Question about Akai PDP4273M Television
How to plug a coaxial cable on akai pdp4273m
There in no input for a coaxial cable on the akai pdp4273m.the hook up panel don't supply a threade plug in for a coax
  • 10 Answers
SOURCE: AKAI PDP4273M Plasma tinted red
TRY THIS BY USING YOUR REMOTE 1-PRESS BRIGHTNESS 2-PRESS FREEZE 3-PRESS MENU 4-PRESS ENTER THIS WILL TAKE YOUR TV BACK TO FACTORY PRESETS. I WENT 3 MONTHS WITH NO TV BEFORE I FOUND THIS OUT.
Posted on Sep 20, 2007
  • 1779 Answers
SOURCE: without a coax. imput , how do i connect my cable
You have to use a cable box using the Red, Grn, Blue outputs along with the red & white audio, or use the HDMI if the box and your set has it.
Posted on Apr 08, 2010
SOURCE: I have a coaxial cable tv service but no female
You need to go to your local TV shop, and get a "F Connector" to "Belling-Lee" Converter.
http://cgi.ebay.com/Belling-Lee-PAL-TV-Antenna-Plug-to-F-Cable-2-Pack_W0QQitemZ110505841195QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item19baa9522b#ht_1024wt_1085
Give you an idea of what you are looking for,
Posted on Apr 09, 2010
Testimonial: "thanks"
futurework
  • 70 Answers
SOURCE: I have a 32
The unit will need to have the tuner module replaced. In some cases you can get the board that you need from www.shopjimmy.com Swapping a board out is not complex so you may want to do that yourself. Otherwise the unit will need to be repaired by a technician.
Posted on May 04, 2010
  • 19 Answers
SOURCE: I have a coaxial cable tv service but no coax port
Check Amazon.com for this: "Mygica SuperColor HD TV Box Video Converter Box."
http://www.amazon.com/Mygica-SuperColor-Converter-Definition-Standalone/dp/B000XY6N5Y/ref=sr_1_4?ie=UTF8&qid=1299386711&sr=8-4
that converter box is precisely what you need.
Posted on Mar 06, 2011
How do I hook up my tv?
what input jacks does it have .never saw one yet that does not have a coaxial cable connection unless they were made back in the late 50's
Dec 05, 2015 | Akai PDP4206EM Television
How to connect the cable to my Akai tv set without a cable input? I don't have a cable box.
If you get a cable box that has audio/video outputs on the rear connect them to a identical input on the rear of the set----direct connection and bypasses the coax fitting most sets have.
Go to the input you hooked to and leave set there--change channels via the box with its remote or manual buttons.
May 27, 2012 | Televison & Video
Where is the cable connection on my tv
There are usually two types of cables that connect to your tv-- coax and RCA. Cable usually uses the coax style, but some modern tvs don't have a coaxial input, which means they probably have RCA jacks. Therefore, you will probably have to find an RF modulator or the like that has a coax cable "Cable" input and RCA (yellow, white, and red plugs) output. These should be able to connect your tv to cable. I hope this helps, and good luck! Sincerely, Der Strom
Apr 09, 2010 | Protron PLTV-32 Television
HOW TO HOOK UP A ANTENNAE
Well you can follow the below steps -
1. Inspect the antenna for any signs of damage. Identify and examine the power adapter cord and the coaxial antenna cable for any rips tears or other defects.
2. Plug the adapter into the antenna's power adapter socket. It will be labeled "12V DC/Adapter". If you are using an antenna that does not require power, such as rabbit ears, you may skip this step.
3. Next connect the antenna cable to the television using the TV's "Antenna In/75 Ohm" input jack. Make sure the antenna connector is twisted tightly into place. Place the antenna on a sturdy surface such as the top of an entertainment center. If you have an older analog TV that is a non high definition ready/capable display and are using a digital to analog converter box, generally, the antenna will plug into the input of the converter and the output of the converter will plug into the antenna input of your TV.
4. Plug the antenna's power supply into a 120V AC wall outlet. This will turn the antenna on. If you are using the "rabbit ears" style antenna, make sure that the each section of the antenna is fully extended. This will give you the best reception.
5. Turn on the TV and check for digital reception. You will know that you are receiving digital signals because the picture will be clear and free of any analog "snow" or other artifacts. Digital TV channels have DVD quality picture and sound.
Follow the below link for more help -
http://www.wonderhowto.com/how-to-hook-tv-antenna-094240/
Good Luck!!
Mar 26, 2010 | Akai PDP4273M Television
Have an RCA F27636BC TV. Can u hook a DVD player
How to hookup TV
If you have a TV with only a single coax input and you want to hook up components like DVD players and VCRs, here's how to do it.
What you need to connect your DVD player or game players to a TV that only has a VHF/UHF 75-ohm F-connector ("coax antenna input").
1.) RF Modulator with Stereo Audio Inputs.
2.) 6 foot long coaxial cable with male "F" connectors. This cable goes from the modulator to the TV. The modulator also has a coaxial input to plug in your antenna or your VCR.
3.) 6 foot long Video and Audio Cables with "RCA" plugs. The cables connect the yellow, red and white outputs from your DVD or game player to the yellow, red and white inputs of the modulator.
Works with X-Box, PlayStation, Nintendo or other devices that output audio/video via the RCA plugs and you want to connect them to your coaxial only TV.
Nov 24, 2009 | RCA F27636BC 27" TV
CANNOT FIND CABLE CONNECTION FOR AKAI TV LCT42V6TN
They don't make a coaxial to RGB or Component adapter. I know they make a coaxial to RCA. If you go that route you would just connect the coaxial to the video. Now if you do this not sure as to what would happen with sound, if you would have it or not. It is possible but not sure. The adapter I am talking about is called a
UHF Female to RCA Male Coaxial Adapter. Which can be found at most Radio Shacks. If this doesn't work I would contact the cable company about a cable box that they could then run the coaxial to and then the RGB or Component cables to the TV.
Hope this helps.
Mar 01, 2009 | PC Connection RG6 Bulk Coax Cable, Plenum...
Connect magnavox dvd to ge tv HELP!
You need to go get an RF modulator. They can be purchased at Radio Shack or a number of other electronic shoppes for a reasonable price.
The RF modulator connects to the coax cable connector and it has inputs for the RCA connectors.
Cheers ... Best wishes
Jan 30, 2009 | Televison & Video
I have some issues with my akai hdmi model pdp4273m
You can download the manual from the akai website:
http://www.akaiusa.com/
I just did a search on "pdp4273m" at the akai website.
http://www.akaiusa.com/products_detail_features.aspx?cat=VISUAL%20ENTERTAINMENT&subcat=Plasma%20TV/Monitor&productno=PDP4273M
The manual is easy to download from there product page about the plasma.
The manual is a PDF, so I hope you have something like adobe acrobat to read the file.
http://www.adobe.com/
Feb 10, 2008 | Televison & Video
Televison & Video Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
