Question about iLO (2 GB) MP3 Player
Flash disk write protected. nostorage device policies key in my registry so that edit won't work
2 Suggested Answers
SOURCE: "storage device policies" key is missing from my registry...!!!
my mp3 player says that it is write protected when i plug it in ,.... so i was directed to change the HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control \StorageDevicePolicies value from 1 to 0 .... when it looked it up i saw that inside the control folder the "storagedevicepolicies " is missing... my comp is normal and is not behaving abnormal..... plz help.... thanks in advance..
Posted on Mar 17, 2010
How to remove the write protection om my usb. I tried to open HKEY_ Local_ Machine and i cant see the storage device policies. Can u just tell me how to solve this problem
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
Apr 20, 2011 | Computers & Internet
Instructions for password protection option on Maxell usb 360 flash drive
click start control panel administrive tools computer management disk management right click on your drive select properties then security select take full control in windows 7
also
- Click permissions
hope this helps
Mar 20, 2011 | Computers & Internet
Sir good after. I have 4GB transcend 2.0 pendrive while copy some thing to penrive this drive a message is comming like " this disk can not be written to bacause it is trite protected please remove...
Go start menu then click run and type regedit then ok.
HKEY_LOCAL_MACHINES/SYSTEMS/current control set/control/storage device policies.
note:if storage device policies key does not exist then download add.bat file and double click it. After double click it is added automatically to registry.
Double click the write protect in the right pane and set the value to 0 in the value data box and press ok button.
restart your computer and again reconnect the pen drive on your computer.
Mar 20, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My ufd won' format, the computer said it is right protected!
also
- Click permissions
hope this helps don
Mar 07, 2011 | Kingston Digital 4GB DATATRAVELER C10...
It always shows the disk is write protected
also
- Click permissions
hope this helps don
Feb 28, 2011 | Kingston (SDCZ2-512-A10-KT)...
Device media is write protected
To disable writing access to USB drives and make all USB drives has only read-only access, follow these steps:
  1. Run Registry Editor (regedit).
  2. Navigate to the following registry key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
  3. Create a New Key named as StorageDevicePolicies.
  4. Highlight StorageDevicePolicies, and then create a New DWORD (32-bit) Value named as WriteProtect.
  5. Double click on WriteProtect, and set its value data to 1. write-protect-usb.jpg
Once set, all users on the computer is now blocked and prevented from copying, transferring or writing any files, documents and data to the USB disk drives, without the need to restart or reboot computer. Any attempt to download or copy files to USB drive will return the following error message:
The disk is write protected.
The media is write-protected.
Remove the write protection or use another disk.
usb-removable-disk-write-protected.jpg To revert and remove the blocked write access to USB drivers, just delete the StorageDevicePolicies registry key, or delete the WriteProtect registry entry, or change the value data for WriteProtect to 0.
For user who doesn't want to manually editing the registry, simply download the following registry registration files to enable or disable the write protection (block writing attempt) to USB removable drive. Double click the .reg file unpacked from the .zip archive to merge the registry key entries.
Download DisableWriteToUSB.reg
Download EnableWriteToUSB.reg
The trick works in Windows XP SP2 and SP3, Windows Vista, Windows Server 2003 and 2008.
Feb 27, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I cant delete my files on my flash drive everytime i click it the WRITE PROTECTED always prompt! that i need to unlock it
I found this on another site, I tried it down to finding the usb device, you do the remaining part at your own risk, I'm very cautious about editing my registry.
Gary
# # Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
Read more: http://wiki.answers.com/Q/How_do_you_remove_write_protected_error_for_the_flash_drive#ixzz1EnkYwY1p
Feb 23, 2011 | Home
How to remove write protection?
also
- Click permissions
hope this helps
don
Feb 23, 2011 | Computers & Internet
My Kingston 4 GB Pen Drive became Write Protected.
Write Protection on any portable USB Device can be applied by the physical lock provided on the card adjuster or some times provided on the pen drives, so make sure to make your drive not write protected by moving the lock in right direction.
But even after moving the physical lock for write protection the problem can happen due to some virus action. This happens when some virus or script which applies the registry hack to make any drive write protect when connected to the computer, In that case follow the procedure below to remove write protection from your pen drive.
1. Open Start Menu >> Run, type reg edit and press Enter, this will open the registry editor.
2. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note: If the registry key Storage Device Policies key does not exist, you will need to create it
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
3. Double click the key Write Protect in the right pane and set the value to 0 in the Value Data Box and press OK button
Please rate me if this solution works for you
Thanks......Have a great time
Jul 02, 2010 | Electronics - Others
How to remove the write-protection in my FLASH DRIVE?
  1. Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "use device" or "driverdesc" to open usb mass storage device. right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
  2. Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
Jun 14, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
iLO (2 GB) MP3 Player Logo
32 people viewed this question
Top iLO Audio Players & Recorders Experts
Michael Vincent Cruz
Allen Benge
Level 1 Expert
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
