2,3,1,4,5,6,7----2,3,4,1,5,6,7 etc are all one and the same then you have
11C7 =330 combinations.
You get them by mere obstinacy: take a pad and start. It is only 330.
Dec 13, 2013 | Office Equipment & Supplies
How do I change the combination on my Unican 1000 keyless lock? thx john
The door must be open.
On models with the passage feature, make sure the passage feature is disengaged: turn knob or key should be in vertical position (A) (see figure 1).
1. Insert the DF-59 control key (B) into the combination change plug
assembly (
C) and unscrew the cylinder by turning the key
c
ounterclockwise. Remove the combination change plug to gain access to the combination change sleeve (see figure 1).
2. Turn the outside knob/lever once clockwise (all the way, until it stops) then release. The latch should not retract (see figure 4).
3. Enter the existing combination. On new installations, use the factory- set combination: depress 2 and 4 simultaneously, (release), then 3
(r
elease). You should feel a slight click as each button is depressed.
4. Insert the spanner wrench as shown in figure 2 to engage the combina- tion change sleeve (A). Gently turn the spanner wrench clockwise to the stop position (a slight click should be felt), then turn the spanner wrench counter-clockwise to the stop position (A) (see figure 3). Remove the spanner wrench.
5. Turn the outside knob/lever once clockwise all the way until it stops, then release. The latch should not retract (see figure 4).
6. Choose your new combination, write it down, then enter the new combination-depress buttons carefully (a slight click should be felt as each button is depressed).
Note: You can use one button or all five for a combination, but each button can only be used once. You can depress two or more buttons simultaneously as a step in the combination.
7. Turn the outside knob/lever clockwise once, all the way, until it stops, hold in position and make sure the latch is retracted (see figure 5).
R
elease the knob/lever.
Note: If your lock is opening on every turn of the knob or lever, except upon entering a code, this may be a ZERO CODE. Before attempting to remove the lock from the door, refer to the troubleshooting procedures outlined at bottom of this document for a zero code symptom/solution.
1000/L1000 Series FAQ
Changing the Code/Combination
hope this helps
and here is the link to the change code web site
http://www.locksonline.co.uk/files/pdf/Simplex_1000_CodeChange.pdf
good luck
please take the time to rank my advice
merry christmas
Dec 07, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
I need the manual so i can reprogram the unit
This is the sequence that I came up with.
Good or bad,please rate my post?
Thanks
Bob
Resetting the Code/Combination From a Lost Code
Simplex LP1000
Important: There is no procedure for finding an unknown combination from the front of the lock. A lost combination must be cleared by removing the combination chamber from the lock housing, then a new combination can be set.
LP1000 Series FAQ
1. Remove the back plate from the front lock housing by removing the six back plate screws.
2. Remove the two Phillips head screws (F) securing the guide bracket (D
to the front housing. Grasp the guide bracket and slide it back to
disengage it from the clutch linkage (see figure 1).
3. Lift the two chamber links (A) off of the control shaft (B) using a small flat blade screwdriver. Mark links to assure proper reassembly (see figure 1).
4. Remove the combination chamber (E) by removing the Phillips head screws (G) at each end of the chamber (see figure 1).
5. Remove shaft bushing (C) from control shaft (see figure 1).
6. Remove chamber cover marked ILCO UNICAN (A) (see figure 2) by gently tapping the lip of the chamber cover (A) at the control shaft end of the
chamber (see figure 3) with a screwdriver to detach it from the staked joints (B).
7. Lay the chamber on its side as shown in figure 4.
8. With tweezers, or other tool, slide the "E" ring (B) off the unlocking slide
stud (A) (see figure 17-4), then gently lift the end of the unlocking slide (C) over the unlocking slide stud (A) (see figure 5).
Note: The unlocking slide (C) is under spring tension and will be easier to lift if pushed to the left to ease tension. Swing the unlocking slide (C) sufficiently to clear the gears, (D) no further than shown in figure 5.
9. Depress the lockout slide (E) as shown in figure 6. The gears (D) are now free to rotate.
10. Turn each gear (D) so that the slots (F) are aligned as shown in figure 6.
11. Return the unlocking slide (C) over the unlocking slide studs (A) while making certain the five toes (G) are engaged in the five gear pockets (F). It may be necessary to adjust each gear (D) slightly to make proper alignment between toes and gear slots (see figures 6 & 7).
