Question about SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Won't sync When i was trying To sync amessage poped up and said it could not find the file or it's benn moved renamed or deleted
  • 115 Answers
Are you using vista? you may need to uninstall that application that syncs and reinstall it. Usually this happens when he original source file that it wants to save to is changed.
Posted on Jun 22, 2009
When I use any internet radio chats, it says "Windows Media Player cannot find the file. If you are trying to play, burn, or sync an item that is in your library, the item might point to a file that has...
Uninstall and Reinstall Windows Media Player
OR
Open up Programs and Features >> "Change/Repair" Windows Media Player.
Does this happen with all files?
Oct 31, 2017 | Dell Computers & Internet
I have an Acer aspire one netbook. ?; why cant i rename a file. Its in, Computer-Ascer(C:)-Users-. There are two files in this folder. Im not able to rename either. Is there a way to rename them?
If you have the file open or part of the content of the file is in use some place in the pc it wont let you rename it
try open the file as an administrator in safe mode or it might be read only attributes
copy paste soem place else see if it lets you then change name
rename and save some place else
There are several reasons why Windows might not allow you to delete a file:
  • The file might be in use in which case you can't delete the file until the program using it gives it up.
  • The file might be marked read-only.
  • The file name might be so long that Windows can't handle it. File names with more than 260 characters in them are often difficult to delete.
There are also several reasons why Windows might not allow you to change the name of a file; particularly its extension. All above apply here; as well as...
  • Your system may not be showing file extensions by default.
We'll cover that one first and the others in turn.
File Extensions Not ShowingThis is the most likely possibility for why you might not be able to change a file's type (i.e., rename the file extension). When Windows installs, one of the defaults is to turn off the showing of the full names for common file types. Basically, in Windows Explorer only the file's rootname shows; the extension is suppressed, yet is "shown" via the description in the File Type column of the Windows Explorer display.
When Windows is set up this way, if you attempt to change a file's name you are only allowed to change the rootname of the file but not its extension. So, if you have a file that shows up as MYFILE as file type Text and you attempt to rename the file to MYFILE.DOC what you really have done is rename MYFILE.TXT to MYFILE.DOC.TXT and the file type in Explorer will remain Text instead of changing to a Word File.
How to you fix this? FILExt has a different FAQ here that explains the procedure in detail.
The File is in UseA file in use by the operating system generally can't be changed while the file is in use. A file in use by a program may or may not be able to be changed. These are not hard and fast rules and exceptions abound; particularly in a multi-user environment. But, if you try to rename or delete a file and Windows complains that the file is in use don't be surprised.
To fix this you have to determine what is using the file. The error message that Windows pops up may or may not have that information in it.
If you don't want to experiment a bit to figure out what might be using the file you can restart the computer with all startup options turned off. This will most likely not run whatever was using the file and the system will allow you to rename the file. Recognize that if you do this and then restart the computer with all startup options enabled some program will likely complain that it can no longer find the file you just renamed. This may or may not affect how your system performs (or even operates at all).
To change the startup options, use the System Configuration Utility.
  • Click on the Start Menu.
  • Click on the Run item.
  • Type msconfig into the dialog box and click OK.
Use the various startup options settings to reconfigure your system startup as needed to find the subject program or process. Remember the caveat about how changing the name of a file a program or the system uses might affect system behavior. Keep good records so you can reverse what you did if necessary.
If you want to experiment a bit, press the Control-Alt-Delete keychord (press all three keys at the same time) only once (if you press the keychord twice you will restart your computer). The Windows Task Manager will appear. Take the Applications tab and see if anything is running. If so, stop those programs (it's usually better to switch to the program and then close it from the program instead of picking Close from the Task Manager). Wait a bit as it sometimes takes Windows a bit of time to release all program assets. Then try to rename or delete the file. If you now can rename or delete the file you know one of the programs was using it (stop only one program at a time if you really, really want to know which one).
If you still can't rename or the file you need to go to the Processes tab. There should be a number of running processes. Two of these are particularly important: Explorer and Systray. Do not end these. The other processes should be able to be stopped. Try stopping those processes you may recognize one at a time. Attempt to rename or delete the file after each has stopped. If you can, then you know what process was using the file. Keep going until only Explorer and Systray are running. If the file is still in use you've got your answer. The most basic processes in the computer are using the file. The same caveat as above applies: the file was in use for a reason and if you rename it or delete it the system may become unstable if you rename the file.
File is Marked Read-onlyThis is the easy one. To find out if a file is marked read-only right click on the file in Windows Explorer. Select "Properties" from the menu that pops up. At the bottom of the dialog that appears are the attributes for that particular file. See if the Read-only box is checked. If so, you won't be allowed to modify the file. To take the read-only attribute off the file uncheck the box. Again, be aware that if some program requires that file to be read-only and you change that attribute or the file's name you may have system problems. Use caution.
