JVC AM FM CD DET FACE CAR STEREO
Problem for JVC AM FM CD DET FACE CAR STEREO
JVC12 DISC CHANGER CH-X550 jammed
By goodone16 on Jun 22, 2009
This is out of warranty; was playing a disc, no. 7 of 12 when suddenly it jammed up. Shows message RESET 01. I followed the printed instruction to hold the reset button ... repeatedly & tried switching car on/off ... and tried wiggling the cassette ... no luck
I contacted the retailer - can't help & does not have a JVC repeairs nubre; tried jvc.co.uk - has everything except someone to contact re repairs.
Any suggestions welcoeme. Either (a) Any way to 'self repair' it or (b) a JVC repair phone number or (c) if I go ahead & buy a replacement ... how to get my discs out!!!! Thanks, Robin from Kent
Comments:
Jun 22, 2009
- Thanks MNfisherman;
I've got as far as I can with the 'easy' bits; removed the sliding top cover and the main metal case (which comprises one 10" x 6" plate, the two 3" x 6" end plates and the base 'half strip', 1½" x 6").
The cassette box remains enclosed on all sides except the top. On one side it is covered by the circuit board on the other by the remaining 10" x 6"\plate. I see no way of removing, or 'getting at' the cassette box without 'major intrusion'. Hmhhh ... pondering whether it's worth a more drastic 'next step' ... it would be great if there were some sotrt of manual 'release' to free the cassette box ... have probed around and haven't come across anything so far.
ps: I'm new to this amazing site & am happy to mak payment for time, so long as there's a reasonable bet someone's knowledge of the unit gives a reasonable chance of a solution.
Best Solution
posted on Jul 04, 2009
Very Helpful)
keepdancin7
Rank: Apprentice
Rating: 100%, 1 votes
to manually eject the cd cassette pierce the protective seel on the compulsory eject hole located on the left side of the unit, use a long narrow object like electrical screwdriver and carefully insert it, make sure you put it in straight.
the cd cassette will then eject allowing you to remove cd's.
after re-insertion repeat the re-set procedure by holding in the eject button on unit.
hope this helps
KDX
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jun 22, 2009
Very Helpful)
MNfisherman
Rank: Wiz  JVC Expert
Rating: 85%, 2846 votes
I would pull off cover, unscrew and remove top carriage of tray and remove your disc. While your at it you should take cotton swab and dip it in rubbing alcohol and clean the laser lens. Then reinstall carriage and top cover and try using it again.
Was this helpful?
Yes
No
Popular Solutions for JVC AM FM CD DET FACE CAR
Questions and Unsolved Problems for JVC AM FM CD DET FACE CAR
Do you recommend JVC AM FM CD DET FACE CAR STEREO?
Answer
Answer
is there a way to get better signal for the FM station
Answer
I just bought a JVC KD-s15, when we hooked it up, we have power, but nothing else is working...
Answer
I am attempting to incorperate a car stereo player and speaker set into a coffee table, for my A... (More)
Answer
My car stereo have problem that when i increase the volume it suddenly jumps like if volume is 12... (More)
Describe your In Dash Receivers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top In Dash Receiver Experts
Top Audio & Video Equipment Repairmen
in Newport, KY
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
