Question about Ovens
Accubake overheating After my mother in law tried to cook (not knowing how to use this digital oven)it has not been working right. When we got it used the temperature was not heating up to an accurate temperature. Now after she tried to use it, the oven just stays on a very high temperature no matter what tempature you put it on and you can see that the bottom burner does not cut off. I have tried to figure out what is wrong with it but can't. Now I have to sit next to it the whole time and keep turning it off and on. The first time I used it after she tried it cooked for about 3 hours then it started beeping and turned itself off. It was extremely hot. Please help
  • 183 Answers
SOURCE: Gas oven not heating to temp
The fault is either the capillary has fallen away from back or it is a faulty thermostat.
Regards
Advisor
Posted on Nov 17, 2007
aborcass
  • 2651 Answers
SOURCE: Oven too hot!!
sounds like a bad oven temp sensor, small 3-6 inch, metal probe in upper left corner of inner cavity, 2 screws and the sensor should pull right out, replace you should be fine
Posted on Dec 08, 2008
  • 23 Answers
SOURCE: I have a turbochef C3 and it works fine. It heats
the oven is not really able to cook on the fly,it is pre programmed so the times are set due to weight and mass.try to use the programs already set up and then trial and error will show which 1 to use,hope this helps
Posted on Jul 16, 2009
mrfixit3667
  • 262 Answers
SOURCE: My oven, model 38HN-6TVW won't preheat
I was unable to get the full model to come up. I was able to get a Magic chef range to come up. I would replace the control and oven thermostat.
Posted on Jan 07, 2010
SOURCE: Hotpoint Glasstop Stove - Burner turns on by itself
I have a GE stove which I purchased in 2004, and it is doing the same. I heard beeping coming from the kitchen in the middle of the night . I went to the kitchen and the oven was on by itself. I have been unplugging it when not using it. Maybe this could be a recall.
Posted on Mar 18, 2010
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Whirlpool Gas Oven Will Not Stay Lit
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
More results from forum.appliancepartspros.com
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
Whirlpool oven/stove with accubake. The cook top works with no problems the clock and display work with no problems. The oven does not work at all no bake no broil. Got it to work a couple time by...
Take a look at the oven ignitor,you might have two.The one at the top is the broiler ignitor.And the one at the bottom is your oven ignitor under your lower oven plate.
Feb 21, 2013 | Ovens
My whirlpool double oven accubake GBD307PDS09 display went blank!!!! HELP!
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty. GBD RBD Whirlpool Oven Problems Causes and Solutions
May 03, 2017 | Whirlpool GBD307PD Electric Double Oven
I have a whirlpool accubake duo, super capacity 465 and when I try to bake something the oven wont stay on...how do I get the oven to stay on
What do you mean that it wont stay on? Does it turn off and on during cooking? Does it just go off and wont come back on? The oven thermostat regulates the heat in the oven and the oven element and the oven indicator light will turn off and on during cooking. If it stayed on constantly on full oven element power everything would burn.
Mar 01, 2011 | Whirlpool Ovens
Whirlpool Accubake instructions
I have lost my instruction manual and I need to know how to use the self-cleaning feature on my range
Oct 03, 2009 | Ovens
Wirlpool gold accubake system is not working properly. Broiler works but oven does not heat up properly
If your broiler is working but not the oven, you just need a new bake element. This is a very simply part to replace. Just give us a call or email us with your model number and we;ll send the correct part out to you right away. 972-859-0929. We'll ship this to you and you'll be cooking in no time! We look forward to working with you and hope to hear from you soon. :>)
Oven overheating
Set the oven thermostat to 100 degrees ( very low heat) and wait to see if the onen indicator goes off. If it doesn't then the oven thermostat may be faulty. If you have an oven thermometer, then use that to check the oven temperature.
Sep 20, 2009 | Fisher and Paykel AeroTech - OS302M...
Whirlpool accubake oven troubleshooting
electric oven heats to correcect temp then drops and does not get back too appropriate temp. For example, set at 400, gets there then drops to 275-300
Dec 18, 2007 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
