Question about Sharp LC52SB57UN LCD TV
How do i make screen fi - Sharp LC52SB57UN LCD TV
How do I find my Wi-Fi passcode
Whoever set up your Wi-Fi should know that. Same passcode should work for any device on your Wi-Fi network.
Apr 08, 2016 | Amazon Kindle
Tip
How to turn on Wi-Fi on my locked iPod
<p>The ability to connect to the Internet via Wi-Fi is an important feature of the iPod touch. With Wi-Fi, you can surf the Internet, check your e-mail and online games. But first make sure that the WiFi connection If your iPod is locked, you must unlock before you can change the connection settings. <br /> <p><br /> <p>1. Press the "Power" button in the upper right or the "Home" button on the iPod screen to activate the screen. <br /> <p><br /> <p>2. Slide the locking bar from left to right to unlock the device. If the password-protected your iPod, type the password. <br /> <p><br /> <p>3. Click the "Settings" app icon, and then click on "Wi-Fi in the Settings menu. <br /> <p><br /> <p>4. Turn on the Wi-Fi pressing the "On / Off" button in the upper right corner of the screen, then see the available networks. Click a network to connect. If the network is password protected, enter the correct password and click "Join" to activate the Wi-Fi on your device. <br />
on Jul 21, 2011 | Computers & Internet
Tip
How to set up internet on Samsung Jet
Ensure that you have the appropriate network key code needed to enable you to access a secure Wi-Fi network.
If you are connecting to a secure Wi-Fi network with MAC address restrictions, you will require pre-authorisation for the router. You will need to find your Samsung Jet's MAC (Media Access Control) address. This is a 12-character code which may be needed by the network controller to enable the phone to connect. See Getting the Samsung Jet's MAC address below.
You can get to the Wi-Fi application either via the main menu or using a homescreen Wi-Fi Widget.
  1. To get to the Wi-Fi application via the main menu, press the MENU button (either on the home screen or the hexagonal button beneath)
  2. In the main menu, swipe your finger sideways to go through the menu pages until you see the Wi-Fi icon. Press to select.
  3. The Wi-Fi application opens.
  4. Alternatively, to use the Wi-Fi Widget, from standby, press the home screen. The Widget toolbar opens up.
  5. Scroll down to find the Wi-Fi Widget icon. Press the Wi-Fi Widget. The Wi-Fi Widget will pop up on the main screen.
  6. Press the Wi-Fi Widget on the main part of the display to launch the Wi-Fi application. The Wi-Fi application opens.
  7. Once in the Wi-Fi screen, press the large Wi-Fi button in the middle of the screen to turn it on. Wi-Fi is activated and the button turns blue.
  8. Press SEARCH Nearby Wi-Fi access points (APs) will appear as small circles on the display, with their names next to them.
  9. Press the circle representing the Wi-Fi Netowrk you want to connect to. An options panel appears.
  10. You can press CONNECT to connect to the network or press ADD if you want to add it to a list of preferred networks for easy access later.
  11. You are taken into a settings menu for the Wi-Fi access point. If the Wi-Fi access point requires a network key code, scroll down to the Network Key panel. Press to select.
  12. The numberpad appears. Type in the network key code and press DONE. You are returned to the previous settings screen. Press SAVE
  13. A list of connections appears. Press the back arrow button
  14. If you initially pressed CONNECT, the phone will connect to the selected Wi-Fi network and a confirmation message will appear. The display now shows the new connection, illustrated by blue dots linking the circles onscreen (Figure 15).
  15. If you initially pressed ADD, you will be returned to the Wi-Fi screen. Press the circle representing the Wi-Fi network you want to connect to. A pop up panel appears.
  16. Press CONNECT. You will be connected and the connection illustrated onscreen.
Press the back button to return to the home screen.
  1. From the home screen press MENU to enter the main menu (Figure 1).
  2. In the main menu, press INTERNET
  3. Choose which browser option you want (Home, Enter URL, Bookmarks, etc.) (Figure 18) and press to select. If you press Home you will be taken to the pre-loaded home page.
  4. If required, use the numberpad to type in an URL or scroll a list to select bookmarks. When an URL is completed press GO. Alternatively press the bookmark you wish to access. You will taken to the web page requested.
  1. Activate Wi-Fi and press SEARCH, as before.
  2. When the Wi-Fi access point you want to connect to appears on the display (Figure 8), press it to select.
  3. A pop up options panel appears (Figure 9). Press DETAILS
  4. Details of the Wi-Fi access point appear onscreen.
  5. Scroll down by dragging your finger up the screen. Towards the bottom of the settings list, DEVICE MAC appears, with a string of 12 charactesr beneath (Figure 21). Each handset has an individual MAC address, and this panel will display your Samsung Jet's unique Mac address.
Make a note of the MAC address. You will need it if you want to use the Samsung Jet's Wi-Fi to access a secure Wi-Fi network using MAC address restrictions. This can be added into the wireless router settings access list.
on Apr 17, 2010 | Samsung Jet S8000 Cell Phone
Hi, i have a acrr aspire one, it was not mine and can't get it to get wi-fi or internet, am not very good at this neither, i realy need help.
