Question about Ducane F7011013
My regulator exploded; where can I purchase a replacement?
  • 11,896 Answers
You can get the regulator from:
ducanepartscenter.com
or
allpartsgrills.com
or
US-Appliance.com
Posted on Jun 22, 2009
Gas doesn't seem to be flowing
I purchased this heater second hand - I have fitted a brand new regulator and gas hose - gas is flowing as far as the burner assembly but I cant hear or smell gas flowing to the pilot or the main burner. Is there a section of pipe between the gas hose and the burner that could be missing? Does anyone have a diagram of all the parts - exploded view?
May 30, 2014 | Stainless Garden Sun Steel Propane Patio...
How do you install a moter for a right side passenger side on 1987 calais
See Figures 1 and 2
Fig. Fig. 1: Location of the front door window regulator-1995 vehicle shown
Fig. Fig. 2: Exploded view of the rear door window regulator-1995 vehicle shown
  1. Remove the window regulator assembly from the door.
  2. Remove the motor from the regulator by drilling out the attaching rivets with a 3/16 in. drill bit.
To install:
  1. Connect the window motor to the regulator with 3/16 in. rivets.
  2. Install the window regulator assembly.
icn_arrow.gifBack to Top
Apr 30, 2012 | 1986 Oldsmobile Calais
Need Instructions on replacing fuel regulator on 1987 chevys10 pick up 2.8
Fuel Pressure Regulator - REMOVAL & INSTALLATION(see Figures 1, 2, 3, 4, 5 and 6)
  1. Relieve fuel system pressure. Disconnect the negative battery cable.
  2. Clean dirt and grease from the regulator retaining ring.
  3. If equipped with a bolt on-type pressure regulator, remove the fuel return line from the return tube by squeezing the tab and pulling it off.
  4. Disconnect the vacuum line from the regulator.
  5. If equipped with a bolt on-type regulator, perform the following:
    1. Remove the regulator attaching bolt(s)/screw(s) from the bracket.
Image LINK
Fig. 1: Remove the 2 fuel pressure regulator-to-rail attaching bolts (fuel rail removed from vehicle)
  1. If equipped with a snapring-type regulator, perform the following:
    1. Remove the snapring from the regulator.
  2. Wrap a towel around the regulator to catch any fuel that may escape. Remove the regulator from the fuel rail using a twisting and pulling motion.
Image LINK
Fig. 2: ... then remove the regulator by using a twisting and pulling motion
  1. If equipped with a bolt on-type pressure regulator, disconnect the fuel return tube assembly from the pressure regulator.
  2. Cover all openings with masking tape to prevent dirt entry. If the regulator is being reused, inspect the filter screen, if equipped, for contamination. If contamination exists, replace the filter screen
Image LINK
Fig. 3: Exploded view of the regulator mounting on the fuel rail - VIN K engine shown
Image LINK
Fig. 4: Some regulators, such as this 1995 VIN L, are secured with a mounting bolt
  1. If further disassembly is necessary, perform the following:
    1. Remove the small regulator O-ring.
    2. Remove the regulator filter screen.
    3. Remove the large regulator O-ring.
    4. Remove the O-ring back-up.
Image LINK
Fig. 5: Exploded view of the regulator housing (1), small O-ring (2), filter screen (3), large O-ring (4), O-ring back-up (5), regulator (6) and snapring (7)To install:
  1. If the regulator was disassembled, perform the following:
Lubricate all O-rings with clean engine oil prior to assembly.
    1. Install a new regulator O-ring back-up and large O-ring.
    2. Install the regulator filter screen.
    3. Install the small regulator O-ring.
  1. If the regulator is not being replaced with a new one, lubricate new O-rings with clean engine oil, then position them on the old regulator.
Image LINK
Fig. 6: If the regulator is not being replaced, remove and discard the old O-rings
  1. If necessary, connect the fuel return tube to the pressure regulator and secure with the retaining nut. Tighten the nut to 13 ft. lbs. (17 Nm).
  2. Install the regulator into the regulator housing and seat with even pressure.
    1. Install the snapring or retaining bolt(s)/screw(s), as applicable.
  3. Attach the vacuum line to the regulator.
  4. If removed, connect the fuel return tube to the pressure regulator.
  5. Connect the negative battery cable.
  6. Turn the ignition switch ON and OFF to allow fuel pressure back into system. Check for leaks.
Hope helps.
Oct 01, 2011 | 1987 Chevrolet S-10 Pickup
I have a Liebert PSA470-120 on one of my computer controlled casting machines. Last night the battery exploded, blew out one of the side walls. Can I just replace the battery or is the voltage regulator...
Personally I would not just get a battery and go for it after an explosion that blew out a wall makes sense to me for you to contact the manufacturer and as some questions and purchase another battery system that is more stable. That would be my worry something blowing out my walls is critical and needs to be addressed what do you think? Thanks for using FixYa! John
Apr 13, 2011 | Liebert PowerSure ProActive PSA470...
Where is the voltage regulator on my 1991 honda accord?
Hello! It is inside the alternator...See exploded diagram...Diode rectifier assembly...It is important to know that a voltage regulator will cost around $100...An alternator $150...
Guru..........Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Feb 05, 2011 | 1991 Honda Accord
We were watching tv , than there was a loud pop noise tv went blank cant turn it on
Best bet is to call a technician, as it sounds like something has died inside. If its under warranty, call the place of purchase to organise for it to be dealt with.
Jan 10, 2011 | Sanyo DP37647 37 in. LCD TV
Replace rear door window motor?
GM Grand Am/Achieva/Calais/Skylark/Somerset 1985-98
Electric Window Motor -REMOVAL & INSTALLATION
Fig. 1: Location of the front door window regulator-1995 vehicle shown (click for zoom)
Fig. 2: Exploded view of the rear door window regulator-1995 vehicle shown (click for zoom)
To install:
Hope helps (remember rated this).
Jul 08, 2010 | 1997 Buick Skylark
Can a voltage regulator/rectifier if not working properly blow the main fuse. I have a 2002 v-star 1100. I was riding when all of a sudden the bike died on me. I lost all power no light, turn signals,...
YES!
Good link here:
http://www.flygenring.dk/yamaha/artikler/1100ChargingSystem.pdf
Symptoms:
Lights flickering at times and/or battery gets hot to the touch
Problem:
Reglator/Rectifier
When the regulator dies, it allows as much as 19 volts to appear across the battery. This is not good. It will cook the battery and the battery could even explode. Fuse can not stand up to this!
Oct 05, 2009 | 2000 Yamaha V Star 1100 Classic
EXPLODING SAECO VIA VENETO
I think your machine is overheated, try to replace the thermostat on the boiler.
May 25, 2007 | Saeco VIA Veneto Espresso & Coffee Maker
Ducane F7011013 Logo
101 people viewed this question
Top Ducane Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Marvin
Marvin
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
