Question about Irons
Euro pro ironing board cover
Can you find a euro pro ironing board cover replacement model EP51A?
SOURCE: Manual for Euro-Pro G6118H
I don't know if you have the number for the euro pro customer service department; but, I had the same problem, called customer service, and had a manual emailed to me. The manual came within a couple of hours via email. In case you don't have the number and still need a manual for your unit, try calling 800.798.7398. I hope this helps and good luck!
Posted on Jul 18, 2008
SOURCE: Handle on iron gets too
I purchased a silicone heat protector for a pot handle and sewed it together with dental floss around the iron handle
Posted on Feb 09, 2009
Blindbox1
  • 9 Answers
SOURCE: Euro Pro 1005 ironing Cover and Part.
Hello, rslarve, Okay, here are a couple of links that should be helpful: Euro Pro Replacement Cover LC and Pad for EP1010 / 1005
This will link you directly to the purchase page for the ironing cover you want. Sorry, but after extensive searching, it's the only one I could find, so I suggest you get two while the getting is good! Customer Support for Sharkvac Products - sharkvac.com
This link will take you to a web page that will allow you to send the manufacturer an email explaining the part you need. Please, before you send the email, try your best to find your manual and see if there is a part number listed for the part you want. If not, and the old part is available (like—if you have a broken one), check it over thoroughly (perhaps using a small flashlight and magnifying glass to make sure you don't miss it) for any numbers that might be stamped, embossed, or etched into it. Even if they are not part numbers, they may help the manufacturer to locate the one you need. No matter what, send them as much information as you possibly can in order to help them be able to help you—the easier you make it on them, the more likely you are to get satisfactory results.  Finally, here is a toll-free number for the manufacturer's tech-support line: the same "homework" applies before you call it: 1-800-798-7398. Hours are Monday through Saturday from 9:00am to 6:00pm Eastern Standard Time.
I hope this helps! Ken
Posted on Feb 15, 2009
  • 4 Answers
SOURCE: G6118 Euro-Pro Iron
We fixed ours today. Take the iron plate off (bottom of the iron shaped like a triangle). You are looking for a thermal fuse (or thermal-protector fuse) pictured here for less than $2 at Radio Shack (http://www.radioshack.com/product/index.jsp?productId=2102788&CAWELAID=107599331). You will need needlenose pliers to gently remove the old fuse and the wire cutters to trim the long wires to the same length as the old fuse (less than 1/2"). Also, since the old fuse was 240 C and we only could find a 228 C replacement - we cannot use the iron at the same high temp. So we limited the dial by marking out a portion of the dial. The iron stopped working after I kept the iron on high for an extended period of time. My electrician husband explained that I over heated the iron - breaking the fuse. Not time I'll turn the iron off or down when I'm not using it. This was so easy, I'm going to check out our other broken irons.
Posted on Dec 30, 2009
  • 1416 Answers
SOURCE: Euro Pro Irons: Less than a year old stop heating up.
hello,
some time no part of our property go bad but what will need is to service them from there dysfunction
the problem of your iron could be from the element and the wire ,the element is the heat provider while the wire is the power supply from the electric
But the fact is that ,the problem of your iron is disconnection of element from the wire what you need to do fix it to unscrew your iron and trace the wire down to the element and see the disconnection am toking about and fix it back
thank you and thanks for using fixya.
Posted on May 31, 2010
REPLACEMENT COVER FOR EURO PRO IRONING BOARD -WEDGE
you must contact your supplier vendor of iron in order to get the parts. or search in internet by Marconny appliance.
God bless you
Jul 22, 2012 | Irons
I have a Eurp-Pro 1000 ironing system. I need a new board cover and a manual
the instruc. manual download from www.fitness.manualsonline.com or www.retrevo.com
the parts go www.repairclinic.com or www.appliancepartspros.com
God bless you
Jul 18, 2012 | Irons
Manual needed
By the look of things its no longer covered by Shark-Euro-Pro (typical) http://www.sharkclean.com/cgi-bin/livew/site.w?location=mcopy.w&mcopy=manuals&frames=no&target=main&sponsor=000001&lang=en-US i know this is not a fix for you but i shall keep a look out for a manual.
Aug 01, 2010 | Euro-Pro EP5500 Iron
Euro Pro Shark Iron
Thank you for taking the time to warn us and others about the euro pro shark iron. I will help spread the word.
Aug 10, 2009 | Irons
Euro-pro EP1005 iron--iron heats -blower works-but no steam
You may not need a new iron, my wife's iron is doing the same thing. take the top of the ironing board off (you will need a torx t-20 security bit driver), under the tank is a connection that may have rusted out re-connet it and turn the iron on. Once it heats up, check the tank for leaks. The tank may need to be replace as well or try a 5-minute epoxy type glue on the leaks once it has cooled. If the tank leaks you will get not get enlugh pressure building up to get the steam.
Feb 05, 2009 | Euro-Pro EP1005 Iron
Shark euro-pro iron cord replacement model 4750
six screws on bottom plate two hidden under rubber feet on bottom under lower screw holes
Nov 18, 2008 | Euro-Pro Shark GI490 Iron
Shark euro pro G 1400z
how do you replace the light bulb on a shark euro-pro iron?
Oct 27, 2008 | Euro-Pro Shark GI475 Iron
Handle on iron gets too hot to hold onto. Product is an Euro-Pro Ironing Solution. Ironing system includes the iron and ironing board together.
Sep 23, 2008 | Euro-Pro EP1005 Iron
Jan 15, 2008 | Euro-Pro G6118 Iron
Irons Logo
88 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
