Question about Wright Products EWTGBL Touch Push Button Latch Black
Wright Pushbutton Latch and Closure
Looks itself and thus locks me out
The door leaks on my Diplomat HJA 8640 DISHWASHER. I have changed the door seals with no luck
Malcolm,
Good for you replacing those seals. Not trivial, I suspect.
Does your DW have a positive latch closure or does it just close without a latch?
If the opening of your unit has become distorted due to gradual settling, even a new seal won't work properly. Look carefully and make sure the unit is "square" in the enclosure. If not, use the leg adjusters to correct the situation.
Also, when you replaced the seal, you no doubt cleaned the door thoroughly, since debris can accumulate (especially along the bottom of the door) and interfere with closure.
Use a flashlight for a thorough visual inspection!
Oct 24, 2016 | Dishwashers
How do i remove thehatch door pushbutton?
you need to remove interior trim panel and removed 4 or 5 nuts to remove the license plate light assembly to gain access to the pushbutton switch. the latch asy could be back if it don't open the hatch
Apr 30, 2014 | 2008 Ford Escape
I put the latch on the door and the handle won't push in. When I loosen the screw, it is too loose
The actuating bar (the push rod) that actually works the lock was not properly sized. They are very finicky. If you cut it just a bit too long or too short it will cause all kinds of problems.
Apr 01, 2014 | Wright Products International VC333BL...
The microwave works at times and then does not work. What is wrong? a Switch?
Full closure of a microwave door is a serious safety item. Check the door for full closure. Is there anything in or on the hinges that might resist full closure. Check the latch mechanism for foreign objects even food on the latch. Also check around the sealing point around the entire door and mating seal. Closure should be a distinct snap.
Feb 20, 2014 | Frigidaire Kenmore Washer Tub to Pump Hose...
Dishwasher turns itself on and beeps periodically but does not start
Seems to be a faulty door latch...it wants to start but the computer thinks the door is still open and wont allowing it to continue, thus turning off. Try playing with the door latch before opening it up and looking within the latch.
Dec 02, 2013 | LG Dishwashers
Need instructions
The owner's manual will tell you step by step how to program it. Normally you would follow these steps (with the engine off):
1. Press and hold down the two outsid buttons releasing only when the indicator light begins to flash.
2. Position the end of your hand-held transmitter about 1 to 3 inches away from the buttons while keeping the indicator light in view.
3. Simutaneiously press and hold both the desired button and teh hand-held transmitter button. Do not release the buttons until the indicator light flashes slowly at first and then rapidly. Then releas both buttons.
4. Press and hold the newly-trained button and observe the indicator light. If the indcator light stays on constantly, programming is complete and your garage door should activate when you press the button.
Nov 26, 2013 | Wright Products International VC333BL...
Hood latch won't stay in locked position. Hood is 1 quarter inch high.
There should be rubber bumpers on the bottom of the hood where the latch is. They are located on either side (and ends). Screw them inward for lower closure.
Apr 29, 2012 | 1999 Oldsmobile 88
Front passenger side door will not close because closure latch is engaged. how do I disengage closure latch to close door?
Just use a screwdriver to fit into the area where the latch part lock onto the bar, pull the handle you use to open it while prying/pulling the screwdriver & the jaws will open again to allow it to close.
good luck.
Feb 13, 2010 | 1999 GMC Suburban
Front hood wont lock closed. i drop the hood and it doesnt catch. it catches on loosely but not the secure closure
you have a problem with your primary hood latch, your secondary latch keeps it from flying up into your windshield. inspect the pri. latch, it may have stuck and won't close. a thorough soaking with a good penetrating oil usually frees it up. if not you may have to replace the latch.
Dec 19, 2009 | 1998 Honda Accord
92 Accord. Driver door not opening. Lock works. Took inside cover off. Rods going in to the Lock don't seem to be grabing any thing to open the door?
It sounds as though one of the rods (the one leading from the inside door handle to the latch, called the release rod. The other is called the lock rod) has slipped out of the latch at the door closure. Since you have removed the door liner (and the plastic skin, I assume) you should be able (with your window all the way down) to see what the situation is through the access hole near the lock/latch portion of the door. If the rod that hooks into the inner door handle doesn't feel as though it is connected to anything (when you pull it toward the front of the car) then the other end of that rod (the latch connection) has either broken or simply slipped out of the hole that it goes through (and may have fallen down some). There is normally a plastic rod retainer or something of that sort at both ends of that rod, to keep the rod in the holes it's supposed to go through. Sometimes they break of work loose. Take a careful look and you will probably be able to see if that is the problem. You say that the lock works. Does the outside door handle work? If so, that tends to indicate that there is nothing wrong with the latch itself.
Oct 22, 2009 | 1992 Honda Accord
Wright Products EWTGBL Touch Push Button Latch Black Logo
Top Wright Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Wright Hardware and Accessory Expert? Answer questions, earn points and help others
