Question about Goodman GDS80904BNA Open Flame Heater
What does 3 flashing lights on the Red T Product Gas Furnace Mean?
    Problem Solver:
  • 47 Answers
Vac switch. pull door/find grey tube to induced draft motor/pull tube off/suck on tube to hear it click/if so you need to find a wire small enough to insert into motor tube being sure power is off before doing this. 112 to 16G will work. reatttach and power up to see what happens. Good luck
Posted on Nov 26, 2014
3 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: what does it mean when my goodman furnace is
It is in Lockout mode. Something has happened to make it go into lockout.
It could be an easy fix. Look of cobwebs in the tubing between the proving switch and the draft inducer motor. Look for air restrictions in the chimney flue. Rusty burners (if applicable). Tripped rollout switches. Some times there could be up to 2 roll out switches on the burner and another in the flue and 2 others in between stuff. . Most times it is a dirty flame sensor. Over the summer the flame sensor gets dusty and the sensitivity gets off. The control fails to FEEL the probe and locks out the gas valve. Most times the failure will be defines by the amount of blinks the red light emits. The sub panel has a guide on it that tells what the blinks mean.
Posted on Oct 19, 2010
  • 1033 Answers
SOURCE: My furnace will not light. What does it mean when
Hello, a 3 flash on a circuit board means that a pressure switch is open, this could be due to a blockage in the flue pipe or the small tubing that goes from the inducer to the pressure switch is loose, leaking, or is blocked. You can try taking the tubing out and checking if there is anything in it blocking the pressure between the pressure switch and inducer motor and then attaching back on and make sure it's secure and tight. If that does not work that the switch itself is bad and must be replaced.
Posted on Jan 22, 2011
Red and green flashing lights on my miller gas furnace, what does it mean
Try turning the power off to the furnace it may just need resetting .
Nov 03, 2016 | Heating & Cooling
Error code= two red flashes, lockout/ no flame
Trane XV80 hard lockout, 2 flashes, Can't be reset - DoItYourself ...
www.doityourself.com > ... > Gas and Oil Home Heating Furnaces
Jan 10, 2013 - The only way I can get diagnostic Red LED light to reset is to switch ... a2 flash with absolutely no operation from the furnace does seem to ..... inducer gets a demand you should get a pressure switch error code 3. ... the flame sensor wire and giving the furnace a heating demand after resetting power twice. Luxaire Furnace Blowing Cold - 8 Red LED Flashes
Mar 1, 2010
Winchester furnace diagnostics
Feb 14, 2010
American Standard Freedom 80 - Cold Air - Getting Error Code 9 ...
Nov 20, 2009
York ignition lockout due to retries
Dec 29, 2008
More results from www.doityourself.com
7 Tips and Tricks to repair your Furnace DIY - YouTube
? 13:25
https://www.youtube.com/watch?v=rAtcvPqUsBA
Dec 18, 2012 - Uploaded by JRESHOW .
cause this fault. 2 RED FLASHES: This indicates that thenormally open pressure ... The furnace will lock out for one hour and then restart. 7 RED FLASHES: This fault code indicates that the flame could not be established. This no-light ... problem. Bothheating and cooling operations will be affected. Check
Jan 23, 2016 | Heating & Cooling
My Xenon high efficiency furnace has a red blinking led light that blinks 4 times and my furnace will not light. What could be the problem?
Gas furnace fault or error codes for common furnaces - Gray ...
www.grayfurnaceman.com/-ifc-failure-codes.html
Each color will also flash a specific number of times to signify a specific error. ... 4 redcolored flashes may be signaling that the "high-limit" switch might be open. ... 3 green colored flashes on your furnace has the same meaning as 2 green colored flashes. ....If a system problem occurs, a blinking LED shows a fault code.Missing: xenon
? 13:25
Flash sequence codes 1 through 11 are as follows: LED will turn "on" ... 4 RED FLASHES: This indicates that the main limit switchhas opened ... This no-light condition occurred 3 times (2 retries) during .... My furnace trane xe80 is only flashing once my manual says something about flame being locked out ...Missing: xenon ‎efficiency
Nov 21, 2015 | Heating & Cooling
Amana 80 sv furnace blowing no heat 4 red flashes
Just a guess unless you read from a paper on the inside what 4 flashes mean but usually it's the igniter
Nov 24, 2013 | Amana GMH950453BX Gas Furnace
Flashing red light mean
Copy following link to identify gas control valve, and read error codes and access service manuals with general to specific repair information:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
More pro resources for do-it-yourself followup:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Add a comment and describe more detail about product
Call local plumber.
