Question about Sony Cameras
Why am I getting the e92 error code on sony cyber shot camera
SOURCE: problem with sony dsc-w30 cyber shot flash
I found this solution in Yahoo Answers. go into the Setup Menu and find "Initialize". Select Initialize to reset the camera adjustments. Then try using the camera again.
Posted on Feb 17, 2008
swami nathan
  • 208 Answers
SOURCE: Sony Cyber-shot Error Code E:61:00
you may have these symptoms,
Symptoms :
  1. After pressing the power button in capture mode, the lens would extend and a slight humming from what appeared to be the auto focus motor could be heard for about 5 seconds. When the motor stopped humming, the camera would beep and display E:61:00 in the LCD Screen.
  2. Camera would extend the lens but not be able to focus on anything past 8 inches or so.
  3. Zoom in and zoom out would not work.
  4. Playback mode and the Setup mode was not affected.
To fix this problem,
Do these...
A) Put the camera about a half inch from a hard surface.
B) Let the lense go out and hit the surface and retract a little bit. Let it go out all the way when it tries the next time.
If that doesnt fix it, try this:
A) Turn it on and let the lense go out fully
B) See where the lens comes out of the camera? The little round crack that surrounds it? Wiggle the lense a bit and blow in there a bit. (Be sure not to blow on the lense!)
Now turn it off/on again, and it should be fixed!
If not, try these steps a few more times. If still nothing, then I suggest you to call Sony, but this DID work for 90%, so hopefully it''ll work for you :)
Thanx for using fixya,
Cheers.
Posted on Sep 27, 2008
SOURCE: Sony Cyber-shot DSC-T77 - "System Error C:32.01"
The issue was resolved.
Thanks.
Posted on Aug 08, 2009
  • 1382 Answers
SOURCE: I HAVE A SONY CYBER
Follow the procedures given below to have a perfect fix for your problem.
  • Press Menu button.
  • Toggle across from REC Mode to setup
  • Toggle down thrice from camera to setup 1
  • Toggle across into sub menu
  • Toggle down from four times to Initialize
  • Toggle across again to the sub-menu
  • Toggle up from cancel to OK
  • Press center button to accept the OK choice
  • Screen changes and so press okay again
  • It should restart the camera
  • Opening on the 'Clock Set' screen
Toggle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function. If it is still not working dont worry follow the steps again two or three more times, As this is related to a software error message and not a hardware malfunction. If it is working then don't forget to set your Clock.
Thank you !!
Posted on Aug 18, 2010
pctech1
  • 1940 Answers
SOURCE: c:32:01 system error= can use
"C:32:01 System Error" means, there's something wrong with the memory. Attach it to your computer and format the the card as 'FAT'. Formatting as 'FAT32' or 'NTFS' will produce this error.
Posted on Feb 21, 2011
Has anyone repaired a Sony cyber-shot camera DSC HX300 with error code 62.10.
It appears that the answer is nope
So Sony is your answer unless you try an independent repair centre willing to do the job
Jul 24, 2015 | Sony Cyber-shot DSC-HX300
Cyber shot DSC-W561 error code E:91:01 - how can reset normal condition?
Download the service manual from elektotanya.com and find the complete explanation to the error codes. This is a service center job.
Nov 04, 2012 | Sony Cyber-Shot DSC-W560 Digital Camera
ERROR CODE 91.01
this is my same problem in my Sony Cyber-shot DSC-W130., pls e mail me if someone answer your problem., this is my e add -- helterbrand_16@yahoo.com ur.goingdown@ymail.com
thanks.pls..
Dec 23, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Problem for Sony Cyber-shot DSC-S600 Digital Camera Error code E:61:20 on Sony DSC-S600
Its Lens Block Assy is faulty. Below is part no of Lens
yey4u7iqvnoaaaaasuvork5cyii=
Problem will solved after replacing Lens assy
Kind regards.
Nov 02, 2009 | Sony Cyber-shot DSC-S600 Digital Camera
Sony cyber-shot dsc-w50 problem
Hi!
It's a flash error. Could be flash fuse or flash board. If you have a multimeter and you're ready to open it, contact me at toms.safranovs@gmail.com or contact your local Sony service center.
I work in a Sony service center.
Tom
Jul 27, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Sony cyber shot t70
how much to replace screen on a sony sony cyber shot dsc t7
Apr 17, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
Format error.
To solve format error, go to camera Menu and select Format and press OK. This will format and delete all data on memory stick.
Apr 11, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Error 91:01
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Apr 08, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony Cyber-shot DSC-F717 5.0 Megapixel
Hi Bella
That code means that the lens unit was unable to move from home position to switch on position.
These lens are extremely complex and I doubt if you could find someone able to repair the lens.
Therefore I suggest contacting Sony to find a accredited dealer to quote you on replacement of the lens.
My guess is it will cost half of what you originally paid for the camera.
Good luck.
Sep 06, 2006 | Sony Cyber-Shot DSC-F717 Digital Camera
Cameras Logo
35 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
