Question about Rangemaster Kitchen Ranges
Leisure roma 100 where can I find replacement inner glass for left hand oven door. Model rm10crs
FreeTech
  • 426 Answers
SOURCE: broken inner glass on kitchaid range how to remove the door
screws near the hinge, make sure to get oven/tempered glass sometimes the screws are located in the crack between the oven and door on the bottom
Posted on Jun 13, 2008
  • 409 Answers
SOURCE: Oven Door Inner Glass Replacement
can you gals get me the complete model # off the stove and i will look up the parts diagram & exploded view.
Posted on Sep 13, 2008
BNewberry
  • 93 Answers
SOURCE: broken inner glass door
NO,  I would not recommend this at all.  However, I have seen the stoves used without one of the inner glasses with no problems.   I am a factory servicer for frigidaire and have seen people use these with one of the glasses broken and haven't seen a problem yet. But again, it's not recommended. www.applianceoutletservice.com
Posted on Nov 05, 2008
aborcass
  • 2651 Answers
SOURCE: Can't remove oven door from Whirlpool model GR450LXH
the hinges problably require to be "locked" beforer removing from door frame, usually explains in hte manual "how to remve door". if needed, you can input your model number here, to download a copy
http://shared.whirlpoolcorp.com/product_literature/literatureSearchResults.cmd?siteCd=WHRCOM
Posted on Nov 27, 2008
farfield
  • 462 Answers
SOURCE: having problems with fan assisted oven on leisure
Often these fan assisted type ovens have a safety that keeps th fan off if it believes the door is open. Look for uneven door closing or cracks in the door to frame closure. Is this a commercial convection oven?
Posted on May 08, 2009
Please tell me if Electrolux EKG5547XN Cooker Main Oven Glass Door would fit my EOB6632U
Glass oven door is not compatible.
First of all, the oven door EKG5547XN has only two glasses, inner and outer, while the oven door EOB6632U has three glasses; inner, middle and outer.
EKG5547XN
Inner glass oven door, part number: 349 00 30-01/6, silkscreened; dimension: 456 x 323 mm, tempered glass.
Front glass oven door, part number: 349 10 45-14 / 6, stainless.
EOB6632U
Inner glass oven door, part number: 899661 92 68-78 / 3,
silkscreened; dimension: 479 x 391 mm, tempered glass.
Middle glass oven door: dimension: 447 x 380 mm.
Front glass oven door: dimension: 589,5 x 466 mm.
Dado
Mar 28, 2015 | Electrolux Ovens
Replacing oven door glass
You didn't say what brand or model but here is a link to a youtube video for a Frigidaire oven, Other brands and models on youtube too. You will probably be able to get a replacement kit from sears parts direct if you have the brand and model number. Or an appliance parts store or ebay.
Range Stove Oven Repair Replacing the Inner Oven Door Glass Frigidaire...
Aug 16, 2014 | Ovens
How to replace inner glass panel on Neff H7871 microwave
Hi Bill, I am having a same problem I have managed to order the glass from:-
http://www.4neff.co.uk/cgi-bin/product.pl?PID=876912&query=Neff%20H7871N1GB%2f01&model=H7871N1GB&path=127858
1. Open the door.
2. Take out the 2 screws just behind the handle, on the inside of the door, the door should flop down at the handle end.
3. Hold the door handle and pull the door out. It is only housed in by a slip in hooks at the bottom end.
4. Once you remove the door you will see the inner metal mesh and the inner door behind it.
5. Remove the 16 screws holding the inner glass with a special star type screw driver bit no T30.
6. Once you done that the glass housing holding the inner glass can be carefully prised free and taken off the inner door assembley.
7. Once you done that remove and inner glass, and be carefull to leave the glass glass seal intact, clean around the frame housing and the seal then replace the new inner glass and reverse the process.
PS. Becareful of the inner door once you've removed the outer door, as the hinges holding the inner door tend to shut quickly as there is less weight on the hinges.
It will do the job if you follow these instructions.Good Luck. AL
Oct 10, 2011 | Neff H7871 Convection/Microwave Oven
Have a Leisure roma 100 cooker model number RM10FRS main fan oven not heating need a service manual to find out how to get at heating element to see if needs replacing.
most likely thermal fuse behind oven take off back plate and you will see the brown wire with the heat shrink sleeving covering the fuse.wire and fuse comes as one part
Jul 05, 2010 | Kitchen Ranges
Having problems with fan assisted oven on leisure roma 100 cooker, it doesnt seem to work everything else seems to work fine, Can anyone help me
May 08, 2009 | Kitchen Ranges
Broken inner glass on Model # NGSG3PZAQA
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
How do I replace the inner glass on the oven door? I have taken the door off and it is apart, but the glass assembly looks to be one piece. How do I remove just the inner glass for replacement? JenW30400W
moz-screenshot-7.jpgmoz-screenshot-8.jpgTo replace the door glass do the following:
Part here: _.gif PS2087058
Mar 14, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Neff H7871 inner glass broken
Hi, I am having a same problem I have managed to order theglass from:-
1. Open the door.
2. Take out the 2 screws just behind the handle, on the inside of the door, thedoor should flop down at the handle end.
3. Hold the door handle and pull the door out. It is only housed in by a slipin hooks at the bottom end.
4. Once you remove the door you will see the inner metal mesh and the inner doorbehind it.
5. Remove the 16 screws holding the inner glass with a special star type screwdriver bit no T30.
6. Once you done that the glass housing holding the inner glass can becarefully prised free and taken off the inner door assembly.
7. Once you done that remove and inner glass, and be careful to leave the glassseal intact, clean around the frame housing and the seal then replace the newinner glass and reverse the process.
PS. Be careful of the inner door once you've removed the outer door, asthe hinges holding the inner door tend to shut quickly as there is less weighton the hinges.
It will do the job if you follow these instructions. AL (srahbah@hotmail.com)
Dec 05, 2008 | Neff H7871 Convection/Microwave Oven
Broken Inner Glass Door
Just the glass piece. Look up parts on any parts site or let the supply house do it for you. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Nov 20, 2007 | KitchenAid KGST307 Gas Kitchen Range
Kitchen Ranges Logo
20 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
