Question about Venturer STS-35S System
Venturer home theatre dvd door is jammed - Venturer STS-35S System
Philips HTS 6600/12 Home Theatre System HDMI does not open the DVD door.
DVD sledges work by a rubber belt that in your case might have broke or come off. It's very easy to replace. Find the original belt. Measure the diameter in MM (approx) and do a Google search for "Drive belt XX MM".
Get the nearest to your size.
Jan 21, 2016 | Philips HTS 6600/12 Home Theatre...
How can I get the Sony DVD home theater TO WORK ON MY UNIVERSAL REMOTE?
Universal remote codes Home theatre
Aiwa = 0641, 1912
Anam = 1913
Apex Digital = 1915, 1937
Audiovox = 0790
Cambridge Soundworks = 1916
Classic = 1917
Daewoo = 1918
Fisher = 1919
Gradiente = 0651
Initial = 1931
Integra = 1924
JBL = 1926
JVC = 1901
KLH = 0790
Koss = 0651
Magnavox = 1914
Norcent = 1923
Onkyo = 1924
Oritron = 0651
Panasonic = 1907, 1908, 1909, 1910
Philips = 1914
Qwestar = 0651
RCA = 0790, 1913
Samsung = 1932
Shinsonic = 1931
Sony = 1903, 1904
Venturer = 0790
Sep 29, 2015 | Philips Phillips SRP1103/27 3-Device...
Lg mini home theatre model FB 162 dvd door will not open dvd's will not play will not play
look for a tiny hole in the dvd door; insert a straightened paperclip into the hole; push in; the door will open then clean the laser lens with a dvd cleaning disk by running the disk in the machine
Feb 18, 2013 | Audio Players & Recorders
'No disc' message on Samsung DVD home theatre system
hello,
the problem the disc is samsung DVD home theatre is having is the lense that is weak. if yo replace the lencse then it wold work properly.
Jan 04, 2010 | Kenwood DV-6050 Multi-disc DVD Player
Mi problema es que yo compre el control remoto que es rcu600wms que era compatible con venturer dvd sts 75 e home theatre en el listado apararece no asi donde estan los numeros de codigos con el tv si...
el problema de los controles universales es que casi no funcionan con los dvd´s y cuando lo hacen hay que buscar que tecla hace cual funcion le recomiendo que busque un original
Dec 09, 2009 | RCA RCU600WMS Remote Control
Decode region on dvd player
Try 7385652500070000+INFO When You Put In A Movie Let Me Know If It Works.
Jan 19, 2009 | RCA RTD255 DVD Home Theatre System System
LG dvd player connected to 5.1 home theatre
Dont now your sytem but check Home theatre sytem must be switch to 5.1 display and not dvd display. if stil no sound check in setup off dvd for soundsetting like PCM, RAW , 5.1etc and select each one till you get desired sound.
Presume your conections from dvd to hometheater is conected 5.1 cables or 1 digital cable and not stereo(2cables)
Jan 05, 2009 | LG RH177 DVD Recorder/HDD Recorder
Venturer AVR2000, home theatre system
I have same system and had same problem until I connected digital audio coax to receiver from digital source.(orange port). Also try making the center front speaker much louder volume setting than all other speakers. hope it helps.
Jan 27, 2008 | Venturer (1012827) System
Venturer STS-35S System Logo
Top Venturer Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Are you a Venturer Audio Player and Recorder Expert? Answer questions, earn points and help others
