Question about Steam Fast SF-250 Mouse Vacuum
I need new cap for steam fast 250? - Steam Fast SF-250 Mouse Vacuum
I need to know how much water to put in it.
press the helpful button
Fill the provided measurement cup to the maximum fill line with water. In areas with a high mineral concentration in the tap water, we recommend using distilled or demineralized water to prolong the life of the steam cleaner. Using the funnel, pour the contents of the cup into the reservoir.
Top Innovations, Inc.
400 NW Platte Valley Drive
Riverside, Missouri 64150
www.mitcoproducts.com
1-800-711-6617
http://steamerstore.com/steamfast/manuals/SF-250_Manual.doc
Jan 28, 2016 | Steam Fast SF-250 Mouse Vacuum
I need new cap
Order a new cap online.
Apr 09, 2014 | Tristar SB Steam Buggy Vacuum
My cap on the tank of my unit does not seal also I have difficulty getting the pads that came with it to stick to the mop.
You can buy a new cap from the manuals link...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Aug 23, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Need a water tank safety cap for euro- pro canister steam cleaner model S3325H
I need a cap which is located on the back of the clean water tank on a Bissell model 1950-3 steam cleaner
Aug 20, 2010 | Euro-Pro S3325 Handheld Steam Vacuum
Need instructions. manual is missing.
You can download the complete instruction manual in PDF format by clicking this link
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Apr 10, 2010 | Steam Fast SF-250 Mouse Vacuum
I am still awaiting for your reply, athina_papamichael@hotmail.co.uk, regarding water reservoir cap steam leaking is this normal or do I require a new cap or rubber ring, otherwise I will have to take my...
Hello, no this is not normal. You just need a new O-ring. This is about a 1 dollar fix. The original O ring is clear rubber but a 3/4" standard O ring will work just fine. You can get these at Lowes or Home Depot.
Mar 26, 2010 | Tristar SB Steam Buggy Vacuum
Steam leaking from screw cap. can i get a new one?
you dont need a new steam cap if steam is coming out of the top, that is supposed to happen when the hose is clogged, it would be very dangerous if that didnt happen, the amount of pressure that thing holds is unreal if you think your cap is leakin steam take a second look. if the cap is not physically damaged then it should be working fine, 9 times out of 10 your hose is clogged
Oct 27, 2009 | Tristar SB Steam Buggy Vacuum
CAN,T REMEMBER WHERE THE WATER GOES
Please open the top white lid and unscrew the top black knob with instruction on the back of white lid.
May 11, 2009 | Steam Fast SF-250 Mouse Vacuum
Steam escapes Steam Buggy
I've faithfully used by little yellow Steam Buggy to clean tight corners in my replacement windows and was always to get them looking new again and many other small places that needed blown out with steam when wiping or even scrubbing with a toothbrush doesn't work. I started to use it today and the steam started to come out around the black cap. After searching for a solution on the net I was very disappointed to find everyone else was having the same problem with no real solution. I had my hubby look at it and he said the gasket was worn and slip an o-ring on top of the gasket and now it back to working fine.
Just wanted to pass it along. A 10cent O ring will fix it.
May 12, 2008 | Tristar SB Steam Buggy Vacuum
How to use the product
We had the same problem. My husband gave the cap a few judicious
blows with a hammer to loosen it because it had become encrusted
with mineral deposits. That allowed us to open it ... then we spent a
remarkable amount of time flushing minerals out of it.
From now on, I'll do the vinegar rinse bit (in the manual) after every use
(or at least frequently).
Jan 15, 2008 | Steam Fast SF-250 Mouse Vacuum
Steam Fast SF-250 Mouse Vacuum Logo
Top Steam Fast Vacuums Experts
Are you a Steam Fast Vacuum Expert? Answer questions, earn points and help others
