Question about Saws
Why the door don't close or open completly
The door doesn't close or open copletly
5 Suggested Answers
  • 54 Answers
SOURCE: Oven door won't close completely
You will probably have to replace the springs I doubt if they can ve fixed. you can open the door all the way and you will see a hole in the spring just inside the door. you can stick a nail in that hole, both springs that will hold the door open and you can lift the door out and check the springs I will tell you to have patience its not easy.
Posted on Apr 22, 2010
woobie dog
  • 1273 Answers
SOURCE: Our Chamberlain garage door will
Hi, W/D here.
Check the alignment of the photoelectric door eyes, located at ankle height on either side of the door. Usually, something is preventing the light from reaching the other side (receptor), and check to make sure that the eye lenses are clean. (You cannot actually see the light beam). Check that the lights are on and (usually) green on both sides of the door. These are the indicators that show you that the sensors are working. If one has been knocked out of alignment, it can be re-aligned using a string line, and observing the lights on the light and receptor. Somewhat more common is that one of the wires is either touching the other, or has come loose. Usually, the wires are just twisted together at the eyes. Lastly, if you have no lights lit on the eyes, and adjusting doesn't resolve the issue, one may be defective. Replacements are available at Lowe's/Home Depot, and others.
Check your lights first, and look for something blocking the path of the light.
Best Regards, --W/D--
Posted on Jan 28, 2011
gopakumarg43
  • 74211 Answers
SOURCE: Open & close disc doesn't work. It is
Hello
There are three possibilities for this trouble with this DVD player. The first one is imprper loading function due to loading motor or loading belt trouble. If loading motor is weak [that is its pulling power has gone low] the tray will not close properly into the mechanism, and will not touch the load sensor switch fitted inside the mechanism. If this happens, the main system control IC will detect improper loading and will turn the tray out again to load it properly. Just try to close it without a disc inside the tray, and check whether it closes well. If it does so, or the trouble repeats, change the loading belt first. In most cases, this will retify this type of trouble.
The second one is, bad 'Sled' motor. sled motor is one, which spins the disc inside the mechanism. After proper loading, if the disc do not spin inside it, again the system control IC will sense it, and will eject the tray. The sled motor also is a replacable part.
The third one is, damaged gear wheel in the loading gear section. to detect and repair any of above trouble, you have to open your DVD player, and take the DVD mechanism out of it, and is somewhat semi-skilled work indeed. Check these first. If you want anymore assistance from me, feel free to get be by fixya. If you are somewhat skilled, and have confidence and can follow the diagrams, send your email address to me by FixYa. I'll send the service manual of your DVD player by return mail. All details and disassemblng procedure are in it. OK
Posted on Jun 12, 2011
dustydis
  • 373 Answers
SOURCE: lexus 2007 RX350 trunk door doesn't open or close from key, trunk button and power door button
OPEN MANUALLY AND CHECK THE STRUTS PS. IF WHEN YOU OPEN IT AND IT GOES BACK DOWN THAT'S YOUR PROBLEM
Posted on Sep 26, 2012
Need gaskets for CSX20E Hotpoint side by side
Seals don't lose their magnetism. Check the door closes all the way round and adjust the hinges if it doesn't sit straight. Check there isn't a relief valve frozen up or blocked (it allows air to escape when the doors are closed). Check the drawers are fully pushed back in and not stopping the door closing properly
Sep 11, 2012 | Hotpoint Refrigerators
My seal hifi, model number w3 7rw when CD is put in player the unit doesn't play CD, the door keeps opening
The loading sequence is not completing the cycle when the tray door closes because of slipping belt, or the laser pickup assembly is faulty.
Apr 15, 2012 | Audio Players & Recorders
Garage door will not close from remote or car. Garage door will open from remote or car; however, it will not close using these controls. The only way I can close the garage door is to press on the manual...
Try reprograming the opener to each remote, if this doesn't work then the command/radio module in the opener is damaged and needs to be replaced. Hopefully you can find one or you will have to replace the whole garage door opener. Good luck.
Jan 21, 2012 | liftmaster Chamberlain Garage Door Opener...
Does this pull a vacumn when either door closes? The freezer side doesn't seem to do that now. Getting frost buildup in chut where ice is dispensed. Don't see a problem with the door seal.
