Question about Telex Aat-2 Sound Mate Personal Listening System Sound Enhancement Box
What would serve as a replacement antenna for the Trx? The original was a wire whip on a Male right angled UHF connector.
Grounding uhf antenna
First off, using a Ground post driven into the soil is important. The best ground post procedure is to SLANT a 6 or 8 foot rod into the soil at an angle (not directly down). The angle allows for a greater ground surface and is more effective. If a Ground rod is cut off because it cannot be driven deep into the soil; this defeats the need to ground electronic or other devices.
12G wire is OK for an antenna if 8 or 10 are not available. Copper is best, but aluminum will work. The Grounding bock is attached to the mast, usually near where the antenna if affixed to the mast. Simply drill a small hole into the Mast section using the block as your guide. Using a hex driver and small hex screws, tighten the block to the mast. Good contact is necessary, so tighten all attachments. I suggest getting Rubber Boots or Covers to protect the connectors on the block from corrosion. The reason I attach blocks to the mast is to ground the Mast first and Antenna second. Not a critical feature. You may also use petro-jelly to cover the nuts, bolts, and screws to prevent corrosion or binding.
Dec 18, 2013 | Cable Wholesale F-Pin Coax Grounding...
Eton e5 sw shot
The SW FET preamp transistor, Q1, on the underside of the circuit board blows if a static electric discharge hits the whip antenna. In my case, a cat rubbing against me & the radio on a very dry winter day did it in. The back & circuit board has to be removed to get at it. The micro transistor & the solder connection are very tiny, so hard to replace. The antenna jack should still work, because the preamp is only for the whip antenna's SW reception. An easier solution would be to just run a wire from the antenna jack to the whip antenna, but you would no longer have the whip's preamp benefits, or just use a longwire antenna connected to the jack for SW. Also beware plugging into the jack disables the AM ferrite antenna inside, so you might not want anything plugged into it for AM reception because the internal ferrite seems to perform better than any external antenna.
Jan 17, 2013 | Eton E5 Radio
I want to use an external antenna. Is the antenna
There is a kit available which contains the antenna, mag mount, coax, and connector. OR if you already have your antenna, mag mount and coax, the connector alone is available. You should be able to get these from your local Motorola dealer.
best regards.
Dec 04, 2009 | Motorola Talkabout Distance DPS (10...
Local ABC and PBS stations do not come in. All others local stat
Check to make sure your DTV antenna is an "all band" antenna with reception in both the UHF and VHF bands. It sounds like you may be in Philadelphia area. In Philadelphia, all the DTV stations are in the UHF band except Ch 6 and Ch12, which are in the VHF band. Some of the DTV antennas are UHF only. You can tell if yours can receive VHF if it has the "rabbit ears" long wip antennas. If so make sure the whips are extended fully and turn the antenna to try to get a good signal.
Visit the 6ABC and WHYY websites for up to the minute information about the issues with reception issues.
Jun 16, 2009 | Insignia Digital-to-Analog Converter for...
2004 Jeep Wranler turn signal issue
load variation may not be proper causing that condition. Any chance you can use original lights?
Mar 19, 2009 | 2004 Jeep Wrangler
No sound on my kam uhf wireless mike
wire loose inside handset, or receiver output problem. wiggle the handset wires and listen for crackling. if so, repair or replace.
Jan 26, 2009 | RCA EZLINX 3 BNC male plus 2 male to...
Which connector to get for 1/4" Heliax LDF 150A cable?
get a PL 259, it is the male mate to the female so 239
Dec 28, 2008 | Uniden BCD396T Handheld Scanner
Fm Radio signal?
There was a black wire included (with a metal "cap" to insert in the FM center connector) that served as the FM antenna, but in a pinch any wire can do, preferably about 33" long and with the insulation stripped from the last inch or so (or get creative and sand the last inch of varnish off a properly sized untwisted clothes hanger and gently bend to suit). Bare stranded wire should be twisted or folded until it's thick enough to firmly fit the middle "hole" of the FM antenna connector. Be careful that no strands of wire short to the metal ground "ring" surrounding the hole or the antenna won't work (although it won't burn out your amp like shorting the speaker wires would, it just won't work). Orient the wire horizontally or vertically for best reception. This unit also doesn't pick up FM very well if you're in a steel-framed building or away from windows in the general direction of the local transmitters, so moving the unit closer to a window may help dramatically. In bad reception areas you can get an external FM "rabbit ears" type antenna but you'll need the "European" style of 300 ohm to 75 ohm transformer to plug it into the unit's FM connector (one that has a bigger central connector "plug" than the usual US units). Some cable systems also still support FM, if yours does, a VHF/UHF/FM signal splitter and either the above mentioned transformer attached to flat 300 ohm cable or a plain  "European" style connector attached to the end of the 75 ohm round black cable will do the trick. Some Radio Shacks have them. Good luck!
Jul 23, 2008 | JVC FS-5000 CD Shelf System
Midland handheld CB antenna
The connector that's part of the radio, or part of the antenna broke?
Oct 30, 2007 | Radio Communications
G4 Footswitch wiring
I have published an online guide...it may be of help to you. Just click on the link to view it.
Marci
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
May 25, 2007 | Kirby G4 Bagged Upright Vacuum
Telex Aat-2 Sound Mate Personal Listening System Sound Enhancement Box Logo
Top Telex Audio Players & Recorders Experts
Ben Armstrong
Sam Palermo
Sam Palermo
jairo sanchez
Are you a Telex Audio Player and Recorder Expert? Answer questions, earn points and help others
