Question about Optics
Callaway crosstrax push cart front flat repair
How do I remove the front wheel?
I too searched the internet. I have Calloway Crosstrax push cart. I put too much air in front tires and it blew. Be sure to put only 28psi of pressure in that front tire. These tubes cost at least $10. I Finally figured it out how to take this darn wheel off to replace tube. After 2 hours and revisiting after having a beer it came to me. Remove the two screws on each side of the wheel. Unloosen hex screw at bottom of fork. You don't have to remove the hex screw and not sure if it has to be unloosened. The key is to get pair of grip plyers and pull those black end caps out. A little on each side at a time. The tire assembly comes right out. Don't forget to release brake from closed position. Hope this helps.
Posted on Jun 18, 2014
President club car golf cart front tires wear out every 3 months.
Maybe your front end alignment is off?
Measure the distance across the front of the front wheels and across the rear of the front wheels.
On this cart the measurements should be almost exactly the same.
Measure carefully as the measurement needs to be exact.
If the measurements are not the same,adjust one or both tierods to make the distance between the front and rear of the front wheels the same.
TIP:AVOID sharp turns on pavement which will also accelerate tire wear.
Apr 08, 2017 | Cars & Trucks
How to replace a battery on Sebring 2010?
See my pic below. The battery is in the wheel well in front of the driver side tire. I took this pic when I had the entire front bumper off to work on the radiator. You obviously don't have to take the bumper off to get to the battery, but it's still a pain. To change the battery you need to remove the driver side front tire. Then remove the plastic push pins holding the front of the black plastic wheel well. (These push pins have a center button that need to be lifted. They sell a tool, but a flat screwdriver works fine. Once the center button is lifted the push pin comes right out). Once you have the front wheel well off you can see and reach the battery. Good luck to all!
Feb 04, 2015 | 2010 Chrysler Sebring
How do I align the front wheel of the Bag Boy DLX push cart?
Unfortunately, there is no adjustment on the wheels of the DLX. However, you can often adjust it's alignment by ensuring that the weight of the golf bag is properly centered on the cart.
Aug 17, 2013 | Bag Boy Bagboy Express DLX Push Carts
Can I buy a medical cart with removable wheels?
I think that most of the carts have removable wheels. It really depend on the cart you are looking for and which company manufactures it.
Here's an example of medical carts with what it seems as removable wheels:
http://www.rubbermaidhealthcare.com/products/Pages/Medication-Carts.aspx
Apr 28, 2013 | Medical
I can't fold my caddytek lite 11.5 v2 cart
I'm sure you figured this out by now, but for others stuck with the same question, here's how you fold it: the upper handle of the cart is 'locked' into place with the lower cart just above the upper bag strap. It's the same plastic piece that adjusts the angle/position of the handle. Slide this plastic piece back up the shaft (toward the ball holders), and the upper handle will release & fold down. The 2 side wheels also fold in at the same time.
Jan 21, 2013 | Caddytek CaddyLite 11.5 v2 Deluxe Push...
Front wheel stud replacement for a 2006 Hyundai Sonata GL.
grind a flat spot on the round head of the new stud this should give enough clearance to install it. don't pull the hub this will damage the bearing.
Oct 24, 2009 | 2006 Hyundai Sonata
Hoover front wheels replacement
on the wheel assembly you will see on each end the studs with the flat ends on them,slide the studs in the slots and fold wheels forward and push in.in the middle at the front of the wheels you will see a flat catch ,push it up into the base right behind the brush roller and it will snap in
Oct 04, 2008 | Hoover Elite U5061-900 Bagged Upright...
Quinny freestyle 4; Flat front tyre, how dod I get wheel off so I can repair/replace it?! Thanks
Push in the black button in the center of the wheel. It appears to be just a small plastic "hub" but it's actually a button for installig/removing the wheels.
Sep 21, 2008 | Quinny Freestyle 4 Marina Stroller
Baby Tend Jogger model 9118A needs new wheels
Go to any Auto Parts store or Wal MArt Auto center etc. and buy a can of "Flat Fixer" and fill the tires with it. Problem solved :-)
Jul 27, 2008 | Baby Trend Expedition LE Jogger
Optics Logo
115 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
