Question about Panasonic WORKiO DP-1820E All-In-One Laser Printer
Same issue as the other user.
Have a network copier/printer i want to print to with my iMac computer...having a problem finding a driver for it. How do I put a PC post script driver on my iMac?
    Champion:
  • 224 Answers
Copystar CS-C3225 color copier scanner. The Scan to Email quit working. It says Unable to find SMTP server. A Windows box and an iMac print to this. We updated the driver on the iMac for this and n
Updating a driver would not affect the mail server settings. could be a firewall issue but i doubt it. is the smtp server on your lan or are you using a hosted mail solution? the only things that matter there are the ip address of the smtp server, authentication, ssl (or not), port numbers, default from address, dns settings, and message size. the mail function is totally independent from you computers operation unless an on site server or workstation is hosting the smtp server.
Jan 10, 2013 | Copystar Cs-C3225
How do I find ip address for Hp inkjet F2100 so that I can print from my iphone with eprint. I have an imac
This model printer does not have a network print server and therefore does not have an IP address. Theprinter uses an USB connection to connect to a computer.
Go to this WEB site to download a user manual.
http://h10032.www1.hp.com/ctg/Manual/c00901032.pdf
Aug 23, 2011 | HP PSC 1610 All-In-One InkJet Printer
I have two computers on my network, an iMac and a PC running Windoew 7. I recently purchased the Lexmark Pro901 and installed it on the network. It(the Lexmark Pro901) seems to connect fine to the network...
It could be a software issue. Try to uninstall the existing Lexmark Pro901 driver from your desktop pc by going to Start menu -> Programs -> Lexmark -> Pro900 Series -> Uninstall Lexmark Pro900 Series. Reboot pc when prompted.
Now, check your Windows 7 if it's running on 32-bit or 64-bit by going to the Start menu -> right-click on Computer -> Properties. Take note of the System Type.
To reinstall, download the Lexmark Pro900 Series driver using the links below: - Lexmark Pro901 driver for Windows 7 32-bit - Lexmark Pro901 driver for Windows 7 64-bit
Download, execute the file and follow the instructions on the software.
I hope this information has been helpful. Thanks.
Jan 04, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
Describe your hp business inkjet 1200 dn driver Problem I couldn't find an exact driver match for my iMac with OSX 10.6.4. Now it won't print on both sides and the tools don't work (such as cleaning the...
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Oct 26, 2010 | HP Inkjet 1200dn Printer
I have a Windows printer set up for the Ricoh 12332C. Jobs are sent and clear the queue, but do not print. They appear to be accepted by the Ricoh - they show in the job history log, but they do not print...
Usually the setting of yout network with your copier/printer setting is mismatched so your printer.copier did not understand. What you can do you should check the system setting of your copier/printer and print it out then you should find the driver of your printer/copier in the add printer hardware secrtion in control panel of your computer network . Before you reinstall it , you should uninstall the previous driver so there is no conflict when you reinstall new driver . Try it
Apr 17, 2010 | Ricoh Aficio 1232C Color Copier
Network Printing Issue. I'm running 2008 Domain Controller 2003 File and Print Server. Cisco 3560G switches No 3rd Party print management software User workstations are all Windows Xp Pro SP2 Printers are...
DNS errors then? can you map to the printer via hostname too? Are you sure you're not using SP3? When we upgraded to SP3, we had to use the new drivers. Try new drivers.Have you tried just rebuilding your print server? try sharing the printer off your computer in the data center and try t print to that. When you ping the data center from the user's computer... what is the delay?
Oct 13, 2009 | HP LaserJet 4250n Printer
Just purchased an iMac computer for my HP DeskJet 880C
You can log on to the hp site and get the current driver/printer software for your printer. Get the mac os version and install via usb. Download and install then restart your imac... then attempt a print...
Should work fine with an iMac.
K
Sep 01, 2009 | HP DeskJet 880c InkJet Printer
Panasonic WORKiO DP-1820E All-In-One Laser Printer Logo
63 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
