How do you remove the housing to access the coils for cleaning on a Rheem RACC-036JAS?
  • 52 Answers
Not completely just the fan assembly and wash from inside out only in extreme cases do you remove entire housing
Posted on Aug 25, 2009
How to clean inside Coils for Rheem model # RRKA-A036JK08E
There is a product called "Coil Brite" That is designed to clean coils. It is a spray on liquid that will dissolve the crud built up on the coils.
Aug 27, 2014 | Heating & Cooling
The instructions on my Richmond tankless water heater talk about cleaning a water filter but give info on where it is or how to remove it I have a rmtgl74pvn
The manual may be suggesting that you clean in-line water filter installed before tankless unit.
Tankless might also have a screen filter where water enters unit.
Open following link for troubleshooting resources:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Contact Rheem:
http://www.rheem.com/products/tankless_water_heaters/customer_support/
Jul 04, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
The insturtions talk about cleaning a water filter but give info on where it is or how to remove it I have a rmtgl74pvn
Contact Rheem:
Clean coil light is on
The coil they are referring to is the condenser coil, which will be located underneath, and can be accessed either by removing the toe plate in front, or by pulling the cabinet from the wall, removing the machine compartment cover by removing the screws. In both cases its best to use an appliance brush or lint brush available at any hardware store, these brushes are about 2' in length, and contain black plastic bristles, and of course, unplug your refrigerator before doing any maintenance. Remove the dust and pet hair from the condenser with the brush, then vacuum the brush clean and repeat.
Jun 28, 2010 | Amana 22.6 cu. ft. Side-By-Side...
I have a Ruud Model # UACC-036JAS. Any idea on
Hi, yes the number you are showing me 036 indicates its a 3 ton unit. For every ton of cooling, you will have 12,000 btu's of cooling. 36 divided by 12=3 ton unit. Its showing me also its a Ruud Handler 2.0 ton which would be a Model# UACC-024JAS? If your mobel number is the one you gave me, UACC-036JAS, this is a 3 ton unit, absolutely no questions. I hope I have been of help to you. I am a licensed air conditioning / Refrigeration /Heating Contractor. Let me know if I have been of help.
Sincerely,
Shastalaker7
PS If this is a split system with the indoor air handler and condenser outdoors, both coils must be the same tonnage for it to work for you properly. You can't have a 2 ton indoor evaporator coil with a 3 ton condensing unit.
Jun 28, 2010 | Ruud Handler Air Conditioner
Want to clean evaporator coils on Goodman A/C. It's a roof unit. the Heater, A/C evaporator and condesenor, both fans, are all in this unit. No way to get to the A/C evaporator to clean the coils. How do I...
There is an access panels on some package units. If you cant find the access panel then remove the top. I use a garden house. Make sure to kill the power to the unit before servicing.
Jun 27, 2010 | Goodman CLQ36AR49 Air Conditioner
I want to clean my rheem air handler coils with out taking it
If it was me, i'd remove as much of the case to allow access to the coils on both sides. Using a soft brush so as to not damage the fins, brush any rubbish from the air on face. Then use an airline to gently blow the opposite way to normal air direction. There could be a lot of dust and **** so it is best to do this outside wearing a dust mask. A vacuum cleaner may work if you don't have access to an airline. Just make sure any bent over fins are carefully straightened again afterwards. If you block the gap you will get reduced airflow.
Aug 15, 2009 | Ruud Central System Air Conditioner
Rheem raka 036jas
This is not a stuck TXV.
If you have a AC and not a heat pump you have bad valves in the compressor and it will have to be replaced.
Aug 05, 2009 | Ruud Central System Air Conditioner
Have Rheem 5 ton heat pump with stacked coils poor cool.
If your sure on the psi your low on freon or your evaporator is restricted discharge psi would realy help.you will get best performance with a clean unit or pay expensive utility bill . Tom
Jun 18, 2009 | Ruud Central System Air Conditioner
Replace Contactor Relay on Rheem Air Condenser
I have a Rheem heat pump/airconditioner, Mod # RPFA-036JAS, that I have had problems with for at least 5 years and have paid over $1,000 in parts and service calls. I can vever recreate the problem when a tech is here. It usually happens in the middle of the night. I hear a Click, ckick, click sound, through the unit and it sounds like it is comming out of my air handler, but the outside unit also clicks at the contactor and the condensor cooling fan moter will start and stop about every half secongd or second. Both contactors have been replaced, the small one twice, one capaciter
has been replaced. I allow the unit too cool down and its alright for a few hours. That is difficult when the outside temp is below zero. HELP PLEASE!
Feb 16, 2009 | Heating & Cooling
Heating & Cooling Logo
194 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
