Question about Husqvarna RZ5426 54" 26HP Kohler Zero Turn Lawn Mower 2012 Model
Where is the solenoid located on a husqvarna rz5426
Husqvarna 22/46 won't start,replaced solenoid still won't start unless I bridge the solenoid over.help?
sounds like you need to test the solenoid to be sure it is good. you may have a safety switch that is the problem. check them all and replace the bad one.
Oct 27, 2016 | Husqvarna Garden
Can I rebuild hydrostatic transmission
Ken, yes if you can get parts and maybe repair manual.
Mar 09, 2016 | Husqvarna Rz5426 54" Zero Turn Lawn Mower...
Husqvarna rz5426 will not go forward or backwards
definitely check the transmission drive belt for brake or wear
Sep 06, 2015 | Husqvarna Garden
Why does husqvarna tractor only start by jumping across the solenoid
it could be that the solenoid is bad i would try that they are realtivaly cheap and easy to put on make sure to unhook battery
Aug 16, 2014 | Husqvarna 23 Hp 48" Deck Yard Tractor
Where is the fuse located?
There should be a fuse holder clipped on the left side of the engine compartment (as you are facing the tractor) just below the solenoid.
Aug 24, 2013 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Riding mower will not start. I changedthe spark
The fuse is located just off the solenoid on the side the battery cable is hooked to. The solenoid is under the dash on the right hand side about 3 or 4 inched from the bottom
Jun 11, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna zero turn mower won't start
Usually if all you hear is a clicking noise, it is the solenoid itself that has gone bad...if you can jump the solenoid and the mower turns over, it is the solenoid.
May 01, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna RZ5426 54" 26HP Kohler Zero Turn Lawn Mower 2012 Model Logo
60 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
