Question about LG Flatron Ez T710BH 17" CRT Monitor
LG FLATRON T710BH no display with power led blinking
  • 124 Answers
SOURCE: I want drivers for this monitor LG Flatron Ez
Go Here. For software.
http://www.lge.com/download/939186678T710BH_J-T710BH.zip
Hope this helped. Please rate. Good Luck! Need more help send comment & i will be back.
Posted on Mar 13, 2009
ginko
  • 19396 Answers
SOURCE: LG 700E monitor's power LED blinking continueously, no display
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Apr 22, 2009
ginko
  • 19396 Answers
SOURCE: monitor light blinking
  • Video cable.
  • Motherboard.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
SOURCE: LG Flatron ez t713sh 17" CRT Problem:
I already have the solution to that problem. It is a faulty capacitor that needs replacement. If you want you can copy and paste this link http://loversdelight-ididitmyself.blogspot.com.
Posted on Jun 22, 2010
SOURCE: I have lg flatron l1730s
I have lg flatron l1730s lcd black color monitor. I have problem with this. Power not come. some time when i connect it power LED blinking once then no display.
Posted on Nov 11, 2010
How to opan lg crt monitor back case
TILT/SWIVEL & BACK COVER REMOVAL
1) Set the monitor face downward.2) Carefully remove the Tilt/Swivel by pulling it upward.3) Pressing the latch (b), Back cover by pushing it upward.4) Release the latch (c). (See Tip Spec.)5) Slide the Back Cover away from the Front Cabinet of the monitor.
Oct 28, 2011 | LG Flatron Ez T710BH 17" CRT Monitor
LG flatron T13SH no display with power LED fast blinking.
no video signal - video card broke down or screen resolution is to high
try boot in safe mode and un install de video card
Feb 20, 2011 | LG Flatron Ez T710BH 17" CRT Monitor
I have lg flatron l1730s lcd black color monitor. I have problem with this. Power not come. some time when i connect it power LED blinking once then no display. Some time when i connect it power LED...
Oct 14, 2010 | LG L1730S 17" LCD Monitor
I am having a blurred display on my LG flatron Ez T710BH 17 CRT monitor. The pictures are better but the text is almost illegible. Please help me. The problem started when I sent it to a repair shop. I...
Ya gotta be kidding! You still have a CRT monitor? CRTs have a focus adjustment around the neck of the big tube. The shop screwed it up. Spend $50 and get a nice used LED or LCD flat screen.
Sep 04, 2017 | LG Flatron Ez T710BH 17" CRT Monitor
NO DISPLAY AND THE POWER LIGHT IS JUST BLINKING ON MY LG FLATRON T713SH MONITOR... HOW CAN I FIX IT? ANY GUIDE FOR TROUBLESHOOTING THIS KIND OF PROBLEM?
u better to check the VGA connection to the PC and power on the monitor.power on located at the booton part of the monitor
Oct 03, 2010 | LG Flatron Ez T710BH 17" CRT Monitor
I have the same problem!!
it is a hardware problem. so pls checked it from vendor.
Sep 09, 2009 | LG Flatron Ez T710BH 17" CRT Monitor
THE POWER LED (GREEN) IS BLINKING CONTINUOUSLY
LG 700E monitor's power LED blinking continueously and there is no display solutin ........
May 30, 2009 | LG Flatron F700B 17" CRT Monitor
I want drivers for this monitor LG Flatron Ez T710BH
Mar 13, 2009 | LG Flatron Ez T710BH 17" CRT Monitor
Jun 30, 2008 | LG Flatron Ez T710BH 17" CRT Monitor
LG Flatron Ez T710BH 17" CRT Monitor Logo
43 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
