How many combinations are there for the numbers 1, 2, 3
The numbers can be repeated but only 1, 2, and 3 can be used in any combination
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Computers & ... Master
  • 102,366 Answers
If you're asking for three-digit combinations, 27.
Posted on Jun 05, 2014
2 Suggested Answers
  • 7993 Answers
SOURCE: Does anybody know how many different combinations there are for the numbers 1, 2, 3, 4, 5 and 6?
No, we don't, unless you tell us more. How many digits are you selecting at a time? Even though you say combinations, I am not sure if you mean arrangements, permutations, or combinations.
Posted on Oct 18, 2013
I forgot yo open a security box. Please let me know how.
1 You will need to find out the combination. The first thing to do is to move the entire dial that is in the lock to the right. This will let you know that all the wheels are disengaged. 3. You will need a stethoscope. Each time you turn the dial, you reach the point of the combination number you can hear a click here. You should make notes considering the numbers you can read on the dial each time you hear two clicks. This will help you know the length of the combination. You must use a stethoscope to listen carefully and precisely where the clicks sound. 4. Repeat the process. Then repeat the process considering the number of clicks you hear in the process, repeat several times to make sure you're right about the number of click. This information should be represented in a chart in order to know the numbers of the combination to open safe. You have to start testing the clicks generated by the box when the dial is turned, the dial should be at zero.
5. Combine data to open safe. With the data obtained when listening to the clicks generated by the dial, you should start making combinations and test them in the safe until you get the perfect combination that will help you open the safe. Example if when turning the dial you could hear 3 times two clicks, ie the combination of the safe must have 3 numbers. Consider the exact numbers you could see on the dial when you heard the clicks. Then you must have something like this in your notes (2, 65, 34). Start combining them and try in the safe until you find the right combination, start making patterns and discard. Then those copied in your notes will be the secret code numbers that will open safe. It is very important that you have been very careful when listening to the clicks and that this process has been done several times to be sure that these numbers are correct. Now you can make patterns, considering the numbers that you raise in the example, such as: 2.34,65); (34,265); (65,2,34) and so on until finding the correct one. That is why you need to write down all possible combinations and tosa trials. Remember the success of, without opening your safe, without a locksmith, and also considering that you do not have the possibility to call a manufacturer. Be: • Listen carefully to the sounds of the clicks you hear in the safe. • Avoid other sounds that may distort your ability to listen carefully • Record exact numbers where you clicked • Be patient and test your combinations. You must have on hand the instructions of the manufacturer of the safe, if you do not have it, look on the web since surely the manufacturer has a page where you can find this information. You could also call the manufacturer and prior identification will give you the key to your safe. Otherwise and if you've tried all the possible combinations and you just can not do it, call a locksmith. You no longer have a bad life and recover your valuable items, open safe can generate waste of time but if you strive you will stay with great satisfaction.
Aug 13, 2017 | Cell Phones
How to change the 3 digit code of my samsonite ?
Luggage manufacturer Samsonite offers a variety of business, personal, travel products and accessories. Many Samsonite pieces such as attaches and other bags include a three-digit, built-in combination lock. When purchased, the locks are set on a factory default combination that you can change as often as you wish.
STEP 1
Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage.
STEP 2
Locate the reset button, usually placed to the side of the combination dials.
STEP 3
Press the reset button and hold it while rotating the number dials to the desired combination. Set this to a sequence easy for you to remember but hard for others to figure out.
STEP 4
Release the reset button after you set the numbers to the new combination.
STEP 5
Test the combination by turning the dials to the new code to open the lock. If the combination does not open the lock, repeat Steps 1 through 4 and test the lock again. If you still can't open the lock, contact Samsonite Customer Service at 800-765-2247.
Aug 28, 2016 | Luggage & Travel
I need all possible 5 digit combinations using only numbers 1,2,3,4,7 nobly using each number once in every combinations
There is only one combination using all five digits, namely 1, 2, 3, 4, 7 in some order.
If the order matters then there are 120 different permutations. I won't list them all here, but they start with 1, 2, 3, 4, 7 and go through 7, 4, 3, 2, 1.
Aug 21, 2014 | Computers & Internet
I have 6 digits, numbers 1-6 need to list all combinations possable
There's only one six-digit combination possible, namely the digits 1, 2, 3, 4, 5, and 6.
If the order matters then there are 720 possible permutation. I'm not going to list them all. Start with 123456, then 123465, 123546, and so on to 654312 and 654321.
Mar 25, 2014 | Computers & Internet
How many 3-digit number combinations can you make with using odd numbers
If the numbers repeat twice, there are five combinations (111, 333, 555, 777, and 999). If the numbers only repeat once, there are sixty combinations (113, 131, 311, 115, 151, 511, etc).
Mar 18, 2014 | Computers & Internet
Combination calculator
how do i find out the possible number combinations for the numbers 1238 but 1 and 2 repeat making the numbers become 112338 how can i get a list to print off all the possible combinations
Jan 01, 2014 | Office Equipment & Supplies
That depends on how many of those six numbers you take.
If you only take one number, there are six combinations: {1}, {2}, {3}, {4}, {5}, and {6}.
If you take two numbers, there are fifteen combinations: {1,2}, {1,3}, {1,4}, {1,5}, {1,6}, {2,3}, {2,4}, {2,5}, {2,6}, {3,4}, {3,5}, {3,6}, {4,5}, {4,6}, and {5,6}.
If you take three numbers, there are twenty combinations.
If you take four numbers, there are fifteen combinations.
If you take five numbers, there are six combinations.
If you take all six numbers, there is only one combination: {1,2,3,4,5,6}.
In general, if you take 'm' objects out of a set of 'n' objects, the number of combinations is given by n!/[(m!)(n-m)!] where '!' is the factorial operator.
Apr 30, 2013 | Mathsoft Computers & Internet
How many combinations for the numbers 1, 2, 3, 4, 5 and 6?
If you only take one number, there are six combinations.
If you take two numbers, there are fifteen combinations.
If you take all six numbers, there is only one combination.
Apr 30, 2013 | Home Security
I have lost my instructions to unlock this TARGUS PA400C DEFCON 1 AUDIBLE NOTEBOOK ALARM (PA400C) Do you know where I can find what the default code is?
this may help
Due to the nature of security devices, there is no "magic unlock" code for the Defcon device. To recover a lost combination:
·Set the tumblers to the last known combination.
·While applying pressure to the red release button, rotate the tumblers up one digit and then down one digit on each of the individual tumblers.
·For Example: If your last know combination was 565
1.Set the tumblers to 565
2.Hold the red release button in and rotate the 1st tumbler to 6 so that the combination is now set to 665 (If this is the set combination the red release button will move in)
3.Hold the red release button in and rotate the 1st tumbler to 4 so that the combination is now set to 465
4.If not found move onto the 2nd tumbler and repeat step 1-3
5.If not found move onto the 3rd tumbler and repeat step 1-3
Dec 30, 2008 | Bennett Marine GARMIN StreetPilot...
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