Gene
h
Aug 19, 2013 | Rheem Water Heaters
Intertherm furnace model # MMHB-070ABHR-06 red light blinks two times
Number of flashes mean different things for diff models. The meanings of those flashes should be posted somewhere on the unit; usually inside front of the bottom service panel. Though you can't truly diagnose a problem by number of flashes they can give you an idea of where to look for a problem. There are a ton of videos and how-to's about furnaces on youtube by real service techs. Most modern furnaces have basically the same set-up and features so don't worry about your paticular brand; but of course that would be the best place to start looking. You could start here to familiarize yourself with your brand of furnace:
http://www.youtube.com/results?search_query=Intertherm+Gas+Furnace+&oq=Intertherm+Gas+Furnace+&gs_l=youtube.12...62316.62316.0.63907.1.1.0.0.0.0.202.202.2-1.1.0...0.0...1ac.Ko9QBdxK6OM
And then here:
http://www.youtube.com/results?search_query=gas+furnace+won%27t+light&oq=gas+furnace+won%27t+light&gs_l=youtube-reduced.3..0.5619.10061.0.11544.11.5.0.6.6.1.741.1982.0j1j2j5-1j1.5.0...0.0...1ac.1.5-0zJyxNMEo
Hope this helps.
Dec 21, 2012 | Heating & Cooling
I have a goodman furnace GMP100-4 REV B..about a year ago it was not working. The fan would start but it would not ignite. We found out we need a new ignitor and it was a good quick easy fix. Now a ye
Any light flashin on the control board? If not then look for a small fuse blown on the board. See lights a flashing count them flashes
A sampling of various failure codes on a furnace:
Read one LED flash that stays on continuously to mean your furnace has no signal coming from the thermostat and will not operate. Turn the power off and check the thermostat for improper settings or connections.
Interpret one LED flash that blinks on and off to mean your furnace has locked out because it could not ignite after three tries, and must be reset. Interrupt power to your furnace for 20 seconds or lower the thermostat so your furnace does not try to heat, then reset the thermostat to the previous setting. After one hour of lockout, your furnace will automatically reset itself and try to operate as usual.
Decipher two LED flashes to mean the draft blower is not working, or your furnace has a short in the pressure switch circuit. Turn off the furnace power and repair a short or replace the pressure switch.
Read three LED flashes to mean your furnace has an open pressure switch circuit or it has an induced draft blower operating. Check the pressure switch hose of your furnace for blocks or an improper connection. Also, look for blockages in the flue, and tighten any loose wiring.
Translate four LED flashes to mean your furnace has a primary limit circuit open, possibly from loose wiring or blocked filters. Check and clean filters, tighten wiring and check the flue for blockages.
Interpret five LED flashes to mean your furnace senses a flame without a call for heat. This could be from a gas valve closing slowly or a burner flame lingering.
Read seven LED flashes as a warning of a low flame sense microamp signal. This could happen with a coated flame sensor or a lazy flame from poor gas pressure. Turn off the power and adjust the gas pressure according to the information on the rating plate.
See eight LED flashes as meaning an igniter circuit problem due to a bad igniter or an igniter connected improperly. Replace the bad igniter or check the ground wiring, making necessary corrections.
Decipher nine LED flashes to mean the high-stage pressure switch circuit will not close during a high-stage-induced draft blower operation. Your furnace may have a pinched or blocked pressure switch hose, a blocked flue or loose wiring.
Read continuous flashing on the LED to mean your furnace has a reversed polarity of 115 volts. Turn off the power and correct the wiring polarity after reviewing the wiring diagram.
Nov 29, 2011 | Goodman Heating & Cooling
I have a Goodman GMP 125-5 furnace. It had a 3 light code i replaced the presure switch now it is giving me a 1 light code please help
Oct 28, 2011 | Goodman Heating & Cooling
Suddenly not working im not sure if there even is a pilot to be lit
Goodman have troubleshooting idiot lights on the board. Look for flashes and count em.
The flash explanations are printed on the backside of the blower cover on most models.
Feb 03, 2011 | Goodman Heating & Cooling
My central heating is on lockout and the burner is with red light
A sampling of various codes on a furnace
Interpret five LED flashes to mean your Goodman furnace senses a flame without a call for heat. This could be from a gas valve closing slowly or a burner flame lingering.
Dec 02, 2010 | Heating & Cooling
Heating & Cooling Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
