Question about Freezers
My freezer is not blowing its usual fog. Could it be because the door was not closed tightly last night? The fan does sound a little weak.
    Sergeant:
  • 212 Answers
Could have a slow turning evaporator fan motor. put thermostat in freezer and check temp.
Posted on Jun 22, 2009
Door was not shut tight. A loud buzzing sound recently went off and only stops when we unplug or turn off freezer. :(
loud buzzing I believe is an alarm that is waring you that the freezer is not cold enough. Door problems can be fixed. Test is to stick a dollar bill in the door and shut it. It should be a little hard to pull the bill out. Do this all over the door and find all the bad places. One problem is that the door can become warped by banging it against something or kids hanging on it etc. If you can see the warp you can actually bend the door back into place by holding the bottom of the door and moving the top in the necessary direction. Like jamming your foot against the bottom and pulling on the top or putting a box at the bottom of the door to hold it open and push the top. Next many time the bad fit door is because a hing has moved. All the hinges are adjustable. Usually you loosen the screws and move the door in the appropriate direction and re-tighten the screws. These screws are very tight so you need a big screwdriver and someone big to turn it. Lastly you can purchas a completely new door seal and put it in..
Sep 22, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Moisture forming on inside of freezer
is there anything that's preventing the door from fully closing( too fully)? the door gasket might be the culprit (problem).
May 04, 2010 | Frigidaire 13.7 cu. ft. / 388 liter...
Door will no vacuum seal closed
Are you sure compressor is running? If it is make sure the evap fan is running. You should be able to hear the fan when you open the door. If ypou do not hear a fan running then fan has gone bad. 4390914 and approx cost is rediculous in my mind but it is approx. 150.00 to 160.00 . Crazy for a fan motor.
Jan 28, 2010 | Whirlpool 17 cu. ft. / 481 liter Upright...
Combination cooler/freezer will not get blow 30
a coil covered in ice is one of two things
your defrost is not working or your circ fan is not working
make sure the fan inside is free and spinning
the make sure your defrost timer is operational
the bev airs are usually right in front behind the toe kick
short of that ohm out your heater to ensure its working
Oct 23, 2009 | Freezers
Small patch of ice if frost free freezer
Frost free does not mean no frost ever anywhere. It just means that there is a mechanism to defrost the evaporator on a regular basis. If there is a spot where frost is forming in the box it may just mean that a little bit of moisture that is not collected on the coil may be finding another cold spot to stick. The area where the fan blows into the cabinet is bound to be the coldest spot in the freezer therefore an ideal place to collect frost. Check the level of the unit and your door gasket to be sure the door is closing tight and true.
Jun 28, 2009 | Whirlpool 25.3 cu. ft. / 716 liter Upright...
Whirlpool sbs fridge freezer - freezer stopped working
There are 2 or 3 things that would cause this. first make sure the condenser coils are not plugged with dust (vacumn or blow them out) next check to make sure the fan that cools these coils is running, (this is the most likely problem). if both of these check out ok then you would need to check to make sure your interior lights ar going off when the doors are closed as these will add extra heat and cause the center rails to run hot. last and most uncommon would be a freon system problem.
fyi there is a hot gas freon line that runs in between the doors to prevent exterior sweating. when poor or no air flow problems for the condenser coil exist it causes this area to become hotter.
One more thing. if you do determine that the condenser fan motor is bad you can put a normal house fan blowing on to the coil to help cool this area down until you can get the unit repaired.
If you need any further assistance leave me a comment here and I'll gladly get back to you. Thanks Peyton
Feb 24, 2009 | Freezers
Left the door open on my Freezer last night and now it doesnt wor
After looking at some advice from others I turned the internal dial to the OFF position, then turned it back to 6 or 7, and left it for 20 minutes, and it is now freezing again.
Jan 04, 2009 | Freezers
Freezer defrosting
need to defost the whole freezer get the door to close correctly...
May 27, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Freezer FF20DSERWH
IF THE FROST ON THE EVAPORATOR ISN'T ACROSS ALL OF THE COILS, THERE IS A PROBLEM WITH THE SEALED SYSTEM. NORMAL OPERATING TEMP IS ZERO DEGREES FAHRENHEIT. THE FROST ON THE EVAPORATOR SHOULD BE THIN AND UNIFORM. IF IT IS HAIRY AND ONLY COVERING PART OF THE COILS, THEN YOU HAVE A SYSTEM FAILURE. IT COULD BE A LEAK AND LOSS OF FREON, A RESTRICTION, OR A WEAK COMPRESSOR.
Apr 03, 2008 | Freezers
Freezers Logo
118 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