Note: If the file is in use (see above) or you don't have the necessary permissions (i.e., you're not logged in with administrator status) the read-only box may be greyed out and until you correct whichever condition is to blame you will not be able to change the attribute.
How does a file get to be read-only? Most of the time it's by copying the file from a CD. Most CD media, by design, is read-only and often when you copy a file from a CD (or an install program copies the file) a read-only attribute will be given to the file because it was read-only on the CD. This doesn't happen often, but does happen often enough to cause some people problems.
File Name is Too LongWindows has special problems dealing with extra long path/filenames. If the combination of the path and file names gets close to 255 characters (127 for Windows 95/98/ME) Windows will likely not handle it well if you try to delete or rename it (you can create it but not change it). While there are programs that can handle names that long or longer (e.g., FileBoss) the first thing to try would be to rename some of the folders that lead up to the file itself. Back the directory display up one level and then select and rename the folder the file is in. Try a single letter (obviously, keep a record of what folder you named to what so you can reverse the process!). Then, go back to the file and see if Windows then allows you to rename or delete it. If not, go back yet another folder and rename that one and so forth. At some point you should be able to find a series of reduced-length folder names that allow you to then rename the offending file to a short enough name to allow you to then recreate the original directory tree and still work with the file in question.
Special Programs for Deleting Files/FoldersSometimes you can't seem to delete a file or folder no matter what you do. In this case there are a few programs that might help you.
If, after all this you still can't rename/delete a file, not certain what else to suggest. Others have this problem often and as different ideas might come up in the FILExt forum I'll change this FAQ to include them. If you find a method that works for you and is not in this FAQ, please drop FILExt a note with details on that method so it can be added to the FAQ.
Jul 24, 2012 | Acer Computers & Internet
Windows media player cannot find the file.if you are to play,burn,or sync an item that is in your library,theitem might point to a file that has been moved,renamed,or deleted
That is an error that is thrown out by Windows Media Player if it cannot locate the file, You might of accidently deleted it, moved it or renamed it. Try to find it and put it back into your library.
Aug 11, 2010 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Syncing with Windows Media Player
Place the music files that you want to transfer into the My Music folder of your computer - Windows will re-read them, and then you can synchronize to your device. Also, make sure the hold/lock switch is not engaged on the mp3 player - it probably isn't, but just check.
-Tha Mp3 Doctor
Dec 25, 2008 | GPX MW-238B MP3 Player
Sync
make a folder on your desktop, copy the files that you want from your 'music' folder, and paste them into this folder. Then copy all of the files in the folder you just created and paste them into your mp3 player. Open the mp3 player in 'my computer' and just right click and paste. Your music files should go over. Once you are happy delete the folder from the desktop or keep it for further use.
Oct 30, 2008 | RCA TH1101 MP3 Player
Wndows Media Player can not find file
you must uninstall both versions of media player then reboot and install version 11
to do this go to Start/control panel/add remove programs scroll down to media player and uninstall them
Jun 23, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
COBY MPC850
I have had this problem with the mp3 file had a incorrect title.. are they happening to all your mp3's or just 1 in particular? try moving 1 at a time and see if you can pin point it.
Apr 30, 2008 | Coby MP-C858 MP3 Player
Can't remove programs
When you try to remove certain programs on the PDA the following message may appear and in some cases the program will remain no matter how many times you try to remove it: Due to the nature of the PDA and the fact that the operating system is resident in memory at all times, some .DLL files cannot be stopped and removed. For example, the program below uses a .DLL file to run a program on the Start screen and is therefore always running. The only way around this is to rename the file via Active Sync. In Active Sync on the computer, click on Explore. You may have to wait a short while until Mobile Device is displayed, then follow the program file to where the uninstall file is located, i.e. \Program Files\OmegaOne\BattPack\BatBar.dll. If you try and delete the .DLL file the following message will appear because the file is in use at the time: Select BattBar.dll file and rename this, making sure the file format has the .*** suffix and is different from any other valid format, for example, do not choose .jpeg / .mpeg. In this case we have renamed the file Aaa.aaa. Once the file is renamed and saved, remove the PDA and soft reset. The program linked to the .DLL will no longer be present on the PDA. You can now re-dock the PDA, synchronise and go back to Remove Programs and successfully delete the file.
Sep 08, 2005 | Toshiba e740 Pocket PC
SanDisk Sansa Shaker SDMX9N-512 MP3 Player Logo
108 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