Re-secure the "E" ring on the stud (A). Your chamber will now resemble figure 7 and is ready for reassembly with the lock housing.
REASSEMBLY
1. Re-secure the chamber cover (A) marked ILCO UNICAN. Make sure the staked joints (B) (see figure 2) on both end plates fit through both slots on the chamber cover.
2. Re-secure the shaft bushing (C) with flat side facing up (see figure 8).
3. Secure the combination chamber with the two Phillips head screws (G) you removed earlier.
4. Re-secure the chamber links (A) onto the control shaft.
5. Replace the guide bracket (D) by aligning the clutch linkage in the guide bracket and secure with the two Phillips head screws (F) previously removed.
6. Replace the back plate and secure it with the six back plate screws.
SETTING THE COMBINATION
Do not attempt to set a combination until the complete unit has been reassembled.
Perform the following steps in the order shown.
1. Turn the outside lever once to the stop position and then release.
2. Enter the new combination.
3. Turn the outside lever to the stop position, make sure the latch is fully retracted, then release
the lever.
Aug 11, 2010 | Simplex Kaba Ilco Unican LP1000...
I lost the instructions and don't know how to unlock using "original code" and how to create a new code
try all zeros Kryptonite locks come preset to zeros once unlocked there is a small lever inside were it locks together pull it down and set your new combo then push it back up
Oct 17, 2009 | Kryptonite Kryptoflex 1218 Combo Cable...
I dont know how to open the lock its brand new????? They failed to give me instructions when they attached to the bike
My new lock didn't come with any instuctions. I followed the link above and located the "bike locks" heading. I found that the question:
- I have a Kryptonite resettable combination lock and can't find the instructions for resetting it. How can I change the combination?
contained a pdf titled :
- Resettable Combination Cable
(red reset buttons inside)
which is not the cryptoflex 1218 but is compatible anyway.
dont hurt your fingers trying to depress the nodules as the diagram says though. to my chagrin i discovered that they will turn easily if you just push them around into place.
here are the instructions:
To set your own combination
Your new lock is preset to open at 0-0-0-5 at the factory.
1. Open the lock by aligning the opening combination
number to the Guide Points and pull out the Lock
Post. (Figure 1)
2. Push down the two Reset Buttons simultaneously
with thumb and forefinger, and turn counterclockwise
until it comes to a stop. (Figure 2)
3.You are now ready to turn the dials to set your
secret combination, such as a phone number, birthday,
etc.
4. After setting your secret combination, turn the
two Reset Buttons again by Thumb and Forefinger
clockwise until it comes to a stop and back to its
original position.
5. Verify your new combination before using your
lock. Insert the Lock Post all the way into the Locking
Port but do not turn the dials. Pull out the Lock Post.
Your lock is ready to use.
6.The reset operation is now complete. Repeat
steps 1-5 anytime you wish to change your secret
combination.
Oct 11, 2009 | Kryptonite Kryptoflex 1218 Combo Cable...
We threw out the info that came with our new trek combination lock. now we have no idea how to open it or to reset it.
Try this....
Post. (Figure 1)
etc.
original position.
combination.
Sep 16, 2009 | Kryptonite Kryptoflex 1218 Combo Cable...
Erased the code
FOR YOUR SECURITY THE
COMBINATION MUST BE CHANGED
WHEN THE LOCK IS INSTALLED.
position (A) (see figure 14-1).
combination change plug assembly (C)
key counterclockwise. Remove the combination
14-1).
2. Turn the outside knob once clockwise
14-4).
installations, use the factory-set combination:
(release), then 3 (release). You should
depressed.
Figure 14-2 to engage the combination
then turn the spanner wrench counterclockwise
14-3). Remove the spanner wrench.
5. Turn the outside knob once clockwise all
latch should not retract (see figure 14-4).
on page 26, then enter the new combination
— depress buttons care-fully
Dec 08, 2008 | Simplex Kaba Ilco Unican 1000 keyless...
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
