Question about Universal Pacesaver Boss 4.5 Scooter Battery - UB12550
WHAT DOES IT MEAN WHEN FLASHING SPEED LIGHTS ON VSI JOYSTICK?
How do you reset the chair when all the lights are flashing?
Hand control is locked. turn chair on push joy stick forward til it beeps then pull it back until it beeps then put it in neutral ( joy stick in the center) then it should be unlocked.
LOCKING/UNLOCKING THE VSI
The VSI has a feature that enables you to lock your power chair to prevent
unauthorized use.
To lock the VSI:
1. With the VSI powered on, press and hold the on/off key. After one (1)
second, the VSI should beep.
2. Release the on/off key.
3. Push the joystick to the full forward position until the VSI beeps.
4. Pull the joystick to the full rearward position until the VSI beeps.
5. Release the joystick. There should be a long beep.
6. The VSI is now locked.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile
indicator should ripple side to side.
May 30, 2014 | Pride Jazzy 1103 Ultra Standard Power...
Tip
VSI joystick constantly flashing
You may have mistakenly locked your joystick. Here is a tip on how to lock and unlock it.<br /> <br /><b> <p>LOCKING/UNLOCKING THE VSI<br /></b> <p>The VSI has a feature that enables you to lock your power chair to prevent<br /> <p>unauthorized use.<br /><b> <p>To lock the VSI:<br /></b> <p>1. With the VSI powered on, press and hold the on/off key. After one (1)<br /> <p>second, the VSI should beep.<br /> <p>2. Release the on/off key.<br /> <p>3. Push the joystick to the full forward position until the VSI beeps.<br /> <p>4. Pull the joystick to the full rearward position until the VSI beeps.<br /> <p>5. Release the joystick. There should be a long beep.<br /> <p>6. The VSI is now locked.<br /><b> <p>To unlock the VSI:<br /></b> <p>1. Press the on/off key and power on the VSI. The maximum speed/profile<br /> indicator should ripple side to side.<br /> <br /> Good Luck<br /> <br /> mimobility<br />
on May 05, 2011 | Health & Beauty
Tip
UnLocking Sleep and Lock Modes for Pride and Invacare power chairs
<p><b><span>Pride Joysticks and others that use VSI joysticks</SPAN></B><br><p><b><span>SLEEP MODE</SPAN></B><br><p><span>Your VSI controller has a sleep mode feature. Sleep mode is a built-in circuit </SPAN><span>that automatically shuts off the main power if the joystick is not moved </SPAN><span>in any direction for a period of time predetermined by controller program.</SPAN><br><p><span><b>The battery condition meter lights on the keypad indicate sleep mode by </b></SPAN><span><b>blinking once every five seconds.</b> To restore power and continue, push the </SPAN><span>on/off key twice.</SPAN><br><p><span> </SPAN><br><p><b><span>Lock Mode</SPAN></B><br><p><b><span>To unlock the VSI:</SPAN></B><br><p><span>1. Press the on/off key and power on the VSI. <b>The maximum speed/profile </b></SPAN><span><b>indicator should ripple side to side</b>.</SPAN><br><p><span>2. Push the joystick to the full forward position until the VSI beeps.</SPAN><br><p><span>3. Pull the joystick to the full rearward position until the VSI beeps.</SPAN><br><p><span>4. Release the joystick. There should be a long beep.</SPAN><br><p><span>5. The VSI is now unlocked.</SPAN><br><p><span> </SPAN><br><p><i><span>Invacare and others that use SPJ+ joysticks</SPAN></I><br><p><i><span></SPAN></I><i><span>FOR SPJ+ Joysticks</SPAN></I><br><p><i><span><b>Lock Mode will be indicated by all LEDs</b></SPAN></I><br><p><i><span><b>flashing briefly and the information gauge</b></SPAN></I><br><p><i><span><b>LEDs chasing slowly from right to left</b>. If</SPAN></I><br><p><i><span>this occurs, press the horn button two times</SPAN></I><br><p><i><span>within ten seconds to unlock the joystick.</SPAN></I><span></SPAN>
on Nov 16, 2010 | Health & Beauty
Unlock the controller
Locking/Unlocking the VSI
lock your powericon1.png chair to prevent unauthorized use.
To lock the VSI:
1. With the VSI switched on, press and hold the on/off key. After 1 second, the VSI should beep.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speedicon1.png/profile indicator should ripple up and down.
Mar 16, 2014 | Pride Mobility Products Jazzy 1170 XL Plus
When i push power button on lights blink constantly, wont move
For future reference, here is the is a procedure for
To lock the VSI:
To unlock the VSI:
Mar 16, 2014 | NRS Hoveround MPV 5 - Used Power...
Speed lights flash and machine will not run
Hi patriped,
Sometimes we lock our joystick by mistake.
Here is how to unlock it.
If this dosen't fix the problem you may have a bad joystick. Write me back for more info if thats the case.
unauthorized use.
To lock the VSI:
To unlock the VSI:
Good Luck
mimobility
Jan 27, 2011 | Pride Jazzy 1113 ATS Indoor Power...
Control flashing to light
unauthorized use.
To lock the VSI:
To unlock the VSI:
Try this. If it is not locked write back with more info.
mimobility
Jan 12, 2011 | Pride Jazzy Select 6 Indoor Power...
Jet 3 flashes "code 7".
The VSI joystick controller of the Jet 3 with a flash code of 7 LEDs flashing on the battery condition display indicates a possible joystick fault.
The most likely problem is with the joystick gimble. You can also get a 7 bar flash if the joystick is out of the neutral position at start-up.
Run the joystick in a circle and back and forth feeling for any sticky or broken/dead spots. Check to see if the spring and gimble come back to center when you release it. Turn off the VSI and try centering the joystick. Turn the VSI back on and see if you can get the fault to clear.
The only recourse is to have the unit rebuilt or replaced . A rebuilt VSI will run about $500 and a new one about $1600. For this reason it is best to check with your insurance before performing the work to see if its a covered item. Hope this helps
Nov 30, 2010 | Jet 3 Ultra Power Chair
My chair wont move the lite diplay shows 7 lights the joy stick feels like it is out of the sosket
If you have a vsi joystick seven bars means there is a possible joystick trip
a joystick trip is indicated . Make sure the joystick is in the center postion before switching on the VSI.
It may also be locked try this.
unauthorized use.
To lock the VSI:
To unlock the VSI:
Good Luck
mimobility
Oct 08, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Lights on joy stick controller blink on and off and chair wont move
Cezna Are the lights that are blimking the battery level lights or they the speed level lights. If it is the speed level lights then the chair thinks you still have the charger plugged in. If it is the battery level lights do a certain number of lights flash 3 lights flashing 4 lights flashes etc this is the flash code and will tell you what problem you have. It could also mean that you are in lockout or sleep mode If you have the VSI joystick then turn on the power immediately push the joystick forward and hold until you hear a beep then mmediately push it to the rear til you hear a beep then immediately let it return to the center position. If it was in sleep mode this should wake it up. Hope this helps you
Sep 13, 2010 | Pride Jazzy 1650 Heavy Duty Power...
Universal Pacesaver Boss 4.5 Scooter Battery - UB12550 Logo
41 people viewed this question
Top Universal Health & Beauty Experts
MobilityRepairSpecia...
Level 1 Expert
Robin Hill
Robin Hill
Colin Taylor
Are you an Universal Health and Beauty Expert? Answer questions, earn points and help others
