The blue light on thehaier ls working but nothing else ?
Haier
My haier tv stayed in USB mode and just froze there off and on probe responds to the control and nothing. prove with the buttons on tv and neither worked
press on you remote repeatedly the keay "back", the screen will turn blue, then press "input" and select your option, it should work.
Mar 07, 2014 | Haier HL32D2 32 in LCD TV
Have a Haier HLH26ATBB. After pressing the power-on switch red light will turn to blue (as a power-on indicator) and the blue screen of the LCD with the word "HAIER" will appear but only for a second then...
Main board fault. Almost all Haier LCD models will have the similar main board. Contact any service technician. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Try this link too. http://electro-medical.blogspot.com/
Jan 10, 2014 | Haier HLH26ATBB 26 in. LCD Television
My brand new flat screen haier tv 39'' is flashing white then red green then blue and black screens how do i fix
Try to disconnect the set and a box if being used from power for a while and then power both back as either could cause this problem.
Dec 15, 2012 | Haier Televison & Video
Haier 8000 btu thru the wall ac wont come on
try ot unplug for 2 minutes,,, and try again may have fuses inside also
Jul 03, 2009 | Haier hwr10xc6 Air Conditioner
Nothing works
i had exactly the same problem but not anymore. i called the haier co. and they told me to order a new remote control so i did. i got my new remote and i turned my tv on and pushed the tv/use and it worked thank god. so maybe you could try it. remote control only 20.00 good luck!
Mar 14, 2009 | Haier HP42BB 42 in. Plasma TV
My Haier pv50v6-a8 won't turn on
From your description it is not clear unit shuts off or the blue power indicator stays on?
If you have blue light stays on there is nothing wrong wtih power supply.
You need to trouble shoot either on Y-sus or Main board.
Good luck
Dals123.
Sep 30, 2008 | Haier HP50B 50 in. Plasma Television
Haier HDN305 Dehumidifier
agaver
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Thanks qrx1llb3 for the help!
After carefully removing the plastic covers (yes, u need to remove both, I removed first the back one then the front one by pulling up, then disconnect the cable that joins the panel on the front cover with the electronic board on the upper right area) I found the electronic board with the blown up fuse. My was under a blue plastic cover. I'll try to replace it and see what happens! thanks for the help! :)
Jun 27, 2008 | Haier HDN655E Dehumidifier
Haier 50 inch plasma not turning on properly
try changing to other inputs and move the connection along with it
Apr 08, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
