Question about Jet 3 Ultra Power Chair
I have a pronto m51 wheel chair got the joy stick wet it flashes 7 times how can i fixs it
  • 27 Answers
Here's your M51 manual:
http://www.invacare.com/doc_files/1125085J.pdf
Trouble codes start at p25.
Also, Invacare is proud of the M51's wet-weather performance (check the "Rain Test" chapter in the manual. You might have a warranty issue. Check with an Invacare dealer.
Posted on Feb 06, 2015
2 Suggested Answers
  • 17 Answers
SOURCE: Where do I go to find a price list of a new joy stick.
call 866-722-4581 for lowest prices: your M41 joystick is part# 1147600 and cost: $999.00
Posted on Sep 22, 2009
My m51 flashes 11 times on joy stick what is that
The diagnostic code would indicate a bad control box. It could also be too low a voltage from the batteries or a bad or broken wire or connector between the joystick and the control box. Chair will need a technician from a good dealer to help out if battery's and wiring are good.
Sep 09, 2015 | Invacare Pronto M51 Power Wheelchair
Light come on controller no flashing code lights joy stick does not work
The M51 could have the motor clutch levers in the free wheel/push mode and the joystick will not blink if this is the case. Make sure that the chair cannot be pushed. If it can be pushed it means it is in free wheel and you need to lock the motors in gear.
If it is in gear and the joysticks green light does not change color or blink it could be that the joystick is bad. When nothing happens and the lights don't blink when you push the joystick knob the chairs controller basically isn't recognizing the joystick movement.
Time to have the joystick repaired or more. Have a technician look at it.
Jun 16, 2015 | Invacare Pronto M51 Power Wheelchair
How do I reprogram my invacare pronto m51power chair
You will need to contact a service tech in your area to do this. They should have a special programmer box that can adjust the settings on the chair to improve the chairs performance.
May 02, 2015 | Invacare Pronto M51 Power Wheelchair
I get error code 9, what do I do to fix this
Error Code 9 is a "Communications Error". The controller, or "Little black box" down inside the chair is not talking to the joystick, etc. First, check all the connections. Unplug, examine and clean all of the connections going into the controller, and the joystick connection too. Inspect all of the cables for damage to the wiring. If all looks good, then you likely have a bad controller....ouch. These are very expensive to replace new. You might be able to find a used one on Ebay, etc., or you could be better off looking on sites like Craigslist for a complete powerchair replacement. I have found near-new chairs for under a thousand dollars. Search for Pride Jazzy chairs too...a lot more of those for sale than Invacare chairs. Good luck.
Jun 13, 2014 | Invacare Pronto M51 Power Wheelchair
When operating the Pronto M51 power wheelchair with the joystick, it will only move forward and backward. It will not turn. What do you think the problem is?
I would suggest that the micro switches that the joy stick operate have become faulty or got out of adjustment. contact the makers service agent to fix the problem
Sep 23, 2013 | Invacare Pronto M51 Power Wheelchair
My pronto m51 sure step service light is flashing seven time and it will only turn to the right
sarah check the joystick cable try unplugging it from the rear of the joystick and plugging it back in then unplug it at the back of the chair and plug it back then turn the chair on to see if you are still getting 7 flashes. If you are then you have one of 2 problems the joystick cable somehow is bad or the joystick itself has got a problem try the cables first to see if it fixes the problem If Medicare paid for the chair then they will pay for most of the repair Contact Roadrunner Mobility @ 1-800-467-2668 Hope this helps you
Apr 02, 2011 | Invacare Health & Beauty
Won't move pronto m51
Three lights flashing on your chair indicate a left motor fault. Make sure that all of the connections inside the shroud are tight by physically testing them. If all of the connections are good, and the fuses are good, then it's time for a trip to an authorized repair facility. Here is a link to the M51 owners manual if you haven't one. Page 24 has the fault code guide.
http://www.invacare.com/doc_files/1125085.pdf
The controller monitors all of the functions on the chair, brakes, motors, joystick, charger etc. The three flash fault indicates an "open" circuit. Open, like a switch or blown fuse is open, or a wire is cut or burned in half, or a connector is unconnected, or partially connected. The latter is what you are hoping for. Wires burned in half is the usual cause for a motor fault, and with powerchairs, is usually the result of the chair getting stuck in or against something it can't get out of and the operator over-amping the motors. Motors do, just go bad sometimes, for no reason. Very rarerly, however.
You can also check the brushes on the motor too. There's two quarter-sized black plastic screw-plugs on the ends of the motor opposite each other. Unscrew them and examine the brushes. The springy coils should be springy. Overheating can cause them to be brittle, or even burned in two. Check the lench of the brush, the dark rectangular cube at the end of the springs. It should be curved and polished at the end, and a little over a half-inch long. If it is near a 1/4 inch, it needs replaced, or if there is any evidence of overheating, replace. Good luck.
Apr 19, 2009 | Invacare Pronto M51 Power Wheelchair
Jet 3 Ultra Power Chair Logo
149 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
MobilityRepairSpecia...
Level 1 Expert
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
