Question about Cell Phones
Axivity heartrate monitor #17-12533. Can i charge it with my car charger? Connector fits and its charger charges my phone. How long do i leave it plugged in?
2 Suggested Answers
  • 306 Answers
SOURCE: Does leaving a cell phone charger plugged in to an outlet at home,without having the phone charging in it,drain energy from your home?
Yes. You are right. Here energy is not the criteria. It is always safe to unplug the charger (when not in use) to prevent the damage of a cell phone due to accidental over load of electricity or short circuits. Moreover Chargers do draw power when plugged in, whether or not a device is actually being charged.
If the charger is plugged in someplace easy to access, like right by where you keep your phone, you should unplug it. But if it would be difficult to have to plug it in every time you need to use it, you'll be fine just leaving it plugged in..and.It still uses energy even when not charging. Any electronic device plugged in a socket uses energy whether it is in use or not.
Posted on Oct 08, 2008
Why my phone keeps restarting
Battery may not be charged enough to run the phone. Keep the phone off and connect it to a charger to fully charge the battery or use an external battery charger.
Be sure the The micro usb connector is fully seated and that the battery is actually charging. A loose connection may appear to start the charging process, but if its loose, it may not be continuing to charge. Check the % progress.
Aug 11, 2014 | Samsung Galaxy S 4 GT-i9500 Smartphone...
Axivity heart monitor. Is there a way to charge it in a car?
You can buy a d/c to a/c converter that plugs into your cigarette lighter receptacle.
May 06, 2014 | Exercise & Fitness
MY SONY ERICSSON K790i doesnt charge when i keep it for charging it shows the message that "charging error stop charging" please show me the way how can i get out from it? yours govinda
You asked a  good question!  I am also using same mobile sony ericsson k790i .You'r mobile is fine,If you are using connector for charging means change that connector.If you leave your mobile for charging from the same connector also your mobile get charged but slowly.After changing connector also if you find same problem means take a new brand sony ericsson k790i charger.Then you will not get that error message any more. var geo_Partner = '687b82b2-54e8-44dc-93c0-87c73f39cdb0'; var geo_isCG = true;
Jun 10, 2011 | Sony Ericsson K790i Cellular Phone
Can't find my charge adapter for my Jazz HD 188. Will it charge by plugging into the USB port of my PC?
Some phones charge the battery in the camera like a phone, but many do not. This camera has a USB connection, which is meant to be used to transfer photos from the camera to a computer. If your (now lost) charger was plugged into the camera to charge it, and it plugged into the USB connector, then you can charge the camera with any lead that will fit the USB connector, as this will have a standard voltage. You can even charge it from the computer, without buying a separate charger.
However, if your charger charged the batteries outside the phone, by removing them from the phone and placing them in the charger, then it is very unlikely that they will charge in the phone, whatever you connect to it. I have a camera just like this, that requires an external charger.
Oct 30, 2010 | Jazz HDV-188 Camcorder
Lost power charger will a telephone charger with the right dc voltage work? jazz hdv188 also its a usb jack in camera instead of the little round holed one
Some phones charge the battery in the camera like a phone, but many do not. The USB connection is meant to be used to transfer photos from the camera to a computer. If your (now lost) charger was plugged into the camera to charge it, and it plugged into the USB connector, then you can charge the camera with any lead that will fit the USB connector, as this will have a standard voltage. You can even charge it from the computer, without buying a separate charger.
Oct 29, 2010 | Cameras
When charging nokia E71, it randomly stop, then continuing?
If you are having these problem with your nokia, there are two possible reasons why this should be happening;
1. You could be charging it with a faulty charger, and you should get another e71 charger for it. You can probably use this same presumed faulty charger on another nokia phone and if it does work well then it implies that the charger is fit and well. So please don't replace the charger.
2. This therefore leaves us with the last option which is the battery, please replace the battery you've got and your phone would charge normally.
Hope this helps as i presume that your charging port is very much ok.
Regards
Aug 05, 2009 | Nokia E71 Smartphone
Phone won't charge
Get a new charger, charger is probably broken. That's what happened to my charger before. And also don't leave your charger plugged when it's not being used.
Mar 11, 2009 | Samsung BlackJack II Smartphone
Charging
i think the solution to this problem is to let your cellphone go dead
my friend told me today that my d900i was overcharged so thats why it wouldnt charge throught the power outlet
let the battery cell die and than charge it
see if this helps ( i have to try it too , just waiting for my cell to go dead lol)
Sep 28, 2008 | Samsung SGH-D900 Cellular Phone
Nokia 1600 charging problem
the fuse is burned go to a cell phone service and have them replaced .
May 26, 2008 | Nokia 1600 Cellular Phone
Krzr won't turn on
I would inspect your connectors (both charger & phone) as well for dirt, debris, or damage.
I would also suggest using Motorola's wall chargers, the products seem to charge best with them rather than the after-market knock-offs which also seem to damage the phones connectors on some models.
If there is damage to your connector , you will need to get your phone serviced.
May 21, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Cell Phones Logo
13 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
