Question about GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator installed new 18 months ago. No ice
Refrigerator installed new 18 months ago. No ice production. 2nd incident. 1st time technician replaced on/off unit for icemaker.
    Sergeant:
  • 212 Answers
He should of replaced entire ice maker assy. sounds to me your module is bad.
Posted on Jun 22, 2009
    Sergeant:
    Champion:
  • 208 Answers
Check or replace the filter
How to trouble shoot GE ice maker that is not producing ice
Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ... www.youtube.com/watch?v=fPeZ29XdX5U
    • BY DIGITALPIMPLE
    • 4 MIN
    • 295K VIEWS
    • ADDED 2013-05-15
    Video embedded · How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair www.partselect.com/Repair/Refrigerator/Not-Making-Ice Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - products.geappliances.com products.geappliances.com/appliance/gea-support-search-content?... Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances products.geappliances.com/appliance/gea-support-search-content?... New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    Electrolux side by side model ew28bs85ks4 icemaker was making a grinding noise and just quit completely no ice what to do?
    If you can watch the icemaker run through it's cycle, with the door open of course, try and determine where it might be hanging up.
    I 'trimmed' part of the replacement kit installed by our Electrolux repair technician where it was hanging up with the motorized parts, about 5 months ago, and it began completing it's full ice-making cycle once again.
    Mar 28, 2014 | Refrigerators
    Water (and ice) in storage bin.
    What is the model number?
    Jul 07, 2013 | U-Line Icemaker
    Ice maker stopped dispensing
    Refrigerator - Icemaker Not Dispensing,or Not Making Ice Check that the feeler arm on the icemaker is in the down position and is not blocked. If the icemaker does not have a feeler arm make sure the icemaker paddle is not blocked under the icemaker. For more information on the causes of new icemakers not making ice. For more information on normal ice production. Side by Side models: The filter may be loaded with sediment that can cause low water pressure. The water pressure must be between 40 and 120 psi. Pressures below 40 psi may cause a malfunction of the icemaker (i.e. producing hollow cubes or no ice production). Test the water pressure: Dispense water from the dispenser into a large measuring cup for 20 seconds. If the measuring cup contains less than 13.5 ounces (400 metric centimeters), the water flow is inadequate. If the amount of water is less than 13.5 ounces then the refrigerator fails the test, remove the filter and test the refrigerator again with the by-pass plug in place. If the refrigerator dispenses the proper amount of water with the by-pass plug in place, then the filter should be replaced. If you no longer have the by-pass plug and it has been over three months since the filter has been replaced, you should replace the filter. If the refrigerator fails the test again and you know you have the proper water pressure in your home, you should call service to check the refrigerator. If the amount of water collected is over 13.5 ounces then the refrigerator passes the test and the dispenser is working correctly. Ice not Dispensing Due To Clumping Ice: Your dispenser may not be dispensing due to clumping ice cubes. The ice cubes in your icemaker may be clumping for a couple of reasons: Low food load: The defrost cycle radiates heat into the freezer. The ice in the freezer will naturally absorb the heat. This will cause the ice to melt slightly during defrost, then eventually freeze together in clumps. Increasing the food load in the freezer will buffer the warmth from the defrost cycle and keeps the ice from melting. Lack of use: When the ice bin is full, the pressure from the weight of the cubes can cause the bottom cubes to fuse and clump. To prevent this from happening, discard the clumped ice and check the bin periodically to ensure the ice is not building up. If you do not use a large amount of ice, move the feeler arm on the icemaker to the up position to turn off the icemaker and stop ice production. For more information on the causes of clumping cubes. If the ice bucket is not seated correctly, ice will not dispense properly. Make sure the ice bucket is in the correct position. Refer to Use & Care manual.
    Aug 05, 2012 | Maytag Refrigerators
    I own a Thermador Freedom Collection 18 inch Built-in Freezer Column with Exterior Ice and Water Dispenser Model T18ID80NRP and have had this unit for approx. 2 years as a companion unit to my Thermador...
    No solution but just a warning. We had this same thing happen. They sent a repairman to replace the control board. Then did it again. Just before Christmas, the WATER started dispensing by itself. Luckily, I was nearby and heard it or the damage would have been extensive from flooding. They are now 'working on' getting a response from Thermador. I feel like this thing is just a homeowners claim waiting to happen.
    Oct 28, 2010 | Thermador Freezer FREEDOM® T24ID80PLS
    Replace icmaker on kenmore
    Unplug refrigerator. Take a moment to examine how the icemaker is positioned in the freezer compartment prior to proceeding (e.g.: water inlet tubing coming into the icemaker, etc.). Remove or loosen (where applicalble) screws holding icemaker. Unplug icemaker's wire harness connection. install new icemaker by reversing the screws harness, etc. Make certain that the new icemaker is in the "on" position. Plug the refrigerator in. Allow approximately 6 to 8 hours (some models take fewer or longer timeframe) for ice production.
    Feb 10, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
    Will not dump tray...stops at 2:00 position, will not advance
    Possible cause of this is. 1st the heater is out. 2nd the motor in the icemaker has a dead spot. If heater then the complete icemaker should be replaced. If motor I would replace the faceplate.Part #150 Should be around $55 for part. You can find parts by visiting u-line at www.u-line.com and under customer service you will see parts locator.
    Jun 08, 2009 | U-Line Icemaker
    My ice maker won't make ice.I have a Frigidaire FRS26H5ASB5. Can you tell me what I can do?
    I had the same problem with my ice maker.
    I took it apart and cleaned the three switches inside the icemaker
    The switches are not a high enough amp rating so they burn the contacts. Keep in mine cleaning is temp fix.
    I did mine about 4 months ago and still working.
    I have new switches now that I will be installing as soon as it quits again. About $9.00 for new switches and about $130.00 for a new Icemaker!
    I hope this helps.
    Feb 23, 2009 | Frigidaire GLRS264ZA Side by Side...
    Side by side refrigerator icemaker not making ice. Hotpoint mdl HSS125IFMD Tried installing new filter. Getting water but no ice being made.
    I would first try replacing the solenoid valve which lets the water in. Also, how are the ice cube arms aligned? They should be vertical
    Jul 04, 2008 | Refrigerators
    GE (PSS26MSRSS) Side by Side Refrigerator Logo
    119 people viewed this question
    Top Refrigerators Experts
    Sal De
    Charles T Nevin
    Charles T Nevin
    Randy Justice