First, loof for a special icon along the top row of your keyboard. One of those keys turns wi-fi on and off. You may need to hold down the "FN" key while pressing the wi-fi key. Make sure that you have selected the wi-fi "on" setting. Next, you can try going somewhere that has free wi-fi such as a Starbucks coffee bar or a restaurant. Open your internet browser (Internet Explorer has a large blue icon of the letter "e"). See if you get on the internet. If so, your wireless adapter is working OK. Now, most homes have wi-fi that is password protected. Click on the little bar graph icon in lower right corner of your screen and a list of available wi-fi networks should appear. Choose your home wi-fi and click on Connect. This will open a screen where you must enter the passwordor passphrase to gain access to the wi-fi. Good luck.
Nov 13, 2014 | Computers & Internet
What does need a data connection mean
To use Google maps or some other programs (like games), you need to be connected to a Wi-Fi network, not the cellular network. You will need to be in an area with an open wi-fi network or have a wireless router in your home. Find your password for the router's wi-fi network (it should be password-protected) and the SSID; you also need the encryption type (WAP, WEP, etc.).
Press Apps on the Home Screen. Then press Settings and then Wi-Fi. Select Scan to locate available networks. While on the Wi-Fi tab, press Add Network. Enter the SSID with the keyboard, then touch Security type to select the encryption for your router. Then enter the password and finally press Save. (Some wi-fi routers will want the MAC address before you can add a device to the network. Go to the Menu - Advanced from the Wi-fi tab to get the information.)
If the wi-fi network has been set up on the Tab, press Apps on the Home Screen. Then press Settings and look for the Wi-Fi On/Off icon. Toggle this to on. (You can also access this by touching the time on the Home Screen. Then touch Wi-fi on the Quick Settings list.)
I hope this helps.
Jan 16, 2013 | Samsung Galaxy Tab 2 7.0
MY SONNY ERICSSON X8 WHY I CAN'T GET THRU IN WIFI
To connect to a WLAN via Wi-Fi™:
  1. From the Home screen, find and tap Settings.
  2. Tap Wireless controls > Wi-Fi settings.
  3. Mark the Wi-Fi checkbox. Available Wi-Fi™ networks are displayed in a list under Wi-Fi networks. The available networks may be open or secured. This is indicated by the icon next to the network name.
  4. Tap a Wi-Fi™ network to connect to it. If you are trying to connect to a secured Wi-Fi™ network, you are asked to enter the security key for that Wi-Fi™ network before you can connect to it. The Wi-Fi™ connection is displayed in the status bar once you are connected.
Useful tip:
  • The next time you connect to a Wi-Fi™ network, the phone will remember the security key.
  • To enable Wi-Fi™ network notification of open networks, mark the Network notification checkbox.
  • To connect to another Wi-Fi™ network, just tap another Wi-Fi™ network in the Wi-Fi networks list.
  • To scan for Wi-Fi™ networks manually, press the Menu key and tap Scan. The phone scans for Wi-Fi™ networks and displays them in the Wi-Fi networks section.
You can also try updating your softwares by going to the sites below;
Update Service,
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/xperiax8?cc=gb&lc=en
PC Companion,
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/pccompanion/xperiax8?cc=gb&lc=en
Start the program and just follow the on-screen instructions.
I hope this will help.
Jun 16, 2011 | Sony Ericsson XPERIA X8 Cell Phone
WiFi just scans but does not find any available networks to connect to??;le
Hello Derek,
Connecting Wi-Fi in HTC Desire Cell Phone
From the Home screen, press , and then tap Settings > Wireless & networks.Select the Wi-Fi check box to turn Wi-Fi on. The phone then scans for available wireless networks.Tap Wi-Fi settings. The network names and security settings of detected Wi-Fi networks are displayed in the Wi-Fi networks section.If the wireless network you want to connect to is not in the list of detected networks, scroll down the screen, and then tap Add Wi-Fi network. Enter the wireless network settings, and then tap Save.Tap the Wi-Fi network you want to connect to. If you selected an open network, you will be automatically connected to the network. If you selected a network that is secured with WEP, enter the key and then tap Connect.
Jun 02, 2011 | HTC Desire Cell Phone
Connection to the internet blacberry 9780
1. On the Home screen, click the connections area at the top of the screen, or click the Manage Connections icon.
2. Click Set Up Wi-Fi.
3. If you want to connect to a public hotspot or to a Wi-Fi® network that does not require authentication, select the Show Open networks only check box.
4. Click the Wi-Fi network that you want to connect to.
5. If the Wi-Fi network requires authentication, type a password for the network.
Feb 09, 2011 | Cell Phones
HP iPAQ 3715 - screen problems
Return it as faulty. WiFi should not impact your screens ability to stay on.
Sep 08, 2005 | HP iPAQ RX3715 Pocket PC
Sharp LC52SB57UN LCD TV Logo
10 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
