Question about Dual Electronics CECT P168 Cellular Phone
Sciphone i68+ won't dial out
My sciphone i68+ will read my sim card but I am having trouble with it registering to my network. It will not allow me to send or receive messages, or call out or receive calls.
  • 3 Answers
Here is the fix:
Posted on Nov 21, 2010
Noticed similar problem around.
If you dial *#8375# and see "MAUI" on it firmware specs you have a fake phone in hands.
To fix it you must change your phone's firmware.
Posted on Jul 05, 2009
Hey I have a problem, my chineese iphone 4- when i try to call it makes a message: " not allowed do dial" and I can't change my prefferred mode from WLAN only to GSM only.. how to fix it?...
Not Allowed to Dial Error Message on a SciPhone i68 4Gsciphone-i68-4g.pngI recently purchased a SciPhone 4G with a dual sim card phone. I was very happy with this phone. I had no problems until one day I couldn't call out. I kept getting a not allowed to dial message every time I tried to call anyone.
I could still receive calls and send and receive texts but I couldn't call out. After quite a bit of research on the internet I came up with a solution. None of the solutions available had all the information I needed I just kept trying different combinations until it worked.
Here is the step by step solution I used to remove the "not allowed to dial" message and allow me to dial out again.
  1. turn off the phone
  2. place 2 sims on the phone
  3. restart the phone
  4. keep the WLAN disabled
  5. enter the engineering mode * # 82043036 #
  6. select the option RF Test Tool (on my phone it's option 13)
  7. Select GSM, to accept him
  8. go to Power scan
  9. go to Band Select and select OK DCS1800
  10. another screen will appear (model F003) look at each of the options until you find one that will have your phone appear unresponsive (this locked)
  11. pressing the main button (the box) will take you to the home screen
  12. go to the setup menu
  13. go to network settings menu SIM1
  14. this is a preferred mode
  15. select one of the preferred modes GSM or WILAN
  16. restart the phone and you should be ready to make calls
sciphone-i68-4g.jpgYou just enter the code/s into the phone number area in the dial section and the phone will recognize it and enter into the proper mode.
I still love this phone. It has built in WIFI so I can surf the internet with out having to have a data plan from my service provider. I use T-Mobile.
Here are the particulars on my SciPhone:
Mode: i68 Quad Band Phone
Specifications:
  • Dual SIM
  • Dual Standby
  • WiFi
  • Bluetooth
Mar 17, 2011 | Cell Phones
Sciphone i68 4g: not allowed to dial
I have this problem on my sciphone i68 4g also. I got it fixed with the solution on this website as below:
how to solve the problem of not allowed to dial on Sciphone i68 4G
Jan 23, 2011 | Cell Phones
My sciphone i68 says emergency calls only when i try to use it
We had the same problem on both of our new sciphones. After long hours of research we finally found an easy solution to it so hope this helps.
1) Shut down your phone completely (you will know because a red sign will come up on your phone and you have to confirm that you are shutting it down).
2) Take our your battery and then your sim card
3) Make sure that your sim card is in the right way. (It has to be on the highest slot, not the one closest to the bottomof the phone, and the metal plates have to be facing down, or towards the phone).
4) Reinsert your battery and then start your phone up again
5) Go to restore factory settings and plug in the code 1122 when it asks for one. NOTE: Your phone will reboot, and when it turns on it should be okay.
We tried everything and this is the only thing that worked. We had t-mobile sim cards for both phones and it worked fine. Good luck!
-twins-
Jun 20, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
My sciphone i68 + doesn't read my sim card
flip the sim card over and cutoff the other sim slot example"if chip is face down make it face up" if that doesnt work switch to other sim slot and repeat the steps above if that doesnt work you can go to this link for more help
http://www.freewebs.com/sciphone/index.htm
Jun 10, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Cant get my sciphone to work
okay turn your phone off take the back off ,battery and take the sim card out now put the battery back in with out sim card .. turn on. now go open sim and close sim 2... turn off...remove back and battery put sim card in slot 1 make sure its in all the way put battery and back on ... turn the phone on... give it a few minutes it should work....
Jun 06, 2009 | Dual Electronics CECT P168 Cellular Phone
I just get sciphone i68, and i inserted the sim card [virgin mobile precisely] and the network bar shows 5 bar, which suppose to indicate that the network is ok, but if i try to call, it always indicated...
i have a i68 8g sciphone i put my sim card in the phone and it won't let me dial any numbers i mean i can dial but all it says is fail and it won't let me choose a network i have service but when i look at my main screen it says sims card 2 closed because i closed it but in slot one it says emergency how can i fix the problem please help!
Apr 10, 2009 | Dual Electronics CECT P168 Cellular Phone
+i68 sciphone will not register to tmobile
i m using sciphone i68 in india
here new rules coming for china mobile registration so how i register my mobile
Mar 19, 2009 | Cell Phones
Sci-phone applications
Most of these I68 SCIPHONES have the same imei number, and alot of these are being blocked. So dont be suprised if you wake up one morning and it doesnt work.
Mar 18, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
I just bought a sciphone i68 & my sim card from my old phone won't work in it. Do I have to get another sim card?
Slide the sim card back and forth slowly in the correct slot oriented correctly make sure you're in the correct slot, there are two. Mine did the same thing and it fixed it.
Oct 21, 2008 | Cell Phones
Dual Electronics CECT P168 Cellular Phone Logo
655 people viewed this question
Top Dual Cell Phones Experts
William Alequin
270rexton
270rexton
iphone service
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
