Question about Polaroid TDA-03211C 32 in. LCD HDTV
Picture has a yellow goasty apprarence on white areas
Picture looks like a gassy picture tube on an old tube type TV
  • Polaroid Master
  • 3,866 Answers
This is do to a problem with the inverter its a small circuit board that controls power and other signals to the montior/Tv replaing this will shore this up and you be happy you did Thanks for using Ficya.com for your answers.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jun 22, 2009
Phillips Magnavox 9P6040 C104 tv color adjustment help
If you turn color off and stand back and examine the screen---if it is not black and white but yellow looking you have bad Glycol in the blue picture tube which is quite common.
Easy way to know for sure is with set on and rear cover removed peek with a small mirror at the three lens---don't touch anything with the set on===each tube red,blue, green should have a picture with the set on.
Likely you will find the blue one looks like a floodlight with little or NO image/picture.
May 18, 2012 | Hitachi Televison & Video
Have 47" Samsung HCL743W rear
Here is what to do to confirm what problem is, go to black and white program and make sure color adjustment is turned all the way down to zero.
What you are looking for is what color is the screen?
If it a primary a yellow looking screen (all or most) you have bad Glycol in most likely the blue tube. These sets have a sealed area with a sealed area with Glycol (it is like antifreeze and meant to keep the face of the the three picture tubes cool).
What can happen (usually the blue) is it becomes contaminated with bacteria====note, if blue tube is contaminated you will have yellow screen (red and green=yellow.0
The real easy way to confirm if this is the case is with the back removed and access to the three large lens on top of the tubes look into each lens, if the blue one has no picture and looks like a floodlight, but the red and green have a picture, YOU HAVE FOUND OUT YOUR PROBLEM.
I can tell you if this is the case I can tell you what is involved, this most likely is not a do it yourself repair but i can tell you what is needed.
SD TECH
Dec 28, 2010 | Samsung HCL473W 47" Rear Projection...
I am having trouble adjusting my colors for my kp 53s25 there seems to be a lot of yellow how can i solve this?
This TV has had a long life. Your picture is looking more yellow these days because the Blue picture tube is wearing out. Not saying the Green and Red tub are much better, but Blue tube is a major player in the picture brightness and white balance (the color of white which the TV reproduces). The cost involved wouldn't be justified. You should enjoy the balance of the TVs life; when it's time comes... have the new TV delivered and ask them recycle this one. Best wishes.
Apr 26, 2010 | Sony KP-53S25 53" Rear Projection...
My tv sceen has a stain that makes anything white look yellow.
The color image is comprised of three colors, Red, Green, and Blue.
All the other colors are mixtures of those colors. The yellow picture indicates that your set is lacking sufficient blue drive.
First of all check to make sure that the tint control is not misadjusted.
The next thing is dependent upon the age of your television. If it's an older set that yellow tint is a sign of an aging picture tube.
If it's a newer set, less than 5 years old, have it analyzed by a electronics technician that is familiar with televisions if he is skilled enough he will know right away if it's the picture tube or not.
Apr 17, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
No picture only sound, Toshiba 36A 36" TV tube type
my friend if you open the tv carefully look to see if the tube itself has light, or if you have high voltage i coulbe many different things.wish luck!!
caypianan@yahoo.com
Aug 10, 2008 | Toshiba 36A50 36" TV
Static 'white' sound
Good day.
Try to remove the cover of your unit and clean the tube with a dry cloth. try to look for the anode cap. the one tht is connected to your tube if there are holes in it. This causes the problem.
response is highly appreciated,
chris
Nov 21, 2007 | Sharp 32F-830 32" TV
Distorted Pic
On these sets its the coolent in the tubes thats comtaminated, the picture tubes are soft and are bad, or theres a screen voltage capacitor thats bad in the scan power supply. If the tubes are going bad, a shop with a crt rejuvinator MAY be able to clean the tubes and bring a little more life to them, BUT if not, theres not much you can do as a consumer, as there are no user serviceable parts inside these sets, as all the parts are soldered into place and a TV set is no where to be expeimenting with. Sorry man if the sets over 8 to 10 years old ,its most likly time to put this one out to rest and get a new one. Good luck
Jul 16, 2006 | Philips 8P6034 TV
Brightness and volume
The dark picture is a bad capacitor for the screen or drive voltage for the picture tube driver transistors. The other problem of streaking is one of the same. Thats the indication that a capacitors defective . It could in a rare cas ebe a defective or gassy crt as well but 99% of the time when a crt is said to be gassy its nothing more then poor drive to the crt. Good luck
Jun 13, 2006 | Mitsubishi CS-40507 40" TV
Polaroid TDA-03211C 32 in. LCD HDTV Logo
125 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