Take a knee at freezer door while closed - LOOK UP! Look up through where the ice comes out, that door is stuck open! Try cleaning with warm hot soapy water.
Please rate us 4 thumbs up!!!! Tips Provided by: GOFAR Services, LLC - Refrigerator repair Houston, Katy, Spring and Woodlands, TX!
Aug 29, 2011 | GE GSS20IEP Side by Side Refrigerator
The garage door remotes and keypad works only when i,m very close to opener, will not work at more then 6 ft away from opener. sears hbw0777
How old are the batteries in the remotes and keypad? Replace the batteries. If that helps, then you have solved the problem.
If it doesn't help, then check the antenna wire of the opener. (Make sure it is extended down from the unit.) Note this doesn't apply to all garage door openers. (We have several models - some with the external antenna and some without.)
Does your garage have metal walls and metal doors? This can shorten the range between the receiver and the remotes or keypad. An antenna extension may be available.
I don't see the HBW077 as a model number at Sears Parts Direct or Manage My Life. Please check the model and let me know if I can provide any additional assistance. (Sears Parts Direct has parts for my garage door openers. Manage My Life has manuals for Craftsman and Sears appliances.)
I hope this helps.
Aug 04, 2011 | Garden
I have to get a letter typed and don't know how to open the machine to change the ink????
  1. Open the cartridge access door. Figure 4: Open the cartridge access doorc00127636.gif
  2. Raise the cartridge latches for both cartridges. Figure 5: Raise cartridge latchesc00127637.gif
  3. Remove the protective tape from the end of the cartridges. Figure 6: Remove tapec00127639.gif
  4. Insert the cartridges into the carriage. Figure 7: Insert cartridgec00127642.gif
  5. Close the latches, and then close the cartridge access door. Figure 8: Close latchc00127644.gif The control panel displays a message prompting you to align the cartridges.
  6. Press the Enter button to start the cartridge alignment. Wait until the alignment completes before continuing.
Jun 24, 2011 | HP PSC 750 All-In-One InkJet Printer
Water will not drain out but the water pump keeps running even when the door is openned or closed.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jun 16, 2011 | Asko 24 in. D3120 Dishwasher
I have a Kenmore model#1069557915 S#SG1047043 03/97 Coldspot Just recently the main door doesn't completely close, any recommendations?
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Sep 17, 2009 | Refrigerators
Power Door Light Stays on after battery was changed by a service department
follow this to reinitialize
1. Push the “MAIN” power switch to the “OFF” position.
The “MAIN” power switch is located on the instrument panel, left of the
steering column.
2. Confirm doors are closed, lights are OFF, and the key is out of the ignition.
3. Disconnect the negative (–) battery terminal and wait 60 seconds.
4. Reconnect the negative (–) battery terminal.
5. Push the “MAIN” power switch to the “ON” position and wait 3 seconds.
6. Push the “DOOR R” switch to open the right door and wait 3 seconds after the door
is completely opened.
7. Push the “DOOR R” switch to close the right door and wait 3 seconds after the door
is completely closed.
8. Push the “DOOR R” switch to open the right door and wait 3 seconds after the door
9. Push the “DOOR R” switch to close the right door and wait 3 seconds after the door
10. Push the “DOOR L” switch to open the left door and wait 3 seconds after the door is
completely opened.
11. Push the “DOOR L” switch to close the left door and wait 3 seconds after the door is
completely closed.
12. Push the “DOOR L” switch to open the left door and wait 3 seconds after the door is
completely opened.
13. Push the “DOOR L” switch to close the left door and wait for the door to
completely close.
With ignition in the “ON” position and both power sliding doors in the fully closed
position, the “PWR DOOR” indicator on the dash should NOT illuminate.
14. Confirm proper operation of both doors using the dash, B-pillar switches, and the
transmitter button
Aug 12, 2009 | 2001 Toyota Sienna
Frigidaire Front load washer mold
LEAVING DOOR OPEN BETWEEN USES ALLOWS WASHER TO BREATHE. BEING A CLOSED SYSTEM, IT'S KIND OF LIKE PUTTING A TUPPERWARE LID ON A BOWL WITH RESIDUE AND MOISTURE INSIDE AND LETTING IT GROW.
Nov 03, 2008 | Frigidaire ATF6000ES Front Load Washer
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
