Question about Garden
How to replace the motion belt on a model 247.28852
On a craftsman model 247.288852 21 hp riding mower
  • 18 Answers
SOURCE: motion drive belt on craftsman riding mower
there is no adjustment..it is set by the spring that engages ur drive belt....
Posted on Sep 03, 2008
  • 24 Answers
SOURCE: murray riding lawnmower motion belt routing
I need your model # took look it up , I am a Murray dealer.
The thing to rember there are two kinds of idler pulleys flat idlers that ride on the back side of belts and v pulleys that ride inside the belt . wont be back to the shop until the feb 10.
good luck
Posted on Feb 08, 2009
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
  • 376 Answers
SOURCE: Belt Diagram needed on Craftsman Kohler Command 20 Hp RidingMower
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter your model #, click enter, then scroll down to the sudcomponent list and click on 'Mower Deck' if it's your blade belt you need to see or 'Ground Drive' for your transmission belt. Hope that helps. Dwain
Posted on May 15, 2009
rockitman187
  • 2559 Answers
SOURCE: i need a manual to show me how to adjust the belt
Here is a link to the manual
Please rate this a fixya.
Craftsman schematic
Go online to Sears/Craftsman , or go to Youtube ,they will have videos explaining how to
Jul 17, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Fix a motion drive belt squeals on a Craftsman 24 hp 42 in. Deck Lawn Tractor - CA Model
If I understand the issue correctly, the belt that drives the machine's transmission squeals. When does it squeal? When engaging the clutch? When in motion?
Typically it's the condition of the belt. It's likely slipping due to stretch, wear or from an oil leak causing it to slip, or simply due to a loose idler pulley, worn idler pulley bearing, broken spring. Look for all that stuff. Look at the drive belt and inspect for wear, cracks, fraying, missing rubber, etc. Replace it if any of those conditions are found.
Jul 09, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a 42" Craftsman
HI IF YOUR BELT IS LOOSE THEN YES YOU NEED A NEW BELT
IT IS A V-BELT GROUND DRIVE-95 25
PART /160855
Sep 02, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do you replace drive belt on a hydrostatic transmission craftsman riding lawnmower that has slipped off or my be broken.
Its not a hard job just push in clutch and lock it, remove mower belt then replace drive belt and then put mower belt back on and release clutch.
Jul 17, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Clutch vibration and jerking at slow speeds.
Check the drive belt. It probably has chunks missing or at least has flat spots (narrow spots) that cause the belt to jump every time it goes around a pulley. That will set up a heck of a vibration. Also check the pulleys for free movement. The drive belt is above the blade drive belt....
Jul 27, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Craftsman lawn tractor mower, automatic,917.273621, transmission will not pull mower up a slight hill. richard swint drive/motion belt seems normal,
The belt is probably slipping because it is not tight enough. look by the belt, inside there is a little spring, you may half to tighten it.
Jun 13, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman LT1000 mower
In the Google search box type belt and pulley diagram craftsman lt 1000.....then Search images. The first 4 images feature "springs" however, you can clearly see the motion belt diagram. Hope this information is helpful.
Rox.
May 24, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
123 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
