Question about Garden
Flymo xl500 How do I adjust the throttle?
Flymo instruction manuals
www.flymo.com/uk/robotic-lawnmower-support
www.flymo.com/uk/contact-us
Jul 14, 2014 | Garden
Why wont my Flymo qs 46sd rev ?
does it have a throttle cable fitted?? you really dont need an idle as as soon as you release the opc or dead mans handle it will cut out anyway. engine should be reving at 3000-3100 rpm. if this mower has a briggs and stratton engine fitted, remove the air filter and check the spring and linkege is still attached to the air vane govenor
May 20, 2014 | Garden
Flymo xl500
Sounds like you are in need of a carb diaphragm. Also be sure you do not have a vacuum leak on the carb to block connection. You could also have a little water in the fuel. Cheap fix, rubbing alcohol, about a half cup. fill tank with fresh gas and run it through.
My thoughts.......................................
Mar 12, 2014 | Garden
My flymo 350 turbo compact isint cutting can i adjust the blade height ?
You can put spacers under the blade, a twin pack of spacers are available from Flymo part no. 513811081., from memory you are allowed to fit three spacers.
Aug 10, 2012 | Garden
I have a Husqvarna 55R21HV mower. Last week I stupidly hit a rock hidden in long grass and bent the crankshaft. I can pick up a spare engine off a Flymo XL500 or an engine alone advertised as having a...
Generally the bolt pattern is the same for most small pushmowers. If in question I recommend taking measurements, but when I went to swap engines on a pushmower they were the same, even with an almost 3 HP difference in rating.
In regards to changing the crankshaft, it involves the complete teardown of the engine to replace. Most people just replace the engine.
Jul 18, 2011 | Garden
My flymo gl47 does not get up to max revs,any ideas? Flymo starts but is running slow.
you can adjust the rpm on the carb underneath the fuel tank
Mar 06, 2010 | Garden
Cannot access motherboard on Gateway xl500
it have alock in the back push down while holding it and push lit in the back
remove screws if their is any
Apr 14, 2009 | Computers & Internet
FT500,,need exploded parts drawing of electronic start and gear drive,,to find out which way shims are placed ,thanks
As far as I know the FT500 has the same engine as the XL500...here's a link to the XL500 manual. Good Luck. Rate me if its useful..?
http://www.hondaxl.it/manuali.htm
Mar 20, 2009 | 1982 Honda FT 500
Changing the kick start shaft, for a 1982 honda XL500.
Hey count
You can get a complete manual from here I havnt downloaded it myself to check, but is a workshop manual. Follow the procedure on the manual :) I love tearing down and rebuilding engines :)
regards
robotek
Nov 20, 2008 | 1983 Honda XL 125 R
Flymo micro lite - cutting height of blade
you twist the plate holding the blades and it will lift off, then you turn the blade plate upside down and replace making sure you align the notches and then twist to lock into place. hope this helps
Oct 16, 2008 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
