Question about Brother MFC 420CN All-In-One InkJet Printer
Getting error TW004 for Brother MFC8860Dn printer. Trying to scan document to printer
Mix-it-up
  • 832 Answers
SOURCE: MFC-420CN scanner error
This might be a hint: http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000100/000082/faq000182_001.html?reg=us&c=us&lang=en&prod=mfc420cn_us&Cat=8 another one is this: http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=mfc420cn_us&type2=6&flang=English&dlid=
Posted on Oct 05, 2007
  • 7 Answers
SOURCE: NO CONNECTION (LAN) on Brother MFC-440CN
I had the SAME problem. I have 3 pc laptops and 1 Mac. The Mac could still print, but the pc's were hosed. I called BrotherUSA and this fixed the problem!
Go to your printer and after making sure it's connected to the network with the Ethernet cable, go to Menu > Print Reports > Network Config. This will print a page that shows your printer's IP address. We need to config that address in your Printer, Fax and Scanner settings in Control Panel.
Go to Control Panel > Printers & Faxes. Right click on your printer > Properties > Ports tab. Click Add Port and select Standard TCP/IP Port. Click New Port and click Next on the wizard. Enter the IP address of your printer in the first field (the second one will auto-fill). Click Next and Finish. Printer's done!
Right click on your PC-FAX in Printers & Faxes and Properties. Click on the ports tab and just check the box that you just created for Standard TCP/IP Port. Click OK. Fax is done!
Go back to Control Panel and select Scanners & Cameras. Right click on your printer/scanner > Properties > Network Setting tab. Select the Specify your machine by address radio button and, if it's not already in there, enter the IP address of your printer. Click OK. Scanner's done!
This will work as long as your router is running. You may need to repeat this process after a power outage or if you need to reboot your wireless router. Not too bad, though! I just wish everything was as easy as a Mac!!!
Posted on Aug 27, 2009
SOURCE: Bad Scan Quality Using Brother MFC-7820N Document Feeder
Look to the left side of the flatbed glass for a thin strip of glass by itself. When you scan from the glass, the document stays put and the sensor moves across the document. When you scan from the feeder, the sensor stays in that glass strip and the document moves across the sensor. See what I mean? I would check the small feeder glass for dirt or scratches from staples or other flotsam. Also not a bad idea to blow out the feeder path with some compressed air to ensure the documents is handled smoothly. Hope this helps!
Posted on Nov 11, 2009
  • 159 Answers
SOURCE: Can't scan to PC with Brother MFC 8840D
My guess is a driver problem. I'm assuming you can print to it, so you know the USB connection is good. And you can make a copy (I assume), so you know the scanner mechanism and its connection with the rest of the machine works.
The scanner driver is separate from the printer driver. It's entirely possible to install and use the printer without having loaded the scanner driver. Best bet is to unplug the unit from your computer, then uninstall it completely from Windows. There may be an Uninstall program listed under Brother in your Start menu...All Programs... Or go to Start...Settings...Control Panel (or however your version of Windows get there) and open your Scanners and Cameras folder. If you find the Brother machine in there, Select it and click Remove. Do the same in the Printers folder.
Don't plug your machine back in until you have reinstalled the drivers. Go to www.brother-usa.com, and in the Service & Support box on the right, click Downloads. That will take you to a page where you'll select Multi-Function as your Product Group, then the model.
You'll get two lists of links. Forget Manuals, look at Drivers on the right.
Under Type of Software, click ALL. Select your OS.
You'll get a list of drivers and utilities for your model. Select the Full Package. Brother makes you accept the Terms of Use, then starts the download.
Look for Setup.exe in the main directory, or you may need to browse folders labeled with different language abbreviations to find it.
Start the installation, and don't plug your USB cable in until the computer tells you to. it will install the printer first, then return to install the scanner. It may require you to restart Windows more than once. Sorry.
Once you've suffered through all that it should be fine.
Posted on Dec 24, 2009
Hp 3050 scanning error message
Good day!Try to check the feeder if it has paper on it..then try on and off the printer until it holds normal status..
mastergani
Mar 29, 2010 | HP LaserJet 3050 All-In-One Printer
I have a brother MFC 9440CN when I try to scan a document the error message comes up as not being connected to pc. The cable is definitly connected as the print option works fine. Can you help. Thank you.
Are you scanning from the PC, or are you scanning from the printer?
If the latter, the scanner is trying to send the document to a server software on the PC, which is probably not running; hence the "not connected" message.
Try acquiring a picture using Control Panel -> Scanners -> Acquire Image and see if it works. If it does, you must run (or reinstall) the Control Center software, and configure it as to where to store the Scan-to-File documents.
Nov 02, 2009 | Brother MFC-9440CN Laser Printer
Trying to scan document getting message "check cable"
The Brother All-In-Ones require the Brother control panel software to be loaded on a PC before you can successfully scan a document. You can download the software for either PC or Mac from www.brother-usa.com - Good luck!
Oct 22, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 8460N error cc3-003-00031c0e
1.Uninstall all of MFL Pro
2.Delete HKEY_CURRENT_USER\Software\Brother\ControlCenter
3.Delete HKEY_LOCAL_MACHINE\SOFTWARE\brother\ControlCenter 4.Reinstall MFL Pro
Aug 02, 2009 | Office Equipment & Supplies
Scan to OCR error message
remove all associated driver and scanner software reinstall all the software with the scanner and printer disconnected then rebootit all connected. Try again
Jul 24, 2009 | Brother MFC-9840CDW Laser Printer
Brother mfc8860dn what do you mean by sort button
The sort button is one of the 6 buttons on the bottom right side of the control panel within the series of buttons in the COPY controls. When making multiple copies of documents with more than one page, it tells the MFC to sort the multi-page coping jobs into the correct order of the original document rather than the seperate individual pages.
Mar 07, 2009 | Brother MFC-8860DN Printer
Brother MFC 9840CDW
I'm trying to get my Brother MFC set up to scan to e-mail and open a new email with the scanned document attached. I am independant and not connected to any other service as I am a one man user operator.
Sep 10, 2008 | Brother Multi-Function Center MFC-240C...
Oct 01, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
1,645 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
