Question about Canon CR-55 Pass-Through Scanner
Canon cr-55 transporter is dead - Canon CR-55 Pass-Through Scanner
Amano pix-55 battery replacement how to
The Pix-55 has a simple CR-2032 coin battery. But the battery contacts are pin-point spot welded to positive and negative faces instead of being easily replaceable as they should be. I carefully broke the battery loose and soldered the leads from a single CR-2032 coin battery holder I got off Ebay, The green electronics board is marked +&- so easy to get the leads right. Before I started, mine didn't work at all and after the new battery it works great. What a shame many of these are probably thrown away because of a $2.50 battery. The next time mine goes bad I can easily replace it.
Feb 14, 2014 | Amano Pix-55 Time Clock
Can passive and active transport occur in dead cell?Explain
The definitive answer is: it depends. It depends on how the cell "died". Most forms of cell death include getting holes in the membrane, and if that happens any type of transport (active or passive) is pretty much impossible. The transport proteins might still be working, but whatever they're moving across the membrane would just leak back through the holes, so there's no transport. If there aren't holes in the membrane, then passive transport should still work. For active transport, it depends again. Usually for active transport you just need the transporter and an energy source (like ATP). As long as the energy source is still around, active transport will still go on. Chances are, though, that the dead cell isn't making more ATP as the old is used up, so pretty soon it will run out and active transport will stop. Other forms of active transport don't use ATP directly, but they still count on the cell using energy. When the cell dies, those transporters will also stop working before long.
Aug 08, 2011 | Health & Beauty
Installing GE Halogen H1-55. (Car Hedalight)
There is no up or down side to the bulb
Jan 22, 2010 | 2005 Honda CR-V
I was involve in a dead battery and i can not play my radio ,asking for code.cr v 1999.i need a code for my honda cr v 1999
have you reset your computer try that. autozone will do it and check your codes for free
Nov 20, 2009 | 1999 Honda CR-V
It wont turn on i tried charging the battery to see if it was dead but it wasnt the battery it wont turn on!
Are you sure it is dead or is it simply that liveview is not showing? A friend of mine thought hers was dead the other week but liveview was turned off. Try taking a few photos and see if it actually takes them?
Jun 11, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
Drivers for canon bjc-55
Here is the page to get the driver.
BJC-55 Support
Select the Drivers & Downloads tab. Then select your operating system. The available driver and other software links will appear. Click on the file name to download.
Thanks for using Fixya.
May 20, 2009 | Canon Office Equipment & Supplies
Transport Controls are dead
I have had the same problem with the CR-3A for about 20 yrs. I tried to get it fixed but nobody seems to have a permanent solution. Apparently the control motor (the one activating the leaf spring switches) over travels the worm gear after some time (poor design tolerances). I just open the cover and force it one way or the other until it works again - it will be good for a few plays and will happen again - a pain in the ****.
May 02, 2009 | Audio Players & Recorders
1998 Honda CR-V
you should check for recalls, there were problems with the 98 CRV
Aug 05, 2008 | 1998 Honda CR-V
Cr-180 Won't Detect Checks
Embarassingly enough, a reboot took care of the issue! Duh.....
Apr 04, 2008 | Canon CR-55 Pass-Through Scanner
Canon Cr-180
How can you get to the mirrors inside the machine to clean an ink build up? We are seeing think black lines on the items that are ran at the branches with these machines. Can you clean this off?
Aug 16, 2007 | Canon CR-55 Pass-Through Scanner
Canon CR-55 Pass-Through Scanner Logo
old marine
old marine
